Results 1 to 13 of 13
    Feb 04 2016
    London
    OEM vs aftermarket air filter?
    So I was thinking of changing my air filter. Do I just go for OEM or something like a k&n or pipercross etc?
    I keep hearing aftermarket filters kill maf sensors but this could also be down to over oiling.
    Senior Member Two Rings richB7S4's Avatar
    Jul 16 2013
    MD
    Over oiling is the culprit. It is a personal preference. I have run both and the only gain i see is saving money on replacement oem. As long as you let the oil settle and not overdo it, k&n works fine.
    Jun 07 2014
    phila pa
    Quote Originally Posted by richB7S4 View Post
    i agree. i run the k&n in box filter myself in several vehicles.
    Veteran Member Four Rings Terry.Reese's Avatar
    Oct 05 2015
    2005 Audi Allroad 2.7 Biturbo V6, 2000 Lexus 2JZGE GS300 and my old skate board
    Billings, MT
    I ran WIX for a bit and didn't have an issue, but I have changed it up a bit and am making a barrier for my intake tube and filter. so it technically wont be a hot air intake..lol sounds great with what I have, and I have seen a small increase in reaction time with my setup, nothing to marvel at, just a little punchier. with the barrier I am doing it will be insulated as well and i may add a fan inside also.
    Jul 16 2013
    MD
    Looks clean!
    Oct 02 2005
    The Moon
    Unless you have the auxiliary radiator removed any non airbox setup is drawing in hot air, regardless of engine to filter heat barrier.
    To be clear, stock airbox is the best solution. All others reduce power.
    Oct 05 2015
    Billings, MT
    so, why do I see so many builds with them? if the compartment I am building is hindering the airflow similar to the OEM airbox and is insulated, unlike the OEM box, that should help withhold heat temps that rise from the engine.. just wondering, as I have seen lots of funnel filters and heat shield setups online for builds.
    I will still have the inlet from the front letting air into the area I am sealing off as well.
    Thanks
    Oct 02 2005
    The Moon
    Quote Originally Posted by Terry.Reese View Post
    Thanks
    The only builds that have them that work are due to either:
    a.) Auxiliary radiator has been removed
    b.) Car is supercharged by JHM, which in turn removes the auxiliary radiator.
    If someone has an intake outside of those two parameters they are lossing power.
    Oct 05 2015
    Billings, MT
    Ahh, I see what you are saying, Thanks, havent really noticed any power difference on my half yet. but I am not racing it, I have a lot to work to get to that point.
    Established Member Two Rings dmanisgnarly's Avatar
    Nov 05 2014
    Supermotos & Sportbikes
    The East Coast, NC
    I'm doing a fender mounted intake on my setup..what kind of hard pipe it that coming off the throttle body?
    2005 S4//K&N/Pod filter/Carbon MAF extension/APR Carbon NACA ram-air duct/JHM intake-mani spacers/Gutted piggies/Custom Catback/034 Motorsport billet engine mounts/19” Peelers/034 Snub/Neuspeed lowering springs/JHM stage 4 Kevlar clutch/Rallyarmor mudflaps/Rocketbunny V2 front diffuser/canards/HIDs/DRLs/LEDs/trailer hitch
    02' A4 1.8T Quattro
    Oct 05 2015
    Billings, MT
    3.5 inch steel pipe off of a Genesis Sedan 3.8L V6
    Veteran Member Four Rings A4Maine-iac's Avatar
    May 03 2010
    2012 TT Sold
    Maine
    I am happy with my pipercross. No oil to worry about.
    2002 A4 1.8T - sold
    2007 DTM S4 -Sold Sound clip - https://www.youtube.com/watch?v=bGz60n-31jc
    2012 TT - TTS Rear & Exhaust- UNI Stage 1+ " More to come"
    2021 SQ5 - " Just getting started
    Jul 02 2015
    Bermuda Dunes
    AEM dryflo is what I'm buying. I have used their filters on my offroad truck and they flow as good as the k&n, but don't need any oil.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
