Results 1 to 2 of 2
    Active Member Two Rings Burrito951's Avatar
    Mar 16 2015
    2001.5 S4, 1986 951, 2002 R50
    Milwaukee, WI
    Broken turbo intake hard pipe/mount bolt
    In the process of changing the engine mounts I broke this bolt. It holds the passenger side turbocharger inlet tube in place.
    Has this happened to anyone else? Any ideas? There's really no room to get a drill in there. I considered a metal zip tie to retain the pipe, but that is kind of janky.
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    I wouldnt sweat it. You ever see what holds Tial inlets on?
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
