Results 1 to 7 of 7
    Mar 01 2011
    Nanuet NY
    Need help with this haunting P2177 code
    So i keep on getting this code. Its driving me nuts. I have been working on it for like 2 months. The engine is swapped to an early ((BPG) i think). Running out of ideas. Car runs great. i have changed:
    timing belt/chain
    valve cover gasket
    cam follower
    maf
    Spark plugs
    front and rear O2
    pcv valve and breather tube
    pcv valve (2) hoses
    low pressure fuel pressure sensor
    checks for leaks and cracks nothing obvious
    Fuel filter
    I have a Ross Tech Vag Tech
    1 Fault Found:
    008567 - Bank 1; System Too Lean off Idle
    P2177 - 001 - - MIL ON
    Freeze Frame:
    Fault Status: 11100001
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 246796 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1896 /min
    Load: 58.8 %
    Speed: 85.0 km/h
    Temperature: 78.0°C
    Temperature: 21.0°C
    Absolute Pres.: 990.0 mbar
    Voltage: 14.351 V
    Mar 01 2016
    San Diego/CA
    Maybe some vacuum leak. Have you done a smoke test? If you have VAG-COM or torque pro, you can watch for short and long term fuel trim which will give you some idea to further diagnose the problem. Possible causes could be vacuum leak, fuel injectors, MAF(you have already changed) or fuel pump.
    May 15 2014
    Whittier, CA
    Quote Originally Posted by reno808 View Post
    timing belt/chain
    valve cover gasket
    cam follower
    maf
    Spark plugs
    front and rear O2
    pcv valve (2) hoses
    Fuel filter
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 246796 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1896 /min
    Load: 58.8 %
    Speed: 85.0 km/h
    Temperature: 78.0°C
    Temperature: 21.0°C
    Voltage: 14.351 V
    I fought that same code since Feb/Mar of this year. I don't know which one fixed my issue since I did them both on the same weekend but when I replaced my DV (even though I already had the rev D) and installed the 034 Catch Can (you replaced pcv and hoses so should rule that out for you), I have been free of that code for 3 weeks now and have gone WOT quite a few times. Hope that helps.
    Mar 01 2011
    Nanuet NY
    Thanks I will change the DV and see what happens. I will also get the smoke test done as well.
    Mar 01 2011
    Nanuet NY
    i changed the DV and the basket was broken. I put it in a new DV along with the GFB DV+ dv. Thought to myself yessss thats it. ANNNNNNNNND no it wasn't, the code came back with another Fuel Pressure Sensor (G247) code Implausible Signal - Intermittent
    Any ideas?
    Mar 01 2011
    Nanuet NY
    HELP anyone?
    Dec 28 2016
    Brazil
    Hi reno808, managed to solve the problem?
