Results 1 to 3 of 3
    FS: 2000 S4 6mt Cleveland, OH $9k
    For sale is my 2000 Audi S4 asking $9000.
    Used to be my daily and it puts the hurt on almost everything out there, but I got a new toy and haven't been driving it much lately. I also want to put a down payment on a house and this would be a good start if it sells.
    Anyway, here's the skinny on it...
    Engine:
    - ARP head studs $375
    - 034 phenolic spacer $80
    - new cam chain tensioners $250 ea
    - ECS ignition coil swap ICM delete on wrinkle black powder coated valve covers $400
    - Gates timing belt water pump kit recently installed <5k $600
    - 034 intake and brand new RS4 MAF $160
    - new n75 $125
    - new Bosch 044 drop in fuel pump $475
    - 550 cc injectors $220
    - new front o2 sensors $100 ea
    - new valve cover gaskets $50
    - 034 silicone spider hose kit $225
    - 034 silicone aux water pump delete hose $80
    - 3" upgraded solid aluminum SMICs $300
    - new silicone boost hoses $150
    - forge dv's $200
    - new Mann fuel filter
    - fidanza aluminum flywheel with southbend stage 3 clutch $1000
    -F21 frankenturbos with brand new center sections and SRM 1 bar wastegate upgrades $2000
    -tuned by Blake Beadle, max boost is about 26psi and tapers off to about 18-20
    - this car beats feat and sounds good doing it
    Suspension:
    - ECS poly motor mounts, snub mount and rear diff mount $350
    - 034 solid track trans mounts $150
    - JHM solid short throw trio shifter package and solid linkage rod $800
    - 034 solid rear sway bar w subframe reinforcements and 034 sway bar links $900
    - new front end refresh kit < 10k $500
    - Eibach/Bilstein cup kit $800
    - new PS pump <2k $120
    - 034 solid alum rear subframe mounts $120
    - new 034 center driveshaft bearing $100
    - 034 solid adjustable rear toe arms $220
    - complete rear Powerflex bushings $360
    - fresh alignment
    Brakes:
    - new wheel bearings all around
    - ECS stainless brake lines $100
    - new front calipers
    - brand new rear brakes (calipers, pads and rotors)
    - new parking brake cables (if you know about these cars you know those aren't cheap) $365
    Exhaust:
    - 3" turbo back catless down pipes into custom v-banded 3" exhaust with Magnaflow muffler and resonator $1200
    Interior: 9 / 10
    - 3M carbon fiber vinyl wrapped trim (very tastefully done)
    - white leather seats (no rips) (few cracks in the armrest)
    - Audi sport rubber mats $120
    - hot heat / cold AC
    - LED interior lighting
    - P3 vent gauge, matching Prosport boost, oil fuel pressure gauges mounted in center vents and wideband AFR gauge mounted on pillar $400
    - new front and rear door speakers, front is kicker and rear is Polk Audio $200
    - Pioneer touchscreen double din stereo with Bluetooth $300
    - cluster needs a new lcd screen but is still somewhat legible.
    Exterior: 6 / 10
    - 18 x 8.5 et30 alzor star wheels 235/40/18 nittos
    - ECS carbon fiber mirror caps $150
    - front bumper is in great shape minus small crack above passenger grill and holes in the filler plate from previous owner.
    - hood has small dent from stupid ECS billet dipstick sticking up too high and when I shut the hood,... Pop!
    - had some mean rusting going on the driver rear quarter so I had it fixed a few years back. It's starting to reappear but the worst part was when I painted it, the color didn't quite match even tho I was factory paint. So the silver looks off.
    I think I literally changed/upgraded/replaced just about everything on this car. It drives perfectly with no misfires or any crazy b5 gimmicks. I love this car and hate the idea of selling it.
    Only reason I am selling so cheap with all the goodies it has is because of the exterior issues. It bothers the hell out of me and I just don't have time for it anymore.
    I'd be happy to throw it up on a lift for serious buyers.
    Message me for more pics and details
    ONLY TRADES I WILL CONSIDER:
    SLC CORRADO vr6
    MK5 / MK6 GTI (TSI only)
    Old school Audi (Coupe Quattro, V8, 200, URS4/6)
    Senior Member Two Rings czsrock1990's Avatar
    Apr 20 2010
    2001.5 Stg3 B5 S4, 2001 B5 S4
    Chicopee Ma
    Bump because jkwon. Also if you ever decide to part out back to stock pm me got some nice goodies here. GLWS lots of goodies for that price.
    Pearl White Stage 3 B5 S4
    Brilliant Black B5 S4
    2004 Dodge Ram Cummins (Sold)
    Silver B6 S4 - Milltek catback, VMR 708's, (Sold)
    Price drop $8500
