Results 1 to 24 of 24
    Dec 05 2015
    Atlanta, GA
    LED fog light replacement recommendations
    I did some searching around the web and Audi forums for some input on this, but seems like most of the posts were from last year or older. I'm sure I could have missed something more recent so I apologize if I did, but I was hoping to get some recommendations on what LED bulbs to put in my S4. The ones that seemed really good were the VLED VX3 that someone on here put in about a year ago, but they don't sell them anymore in the H8 bulb and looks like they are only on closeout for H7 bulb. I kinda liked them because they were an all-in-one solution. I've seen people mention the ones member t8ups has sold and Hoen xeonmatch. I don't really like the Hoen ones because they don't seem to give off a lot of light. I'm not looking for blinding output, but someone decent would be good. I was hoping to find a solution that was in the 2500-3000 lumens output, that closely matches the headlight LED, and that hopefully doesn't throw a code. And I'm not sure if it will matter or not, but it is better to get one with a fan or fanless? Thanks for your time.
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    I run VLEDs on my allroad (h11 bulb). Read my blog if you want a review: http://petervutheblogger.blogspot.com/
    Dec 05 2015
    Atlanta, GA
    Maybe I'm confused about bulb types, but from searching around, it says my '14 S4 has a H8 bulb. So the '15 Allroad has H11 bulbs? I looked on VLEDs website and it looks like they don't have any H8 bulbs available. I had emailed them and they said they had the SMZ model, which appears to be fanless, but there was two problems. They won't have the H8 bulbs won't be available until early August, and it looks like I would have to buy additional resistors because of the current draw. Looks like they don't have ballasts on these to prevent the "bulb out" indication.
    Dec 05 2015
    Atlanta, GA
    Nevermind about the bulb question. I looked around and i see that H8 and H11 bulbs are the same base so for LEDs can be used interchangeably. So I could order the H11 version they have on the site. Thanks!
    Apr 05 2016
    Portland, OR
    I have these in my fogs: https://www.amazon.com/gp/product/B019IDMAXO
    I had to modify the base a little bit to make it fit. (H11 vs H8)
    They are not super bright(400 lumens) and a little too blue (6000k vs the DRLs at 5400k)
    I will likely replace them at some point but, they are still much better than stock.
    I had an Amazon Giftcard laying around from graduation so I ordered a different set: https://www.amazon.com/gp/product/B01C6FPSA8/
    I suspect they will also be too blue but, should be far brighter.
    They should arrive tomorrow. I will let you know what I think.
    Geoff
    Aug 25 2013
    florida
    Quote Originally Posted by zcspec View Post
    came in looking for fog leds, left looking at allroad online reviews. the car is crisp, perfect height on the 620s. the crazies at audi not making an avant
    2014 sfeux p+ 6mt bo nav w/o sd
    Jul 07 2014
    Calgary, AB, Canada
    These just came in for me. Supposed to be 3000 lumens per bulb. Came in with some filters to change color, someone on here said that without filters they're same color as the headlights. I will throw them in later today and report back.
    2013 S5 6MT Phantom Black Pearl, Unitronics Stage 2+, AWE Touring /w res downpipes, KW V1, Eurocode Intake
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    i got a fanless led from ebay for 35 bucks.
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Jul 07 2014
    Calgary, AB, Canada
    Ok I put one in. LED is on the left side of the picture, not quite an exact color match but definitely brighter than stock incandescent bulb.
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by Tangerined View Post
    You should provide some photos in the dark when you have a chance.
    The main time I use my fog lights is when I am out in the country and want to light up the side of the road to keep an eye out for animals.
    That, and the LED bulbs look better when I unlock my car.
    Geoff
    Jul 07 2014
    Calgary, AB, Canada
    Quote Originally Posted by whiped View Post
    Yeah for sure, I'll get some pictures tonight after dark.
    Aug 10 2015
    Orange County
    Quote Originally Posted by Oloung1 View Post
    Sorry about that. I really was trying to provide the OP a review of the VLEDs.
    Dec 14 2015
    Orange County, CA
    Sorry for such a large picture.
    I bought the Philips LED fog bulbs from Amazon and I have been really happy with them. More light on the ground and the beam pattern is still nice and sharp.
    *GONE* 2016 S4, Premium Plus, BO Package, DSG, Sport Diff, Daytona Grey, CR-15 Strut Brace, EuroCode AK, 034 Trans Insert, ECS Drivetrain Inserts, 034 Rear Sway Bar, HRE FF01 19x9.5 Wheels, Brembo GT 380mm BBK, EPL Stage 1 & DSG Tune
    2020 BMW M2 Competition, M Drivers Package, White
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by Lbsigman View Post
    How much did they end up costing you?
    Hopefully not the $125 they are currently
    https://www.amazon.com/dp/B00U2NHLTI
    Geoff
    Dec 14 2015
    Orange County, CA
    I paid $125, but I had some birthday gift cards to Amazon so in theory I didn't pay full price.
    Senior Member Two Rings Pawan2013's Avatar
    May 28 2013
    do the b8's throw codes when switching to leds? the b8s always throw codes when switching out the reverse lights whereas the b8.5's dont. Wanna make sure its not the same situation here.
    B8 S4, DSG, Sport Diff, B&O + Nav
    Many Mods
    Jun 20 2015
    NC
    I had VX3 LEDs in my B8 fogs with no codes
    Jul 07 2014
    Calgary, AB, Canada
    Alrighty, got some more pictures in a dimmer environment.
    This picture is with only the fog lights on. You can see that there is no clear cutoff like the incandescent on the left, but it's much brighter.
    This one is with foglights + headlights
    And this one is fogs only, I was trying out the yellow filter on the left fog in both of these.
    I used a proper camera in manual mode and kept the exposure settings the same between the two pictures so brightness can be directly compared.
    I'm pretty happy with these for 45 US dollars. Gonna run them with the 3000k yellow filters for a while and maybe switch them out down the road. Again, no codes on dash for B8.5,
    Nov 28 2015
    Montreal, QC
    happy with the m'auto fanless led. i bought china ebay sh*t and it throw code.. those m'auto are legit.
    S4 B8.5 no track, just enjoying spirited driving.
    Account Terminated Four Rings Pyromatic177's Avatar
    Aug 02 2015
    Corning NY
    I had these on my last car. They were pretty great! But not the cheapest...
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    FWIW
    I'm running LED fogs. M'Autolite Fanless - http://www.hidconcept.com/brands/M%27AUTOLITE.html
    They are very bright. VERY! I've been driving my wife's car with her following me in mine at night and they are almost obnoxiously bright.
    Veteran Member Three Rings ducati's Avatar
    Sep 02 2008
    Greater Toronto Area
    I have a question regarding the led bulbs.If my standard fog light bulb is 55W should I stick with a 55W LED replacement?.
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by ducati View Post
    It doesn't really matter in my experience. Most the bulbs I have tried have been 35W.
    Geoff
    Veteran Member Three Rings eightamrock's Avatar
    Jan 21 2016
    Quote Originally Posted by Pyromatic177 View Post
    I have these now in yellow. Make a note, they fade over time. I ended up doing laminex to keep the yellow nice and sharp. Disappointing for the price.
    '19 Daytona Gray RS5 Sportback
    Options: B&O Sound, Dynamic, Navigation, Black Optic, RS Driver Assist, RS Stitching
    Mods: Suntek PPF wrap
