I have had a no start condition with my 2010 B8 A4 Quattro and the symptoms are always the same. It has been flat-bedded to the dealer (Jack Daniels Audi in Paramus NJ) three times and they have replaced the fuel pump, fuel pump relay, controller and the central computer. The car has 56,000 and all work was under warranty. I have just picked it up again and the diagnosis, after speaking with the main Audi tech support line they had suggested replacement of the fuel pump fuse wire/link.
The no-start symptoms are:
- Car will always start OK from cold. I am in Northern NJ and starting at zero F has not been a problem
- Typically I will drive somewhere, stop and then go to re-start and it will crank and not start.
- The first time this happened was after a two hour drive, then it happened again a month later after driving only 1.5 miles into town.
- The first time it happened it was obvious there was a serious problem and I called AAA for a tow. While waiting I continued to try to start it and eventually it started so I cancelled the tow. I then drove 10 miles, parked, the car started OK and was perfectly good for a month or so.
- Once or twice the car has started and idled very roughly then stalled. Similar to a very bad misfire or fuel starvation problem.
- Twice it has failed after coming out of a restaurant. 30-60 minute drive and 1.5 - 2 hours rest and then it will not start. Both times I waiting several hours to see if the problem would clear itself (as it did the first time) but it did not. The last time it happened I left it overnight and came back to it the following morning. After several tries it did start and I drove it to the flat-bed.
- Several times while trying to start it, the car will continue cranking when my finger is removed from the key.
- Twice it has started normally, and then while I was sat there with the engine idling, the ESP warning light came on, then the TPMS warning light, a warning buzzer and then it stalled and would not run.
I have no confidence that the latest fix (the fuel pump fuse wire) fixed the problem. Everything is OK now and I am continuously going outside and starting it to try and make it fail. I do not want another 110 mile tow.
Questions:
1) Has anyone else seen this or have any idea what the problem is?
2) If this does happen again, is there anything that I should try to do in order to get it started and get another data point? Maybe remove the battery wire and reconnect to 're-boot' the system?
3) Where is the fuel pump relay and the fuel pump fuse wire located on the B8 2.0T Quattro?
Thanks,
Paul
