2009 Audi A4 2.0 T Quattro Sedan Prestige
180K miles on the body
98K on the engine.
I was driving and everything was fine until my engine started vibrating between 1000-3000 RPM. If i accelerated above 3000 it would stop. I pulled over. The exhaust became almost smoky but smell like gas. So, I had the car towed. I had the car engine light checked and it said cylinder 4 misfire. It read it twice. I pulled out the spark plugs and the 4th one was covered in gas. I changed the with a new coil pack and spark plug. Same problem. Rough idle barely started. I removed the intake manifold and took out the fuel injectors. I order new ones and a fuel filter. Be here on Friday.
My main questions is: What else could cause my cylinder to fill up with gas if its not the Fuel injectors? I want to cover all bases as I can.
Thank you for your feedback!
