Results 1 to 23 of 23
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    Bang & olufsen amp and sub
    Have a oem b&o amp and sub
    Both in perfect working condition.
    Also have the 2 rear deck lid speakers
    $200us shipped for amp
    $100us shipped for sub
    $50us shipped for 2 speakers
    Sent from my SM-G900W8 using Tapatalk
    Dec 01 2011
    do you know if this is a direct swap/upgrade to non-b&o cars? will i need any coding, extra adapters/harnesses, or any new panels or anything, or just a straight swap.
    IG @theshawon
    Aug 15 2015
    2 feet
    Niagara canada
    It's not a straight swap..Harness plugs are definitely different.Not sure what else you would need
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    Quote Originally Posted by Liquid Smoke View Post
    do you know if p+ come stock with amplifier?
    i think mines missing
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by JeriQo View Post
    Concert = No amp
    Symphony = Amp (this amp is different than the B&O amp)
    If you don't have an amp now you will need to get the correct harness to connect to the radio and it routes back to the rear where the amp is located.
    Jul 08 2015
    Quote Originally Posted by The Infiltrator View Post
    Concert = No amp
    thanks for the info.
    not sure what mine is but it says Audi Multimedia. i do have nav. im assuming its a concert.
    Sep 09 2010
    Destin, FL
    Go to your trunk and pop open the left side panel, there should be an amp.
    Jul 08 2015
    the nav is there but no amp.
    i got a first aid kit there now where that amp i think is supposed to be.
    Sep 09 2010
    Destin, FL
    So you have the Concert system, you'll need the wire harness that goes from the front to the rear then.
    Veteran Member Four Rings Zach L's Avatar
    Feb 24 2010
    Austin, TX
    Concert = No amp
    This is misleading since Audi Concert does indeed HAVE an amp, IF the car had factory B&O system. B&O was an option on all the head units, so simply going off the head unit is not accurate.
    Daily Driver: B8 A4 quattro 6MT, Aruba Blue on Black, Premium Plus, Sport Package, Bang & Olufsen
    Current Projects: 2006 Cayman S 6MT • 2006 VW GTI 2.0T 6MT • 1997 VW Golf • 1982 VW Rabbit Diesel • 1972 VW Bay Window Bus
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by Zach L View Post
    Not sure if you read the whole thing or what? He doesn't have B&O or an amp, so he has the basic Concert system, the next setup was Symphony which had the amp and a sub, finally B&O which has it all.
    Feb 24 2010
    Austin, TX
    JeriQo asked if P+ came with stock amplifier. He didn't say whether or not he had B&O. Either you made an assumption about his car or you made a blanket statement that's only true in some cases.
    Sep 09 2010
    Destin, FL
    Well you're right on that one. I thought all B&O came with the sub and amp in the rear. I'm pretty sure there was only one setup of that system and if he doesn't have the amp in the rear, he doesn't have B&O.
    Edit: Don't B&O setups have two subs in the rear?! I have one since I have the Symphony speakers.
    Feb 24 2010
    Austin, TX
    Yeah it's confusing because of his question. People ask if a certain trim level has some part, when stereo equipment can't be known based on trim level alone or even head unit. B&O always has an amp and sub, but B&O was an option on multiple trim levels and Audi Concert radios could be had with and without B&O. He later mentioned he doesn't know what he has, so no telling if he does or doesn't have an amp.
    Sep 09 2010
    Destin, FL
    He said he didn't have the amp after I asked him to check where it should be located.
    Feb 24 2010
    Austin, TX
    He has no clue. He said he didn't know if it was missing. He also said he has nav and Audi Concert. Well you can't get nav with Audi Concert so he truly has no clue. If he actually does have nav then he does have an amp.
    Or he's just trolling.
    Sep 09 2010
    Destin, FL
    lol, I don't think he's trolling.
    Jul 08 2015
    got the car used. its a P+ w/nav.
    theres no amp, but i have subwoofers.
    im not sure if someone ripped that off before i purchased it.
    ---yep no clue if its a symphony or concert.
    Sep 09 2010
    Destin, FL
    You wouldn't have sound if that was the case.
    Look at your driver's door, the speaker cover will be all black and nothing to it. If in fact you have B&O it will be a round chrome piece that says the B&O name on it.
    Jul 08 2015
    i know for sure its not a BO
    Sep 09 2010
    Destin, FL
    Then concert it is, as I said before.
    Jun 12 2013
    1999 Pontiac Grand Prix GTX
    LaSalle, Ontario, Canada
    This is a B&O amp with MOST. I think I need this for my 3G+ retrofit.
    Infiltrator, if you're still watching this, can you confirm if I'm right? If so, consider the amp sold.
    2010 Silver Audi A4 MT Sport Package w/ B&O
    Stage 'X': FrankenTurbo F23L Ceramic Coated Manifold | Bully-Flo P&P Head | Ferrea Intake Competition Valves | Ferrera Exhaust Super Alloy Valves | IE ValveSprings & Retainers | HFC wrapped w/ DEI Titantium
    Eurocode FMIC | Maestro Tuned | K&N Typhoon Intake | EuroCode Meisterwerk | StopTech BBK | 034 Motor Mounts & All Inserts | CTS PCV Catch Can
    Build Thread
    Feb 24 2010
    Austin, TX
    Quote Originally Posted by Allowencer View Post
    Yes, the female plug hole on the left in the second pic is for that.
