Results 1 to 6 of 6
    Senior Member Three Rings engineerjet's Avatar
    Aug 02 2013
    How to tell if flap motor is bad?
    I tried doing a search and couldn't come up with anything related to verifying a flap motor. Long story short I got a p2014 code and I ordered a new flap motor. After installing it and driving the code came back. Took it in for a diag and the tech says he's getting code for mechanical fail of the flap motor. So before I go off replacing another flap motor (it's covered under warranty but just wanna avoid hassle if I can). It's possible I got a lemon, but is there a way to verify the motor is actually bad?
    Dec 23 2011
    I believe there are multiple flap motors depending on your model year, did you get the right one?
    Aug 02 2013
    Yes, I verified by vin. It is 06f133482e.
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Did you take it to the dealer or local independent shop?
    It needs to be adapted to the car via VCDS (and only VCDS). I'm pretty mechanically savvy and changed it myself, have a full vagcom, etc but lost 2 days trying to replace my failing flap motor....I ended just leaving it at my local Audi dealership (which I never go to), leaving them the keys, and told them to make that light go away without asking me anything. 2 days and $600 later, they did. Don't know and don't care how...Was at my witts end. The only thing I can think of is that either the VDO (not Audi) part was defective or similar, but the stupid thing never wanted to adapt via VCDS and always just threw a mechanical error...
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Senior Member Two Rings aviator79's Avatar
    Apr 10 2012
    Suffield, CT
    Quote Originally Posted by BenMTL View Post
    Wait, what?
    Edit,
    OK so part must match for vin?
    Stock B7 A4 quattro
    MS6 BNRs3
    B5.5 WV Passat
    Active Member Four Rings EvolutionArmory's Avatar
    May 20 2017
    New Hampshire
    Quote Originally Posted by aviator79 View Post
    Wait, what?
    Edit,
    There are 2 flap motors. One for cars made before August 2005 and one for cars made after August 2005. Checking which one you need by VIN is the best way to make sure you get the right one because the early one won’t work with later cars and vice versa.
