Page 66 of 66 FirstFirst ... 1656646566
Results 2,601 to 2,624 of 2624
  1. #2601
    Senior Member Three Rings awwturbo's Avatar
    Mar 22 2012
    2010 VW Passat Komfort Wagon, 2012 Ducati 1199 Panigale
    NH
    Quote Originally Posted by kelseysautobody View Post
    I’d be willing to guess using straight 93 is hurting your traps and times a bit. The gas in New England is garbage. I’ve tested “top tier” gas from a few different stations in my area and the Boston area and most of the time I couldn’t hit more than 15-16* timing. On the same file cars using 93 in other parts of the country would have no knock issues. Until I was mixing E25+ I’d see quite a bit of timing pull.
    Next time I head in I'll put some 100 octane in or find some E85. It'll be interesting to see how much of a difference that makes.
    [2012 Audi S4 Prestige | S-tronic | Moonlight Blue | Black Nappa Leather | Sport Diff | Titanium Package | IE Stage 2 tune & DSG tune | AWE Coldfront System | CTS 57.02mm S/C Pulley | JHM 179mm Crank Pulley | ECS Luft-Technik Intake | CR-15 Brace | H&R OE Sport Springs | 034 Trans Insert | ECS rear diff mount | ECS X-pipe]
  2. #2602
    Established Member Two Rings Jimcoily's Avatar
    Apr 06 2017
    Port Orchard, WA
    Thanks for the info guys. Next time out ill try a higher rmp launch and mix a gallon or 2 of race gas in.
    Sent from my LGLS992 using Audizine mobile app
    2011 Stasis Challenge - APR Stage 2 (V4) - Roc-Euro intake - APR 57mm - JHM 179mm - Eurocode Headers - Milltek Resonated Catback - JHM Flywheel & 3R Clutch - 2 Booster Seats - Baby On Board Sticker........
  3. #2603
    Active Member One Ring alejodiazz's Avatar
    Jan 03 2014
    Jetta MK4
    Bogota/Colombia/SA
    Hi, this is my best time so far at sea level, APR ultracharger, unfortunately was using launch control at the time too much wheel spin, room for improvement. Will be adding headers and ported blower next time, an no launch...
  4. #2604
    Senior Member Four Rings Loe's Avatar
    Aug 09 2015
    '14 Audi S5, '18 BMW 540i
    Sarasota, FL
    Quote Originally Posted by alejodiazz View Post
    122mph is pretty great at that D/A, you run a 93 octane file right?
    -Loe- ('14 Audi S5 S-tronic )
    [10.930@127.38mph | +1209 ft. D/A | 3.371 PR]
    Technical discussions? JOIN ME!
  5. #2605
    Aug 09 2015
    Sarasota, FL
    I went to the track last Thursday. It was rather hot.... 91F when I arrived.
    Temperature during the run: 89F
    The D/A hovered near 3,000ft D/A (approx 2990ft on my runs)
    I ran near a 1/2 tank of fuel tonight (slightly under actually), like always. Full spare/jack/tools, like always. My tires are near 3/32nds, but the track surface was warm enough and I launch low enough to where it doesn't matter, pressures are set to 38psi front/37psi rear (cold pressures).
    Launch method: engage LC sequence, module gas near 2,000rpm, once I let go of the brake, stomp the gas pedal past kick down. Nice clean shifts
    Breakdown of the run #2 (only ran twice):
    60ft 1.673
    330ft 4.732
    1/8 7.254
    MPH 98.43
    1000ft 9.411
    1/4 11.230
    MPH 124.59
    CLICK ME FOR TIMESLIP
    CLICK ME FOR D/A PICTURE
    CLICK ME FOR MY LOGS
    IAT's were 100% under control, couldn't had asked for better IAT considering it was 89F on both runs. The 194mm is working itself out to be pretty great as temperature's rise, performance remains more consistent year-round now. Previously on my "baby 179" I could only muster 118mph in this temp.
    Mods: APR UC race file (e85/93 octane), APR TCU, 194mm crank, 57.55 upper, Tampa Autosports ported blower & test-pipes, Modded OEM intake, Killerchiller w/ AWE & PLM reservoirs, Autotech HPFP, "Lift-pump" mod.
  6. #2606
    Senior Member Three Rings maty360414's Avatar
    Oct 13 2015
    Orlando, FL
    Qué bueno saber que alguien de Bogotá tiene un S4 tambien con todos las modificaciones. Lastima que allá no vendan E85. El que tienes es un B8 o B8.5.
  7. #2607
    Jan 03 2014
    Jetta MK4
    Bogota/Colombia/SA
    Quote Originally Posted by maty360414 View Post
    Es un B8, uno de cuatro en el pais univamente, B8.5 ninguno desafortunadamente
  8. #2608
    Oct 13 2015
    Orlando, FL
    me gustan bastantes los rines que le tienes son Avant Garde?. Yo estaria feliz con mi carro que tengo aca, si lo tuviera en bogota. Que tiempo estas haciendo en tocancipa en el 1/4 de milla. que tanta diferencia hay contra baranquilla. Este es el mio.
    '13 S4 - Phantom Black | DSG | H&R SSP | Vertini RF 1.3 | Sport Differential | Akebono Pads | ECS Trans Mount | ECS F/R Diff Mount
    ECS Drilled & Slotted Rotors | EPL DP Water/Meth | EPL TCU | JHM 187 | MercRacing HX/Divorced | 1Res 1NonRes X-Pipe | Spoiler+Diffuser | Becker TestPipes
    Michelin PS4S | Roc Euro Intake | RS Grill | AEM Water/Meth | CR-15 | AutoTech HPFP | 5K Fog LED's | Vagcom Mods | (Meth File) 93/E85 11.4@119 MPH
  9. #2609
    Jan 03 2014
    Jetta MK4
    Bogota/Colombia/SA
    me gustan bastantes los rines que le tienes. Yo estaria feliz con mi carro que tengo aca en colombia. Que tiempo estas haciendo en tocancipa en el 1/4 de milla. que tanta diferencia hay contra baranquilla. Este es el mio.
    12’8 ha sido mi mejor tiempo con 93oct, hay 1 segundo de diferencia aproximadamente, Nice ride!!!
  10. #2610
    Oct 13 2015
    Orlando, FL
    hay demasiada diferencia con la altura 1.3 segundos. usas launch control o upswing para la salida. Alla en colombia hay alguien que te pueda pulir el supercargador por dentro para tener mas boost.
  11. #2611
    Jan 03 2014
    Jetta MK4
    Bogota/Colombia/SA
    Usaba launch, ya aprendí a hacer el upswing, los 60 pies bajan casi 3 décimas, en Barranquilla patinan las 4 llantas toda la 1ra con launch
  12. #2612
    Senior Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x
    New York, NY
    @Loe, what type of wheels and tires are you running? Sorry if it’s been covered before, but given you guys are trying to shave tenths at this point, I would imagine even 5 lbs per corner of unsprung weight per corner would make a material difference. I saved more like 15 lbs per corner off the stock wheels, but I drive a soccer mom wagon.
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
  13. #2613
    Oct 13 2015
    Orlando, FL
    Si a mi me pasa lo mismo cuando hago launch a 4K a 32PSI con las llantas Michelin Pilor Sport 4S. Que llantas usas? Necesito volver a la pista a mirar si bajo el tiempo con las nuevas modificaciones que le hice pero esta muy caliente para los iAT's. Tu tienes un taller en bogota WagenWerks?
  14. #2614
    Jan 03 2014
    Jetta MK4
    Bogota/Colombia/SA
    32psi?!! por el metanol? Que diferencia en potencia con metanol? Yo uso PZero. Correcto Wagen Werks
  15. #2615
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by riceboy22 View Post
    Still running OEM S5 Rotors (29.5lbs I believe), 19x9 in size. Stock brakes, stock exhaust (minus the test pipes, "added" weight via an SQ5 H-pipe for sound purposes). I can think of ways to reduce weight, but really I never even thought I'd venture this far into modding, that's why I've kept it the way it has been appearance-wise and kept my mods rather "basic" or low-key.
  16. #2616
    Mar 22 2012
    NH
    Quote Originally Posted by Loe View Post
    60ft 1.673
    330ft 4.732
    1/8 7.254
    MPH 98.43
    1000ft 9.411
    1/4 11.230
    MPH 124.59
    Wow.. that killer chiller keeps those IAT's pretty low! Friday's runs at the track I was starting off in the mid to high 40C in 70F temps.
  17. #2617
    Oct 13 2015
    Orlando, FL
    no jajjaaj con las llantas a 32PSI de aire. Estoy como alrededor de 20PSI de boost masomenos. el metanol ayuda como con 10grados menos en los iAT's que es bastante y me sube como a gasolina de 100 octano con el methanol. le mesclo 50/50 agua destilada y metanol. No se en bogota que tan alto suban los iATS's por lo que es frio pero si en colombia venden methanol te lo recomiendo. Mi amigo aca tiene APR UC y le tiene methanol le funciona perfecto. a mi tambien me funciona perfecto con EPL.
  18. #2618
    Jan 03 2014
    Jetta MK4
    Bogota/Colombia/SA
    Ahhh jajajaja,
    yo lo hago a 41psi se baja top speed con tan baja presión
  19. #2619
    Oct 13 2015
    Orlando, FL
    Ahhh jajajaja,
    pero con tanta presion pantina mucho a la salida. Que modificaciones le tienes a parte del APR UC.
  20. #2620
    Jan 03 2014
    Jetta MK4
    Bogota/Colombia/SA
    APR ECU TCU, APR Dual pulley, APR Intake, APR charge cooler, catless downpipes, Milltek exhaust, stock brakes, stock suspension,
  21. #2621
    Oct 13 2015
    Orlando, FL
    Super bien. Los otros S4 que me dijiste que hay tambien estan tuned y en bogota? o ni idea
  22. #2622
    Jan 03 2014
    Jetta MK4
    Bogota/Colombia/SA
    Ninguno, hay uno negro mecánico que pronto comenzaremos a modificar, solo tiene R8 BBK
  23. #2623
    Oct 13 2015
    Orlando, FL
    este es un log a 35 grados celsius afuera con Methanol de 100kmph a 210kmph
    https://datazap.me/u/maty360414/wate...0&data=0-1-5-6
  24. #2624
    Oct 13 2015
    Orlando, FL
    super bueno que modificaciones van a ponerle?
