Bought this S4 as a mindless project for $4K with 113,XXX miles. It had been hit in the passenger doors in a parking lot/low speed impact on base. The insurance company ended up writing it off and I picked it up before it hit craigslist. I have an A4 as a DD and a F350 for work, this thing is purely a hobby as most of my time is spent on the supermotos.
Before the rest of the Pandem RocketBunny Front Aero kit was installed. (it was originally made for a 180sx)
Put the winch in the F350 hitch receiver and pulled the center door pillar back out to where the doors would open and shut. Picked up a set of doors from a donor A4 from a pick-n-pull in S.C. for $145. Took the doors apart and swapped all the bose/controls/tinted windows/seals from the S4 to the A4 door shells. The only real difference in the door interior is the rear window sun shade.
Drove it for about a month and noticed it had numerous oil leaks-the most severe being the valve covers and valley pan. It shifted really rough too, with a ton of slop. Was coming off the interstate late one night and spiritually downshifted from 3rd to 2nd only to have the clutch stay in the floor.
Shit this is going to get expensive! Funny enough as I was cleaning it out to pull into the garage for the long-term project I found a few time slips from a local dragstrip...looks like my poor car saw a rough life before me.. the times weren't anything to brag about and it was probably the cause for the poor feeling clutch.
In the process of pulling the clutch I discovered one of the motor mounts was in 2 pieces and the snub was non-existent. I decided to go ahead and do the oil check/spray valves while the valley was open even though I dont have any rattle on start-up. I am also following a poly fill DIY for the rear diff mount.
Just gutted the piggies and am starting the fender cut for the ram air intake tonight.
Spent waaay too much on parts some of which are listed below:
JHM Stage 4 clutch w/lightweight flywheel
Piggy pipes
ECS Snub mount
APR Carbon NACA duct-fender mount
Rocketbunny V2 Splitter/Canard- True JDM import
Nokya Fogs
Weighted shift knob
K&N Pod filter
Rally Armor mud flaps
H&R Lowering Springs
JHM Intake spacer kit
034 Street Density Billet Motor Mounts (upgraded 10mm hardware for launches)
JHM shift stabilizer bushings
Oil pressure sensor
Valley pan gasket/oil check valve/ (2X) oil spray valves
Valve cover gaskets
Accessory Belt
ECS street shield aluminum skid plate
Sachs clutch slave cylinder
Oil filter housing o-rings
Cam chain tensioner gaskets/ hold tool
Driveshaft flange seal
90 degree stainless O2 spacers
Vinyl wrap(for silver doors) and for graphics
Honeycomb grill
Tow hook
Euro plate
Stainless Rear diffuser
Stay tuned as Ill update with more pictures as the engine and body start coming back together in the next few weeks. Currently tearing into an Aprilia and a CRF450 as well so my time is limited.
