Results 1 to 7 of 7
    Active Member Two Rings desireroom's Avatar
    Feb 22 2016
    spain
    butt injection times
    hello, I take time out lol and disappeared. the issue is as follows: injection times by clouds. which components may affect the time of injection? and changed and lambda probe, fuel pump, fuel filter and injectors. What else can I look? coils? plugs? in this image you can see how after an change all that down something.
    Enviado desde mi SM-N9005 mediante Tapatalk
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    butt injection
    What kind of tune does the ecu have?
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Feb 22 2016
    spain
    TLR takes stage 1 sport. engine type is AEB.
    Veteran Member Three Rings Wrath And Tears's Avatar
    Apr 03 2014
    17 GTI Sport
    If you had issues with coils or plugs you would most likely be misfiring and would be able to feel, or see it with vagcom. Might want to log misfires on all cylinders. I assume but don't know for a fact that the ECU would pull timing if it sensed misfires (would make sense if it would).
    I really don't know too much about injector pulse, but I would assume if the car is pulling timing due to misfires, heat soak or what have you, that it would then change the injector pulse to match. You might want to log more data than just the injectors.
    2017 MK7 CSGM GTI Sport DSG
    PP (Golf R Brakes, +10HP, VAQ LSD), LP, Kessey
    LW 17" Sparco Assetto Garra's, 034 Res-X resonator Delete
    Feb 22 2016
    spain
    two of the coils are manufactured. 95 year 280,000 km . I'm hoping to bring me new TFSI. if that gets delays of 7 in the cylinder 3 and also also know that this car does not adjust the injection of a single cylinder (corrects 4 at a time). I also think like you refline 380 and wrath and tears! so here I hope you're right. if you spend some more companion and gives us another point of view it would be good. thank you very much!!
    Feb 22 2016
    spain
    Hi. after changing the coils oem by the TFSI coils audi r8 / vw touareg continues to delay the injection to the fullest. to improved response and recovery but still the same. and things already changed. flow meter, lambda probe, injectors, fuel pump, coils and spark plugs, hoses, valve and valve n75. give me a hand please do not where to go.
    Feb 22 2016
    spain
    no idea?
