Page 64 of 78 FirstFirst ... 1454626364656674 ... LastLast
Results 2,521 to 2,560 of 3083
  1. #2521
    Senior Member Three Rings BDP's Avatar
    Feb 07 2015
    Ohio
    Quote Originally Posted by brs2c View Post
    The distance from the center hub, greatly effects the impact of reduced rotational mass. However, there is a general rule. For every 1 lb of rotating mass you eliminate, it is like removing 6 lbs of sprung mass. Porsche uses a 1:7 ratio, but their cars are lighter, and the lighter the car the greater the difference felt.
    So, if you go from 31lb stock peelers to 21lb wheels, the math looks like: 10lbs lighter per wheel x 4 wheels x 6= 240 lb lighter feeling car
    ...you will notice better braking, too
    Thanks for the info...I was somewhere around that figure. I just didn't know the stock peelers weighed that much...I was thinking more like 29lbs a piece and the PSS tires weighting around 1lb a piece less than my current Goodyear all seasons.
    It will be interesting to see what the delta is on my 1/4th mile and trap speeds are after the switch.
    2014 Estoril Blue S4: [DSG] APR Ultracharged - Dual Pulley (57.75mm & 187mm), APR TCU tune, Bilstein PSS10 Coilovers, AWE Touring Cat-Back with Resonated Downpipes, JHM Test Pipes, ECS Intake, Divorced APR CPS
    (93 "Pump Gas" File - 1/4 mile - 11.40 @ 119.74)
  2. #2522
    Senior Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x
    New York, NY
    Quote Originally Posted by FlyS4 View Post
    Look, I understand that when you go and spend 2k on an ultra charger you are expecting it to perform. If it was me I would be also in disbelief as it would show that I made a mistake. Egos are high here and no one wants to be that guy to admit they made a mistake even though someone has compared both cars in the same conditions and has proof.
    Are you familiar with the term sample size?
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
  3. #2523
    Feb 26 2014
    2011 Subaru Forester 1986 Ford Mustang Gt
    New York
    This
  4. #2524
    Feb 26 2014
    New York
    Quote Originally Posted by BDP View Post
    Weighed the HREs vs Enkeis and there was a 10lb difference with the tires installed. I thought there was a discrepancy but after doing it 3x it was confirmed. Car feels much more nimble with the lighter wheels as well...
  5. #2525
    Oct 30 2016
    Boca Raton
    Quote Originally Posted by riceboy22 View Post
    Yes, I am an educated adult. Results from every tuner are all over and in between. Best way to know is to take as large of a sample as possible of identical cars with identical mods and compare them in the exact same condition against other tuner. Would obviously be best if the same person drives them all to illuminate driver error variable. Even then track prep would have to be done after every run to make it exactly the same. You get my point.
  6. #2526
    Apr 04 2017
    10 S4, 14 328d, 14 MDX
    Chicago IL
    Maybe we should focus on the term outlier... like a UC car trapping 109!
  7. #2527
    Oct 30 2016
    Boca Raton
    Quote Originally Posted by GandalfTheIbis View Post
    Weather+bigger pulley= bad performance,maybe other things contributed.
  8. #2528
    Feb 07 2015
    Ohio
    Quote Originally Posted by Moogas1 View Post
    Thanks for the update. Did you run any Dragy times with the HRE's on? Was there much of a difference in your times or trap speeds?
  9. #2529
    Feb 26 2014
    New York
    Havenít dragyd with the 19ís this was first time I used it, same day I received it. But on the track not much of difference for me in trap. Iíve trapped basically same with both setups.... give a mile here or there.... Iíll see if I can find a couple of slips and compare but weather conditions would be different. I donít have the luxury to track consistently and usually install the lighter wheels and tire setup for spring into early fall and the 19ís for late fall into early spring with all seasons.
  10. #2530
    Veteran Member Four Rings kelseysautobody's Avatar
    Mar 03 2009
    Cape Cod, MA
    Do you even realize how much you contradict your own arguments?
    Donít be confused here is a comparison with an APR guy....I drop the mic and walk away like a boss.
    So that's ONE APR car that was slow and you deem your set up superior but then...
    You want a larger sample size... Moving on
    Ohh trust me, itís well dialed in. Humidity and weather plus heat soak from a larger pulley on top of bottlenecking sc are the reasons.
    Damn right that APR car was dialed in, that car just sucks because of the big pulley and bottleneck!
    Whatís this thing about being dialed in? Lol, this is laughable when you are talking about a car with of the shelf tune and basically bolt ons. There is nothing to dial in...
    My car is much stronger on dual pulley tune. Given I had same weather when I ran 11.8 at 116 in the past I would have shattered that record. The APR car is a prime example how humidity or some other weather abnormality have affected me and the APR guy.
    When adding power to a car nothing could possibly go wrong! We're just bolting on parts, nothing to test or worry about, the car is going to be 100% the first time around!
    Simple answer: our cars werenít dialed in, mine should have ran 11.4 and his 11.7 All because of the weather.
    Ok ok you guys convinced me, the APR car wasn't dialed in... but neither was mine so mine should still be faster!
    This might be the first thing you've been right about but its you with the ego and you that should admit your mistakes.
    2013 S4 S-tronic - APR intake // KI 200mm crank pulley // EPL Stg II DP 93 + TCU tune // PLM hx // Jokerz Blower // Headers // Ice box // iABED TB
    11.281 @ 121.58
    1993 URS4 - Work in progress...
    Past: 07 S4 6MT ~ 03 A4 3.0 6MT ~ 99 A4 1.8T
  11. #2531
    Dec 03 2008
    2014 Forester XT, lawn mower
    Castle Rock, Colorado
    Quote Originally Posted by kelseysautobody View Post
    Lol he literally did say the APR car WASN'T dialed in, then said the same car is "well dialed in" didn't he. Why oh why doesn't this ever end!?
    Sent from my SM-G930VC using Tapatalk
    2012 Audi S4 Prestige 6 speed, 034 Stage 2, 034 SC pulley, JHM 179mm Crank, USP Intake, custom x-pipe exhaust, 034 Trans Mount Insert, 034 Front/Rear Diff Mount Inserts, JHM Stage 3 clutch, JHM LWFW, USP SS clutch line, 034 boost tap, Podi boost gauge
  12. #2532
    Senior Member Four Rings evil35r's Avatar
    Mar 22 2016
    HD Fat bob
    Ham central, VA
    Iím so over this right now
    13 S4: Tune EPL, CTS 57/XLR8 196.5 Meth/E file, ROC-EURO w/ custom velocity stack, RSE test pipes and custom catback, ECS inserts, 034 subframe mounts, CR-15, H&R Sports, ECS Slotted rotors, Akebono pads, Snow Performance meth dual 375 nozzles=1000cc 70/30 mix, 034 rear sway, coolant pump mod/divorced, Merc hx, AG M590 wheels/Indy 500ís, iABED 75mm TB, Autotech, Matty Blower with hygroscopic vents on ics.
    11.27 @ 122 via Dragy W/ 180/57 ratio
  13. #2533
    Feb 26 2014
    New York
    Ok, I put a little slide show together... the earlier dates were with the 19ís and all-season tires.... the later with 18ís and RE71Rs
    Hope it helps....
  14. #2534
    Feb 26 2014
    New York
    Hope it helps....
    Wtf, it wonít post any photos etc... Iíll try later... need to trim the bushes in my yard...smh
  15. #2535
    Dec 03 2008
    Lol adulting is so hard
  16. #2536
    Feb 26 2014
    New York
    Hmmmm, not really but hey who am I to say...
  17. #2537
    Oct 30 2016
    Boca Raton
    Weather has undialed both of the cars. However mine was less undialed because itís just a better car with a better set up....finally you get it my girl Kelsey!
  18. #2538
    Dec 03 2008
    Let's please stop using the term "dialed in". Weather does not "undial" your car, also undial isn't a thing. Sure, weather can be less than optimum, but your excuses and misdirection are getting tiresome.
  19. #2539
    Oct 30 2016
    Boca Raton
    I agree there is nothing to dial in itís of the shelf tune! Itís not like we get our tunes then we can adjust all the tables on our own. So I agree, everything was dialed in when the car got the software upgrade.
  20. #2540
    Jan 03 2007
    VW/Audi/Ducati
    Houston
    Let's move on...
    13 Audi S4 | APR Stage 2+ Ultracharger
    14 Lexus CT200h | Batterycharged
    PREV: 01 Audi TT 1.8TQM APR Stage 2 | 07 Audi A4 2.0TQM Unitronic Stage 3 | 12 VW Golf R UM Stage 2+
    Other: 08 Yamaha YZF-R6 | 12 Ducati 1199 Panigale S | 14 Ducati Streetfighter 848
  21. #2541
    Jun 06 2016
    Florida
    Quote Originally Posted by kristokes View Post
    Let's move on...
    Just permaban him and get it over with
    2018 Daytona Gray S6 | S Sport | Black Optic | Carbon Atlas |
    2011 Phantom Black S4 | S-Tronic | P+ | Nav | Sports Differential | Titanium Package | Silk Nappa | SOLD
  22. #2542
    Nov 23 2017
    New Jersey
    2016 Rs7
    APR stage 2
    Apr downpipes
    Roceuro intake
    260GTplus
    Tcu tune by e tuners
    PS4 tires
  23. #2543
    Established Member Three Rings FromRagsToS4's Avatar
    Jan 23 2017
    Idaho
    Quote Originally Posted by AnesRS7 View Post
    2016 Rs7
    APR stage 2
    Apr downpipes
    Roceuro intake
    260GTplus
    PS4 tires
    Wrong forum buddy ;)
    RS7s are that way - - - - >
    Sent from my SM-G930T using Tapatalk
    2014 S4 Premium Plus/Glacier White Metallic/6spd Manual/Sports Diff/Adaptive Damping Suspension/Black Napa Leather/19" Peelers/B&O Sound/MMI-Navi/Side Assist/Carbon Atlas Inlays
  24. #2544
    Dec 03 2008
    Lol I was like DAMN til I realized what was going on.
  25. #2545
    Senior Member Four Rings JD S4's Avatar
    May 07 2016
    Boulder, CO
    Quote Originally Posted by FromRagsToS4 View Post
    Everyone is welcome here. Especially fast cars! A lot of us will go to an RS7 next so itís good to see.
    Congrats man - 132 is fasssst!!
    Sent from my
    2018 SQ5 - Daytona, Prestige - JB4 on E85, Airmatic Lowering Links & 15mm Spacers on 21s
    *Sold*2011 S4 - EPL Dual Pulley + TCU - 20" BBS LM - Bilstein B12 - APR RSC Exhaust
    Deval CF Diffuser - Maxton Splitter - USP Intake - MercRacing HE - CR15 -AutoTech HPFP
  26. #2546
    Dec 03 2008
    Quote Originally Posted by JD S4 View Post
    Sent from my
    I totally want an RS7 for my next car. Can't believe I'm seeing them used for like 60-70k. Stage 2 they should be making almost 700 CHP right?
  27. #2547
    Nov 23 2017
    New Jersey
    This is with fuel cut lol I put a gallon of E85 on top of the Sunoco fuel!! Fml... lol IMG_1163.JPG
    After I did 10.3 I stoped lol (dident wana break anything lol)
    Upgrading a few things and will be back in 2-3 weeks for a 10.1-10.2
    Thanks guys!
  28. #2548
    Veteran Member Four Rings UkuRiSh's Avatar
    Jan 09 2010
    New York
    Thanks guys!
    I'll hunt you next year buddy Nice numbers
    2013 AUDI S5 Stage 3 J-Fonz 545whp/490wtq / 10.45@134.78 by Dragy < Press @svarog_edition < last test updates
  29. #2549
    Oct 30 2016
    Boca Raton
    I might go get one tomorrow, found a sweet deal on auto trader. Wonít hurt to get a 4th car.
  30. #2550
    Dec 03 2008
    Gonna race it against your imaginary M4? Just get over yourself already. I don't understand the compulsive lying for no reason.
  31. #2551
    Oct 30 2016
    Boca Raton
    Your dream is my reality jimbo...
    But you got a point, the M2 is not mine.
  32. #2552
    Nov 23 2017
    New Jersey
    Quote Originally Posted by UkuRiSh View Post
    rock and roll baby!
  33. #2553
    Feb 26 2014
    New York
    2016 Rs7
    APR stage 2
    Apr downpipes
    Roceuro intake
    260GTplus
    PS4 tires
    Great run, man...!
  34. #2554
    Senior Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Jur Mahm
    Denver CO
    3 cars... in a condo?
    2013 S4 Estoril Blue Crystal 6MT / Prestige / Silver & Black / B&O / Sport Diff / 20% Tint / ECS SSK / E-codes / RS Grille / Ziza Yellow Fogs / ECS Slotted & Drilled Rotors / Akebono Pads / Roc Euro Intake
    Denver to Vegas in 9:26 (2/27/15)
  35. #2555
    Mar 07 2016
    Oceanside, CA
    Bogdan, your 12.4 run that day is just as much of an outlier as an APR UC car trapping 109, yet youíre claiming to understand statistics? I have no interest in creating drama, but Iím concerned youíre twisting reality for the purposes of your own confirmation bias towards GIAC and against APR.
    Why donít you be transparent and post all of your runs and explain what you did to get to your best run? Any apples to apples comparo should be done with doing the same for both cars by posting logs, understanding the state of tunes and conditions, and highlighting mitigating circumstances that would explain unexpected results such as missed shifts, bad launches, tire pressure variations between runs, octane content, etc.
  36. #2556
    May 07 2016
    Boulder, CO
    Quote Originally Posted by youngrepublic View Post
    The cal is on you.
    Sent from my
  37. #2557
    Oct 30 2016
    Boca Raton
    Brian, what do you know about comparing? I have known you for 11 years and you couldnít even adjust your own coilovers on that 2004 VW. Have you ever worked on your own car? Are you even able to perform your own oil change?
  38. #2558
    May 07 2016
    Boulder, CO
    You just proved you are exactly
    Who we thought you are.
    Sent from my
  39. #2559
    Oct 30 2016
    Boca Raton
    **NEW** 1/4 mile spreadsheet: Submit your time here
    Sent from my
    And who would that be? Conspiracy? East North, SouthEast?
    I am Brianís former neighbor who helped him turn knobs on his kw suspension because he wasnít mechanically inclined to do so himself while I was Stationed in Camp Pendleton, Ca sometime back in 07,08.
  40. #2560
    Mar 20 2015
    McKinney,TX
    Unsubscribed
