Results 1 to 40 of 40
    Jul 30 2010
    Los Angeles, CA, 90094
    Help With Chipwerke Pro
    Hey everyone!
    So I recently just purchased a chipwerke pro from a forum member. It finally arrived today, and I was super stoked to install it. Prior to installing, I called to make sure the program on this chipwerke would work for my car, and the customer service people said that it would, I would just need to change settings from 6-1 to either 5-1 or 3-1 (no 93 octane in CA).
    I turned the settings down and installed it. However, when i start my car, it will rumble for a little bit, and then shut off itself.
    Has anyone heard of anything like this? I tried multiple settings, and all produced the same result of rumbling a little bit, and then shutting off.
    Jun 11 2014
    Ny
    Make sure everything is installed properly.
    Veteran Member Four Rings ModItNow's Avatar
    Mar 05 2015
    Exway x1 pro
    Bay Area
    I have the chipwerke also in California on 91 octane. 3-1 setting is perfect. Make sure you only changed the dial on the left side, the one on the right should remain at 1. I would also reset your ecu and if the problem still happens I would send it in and have the company look at it.
    Sent from my SM-G925V using Audizine mobile app
    Jul 30 2010
    Do I just reset the ECU by unplugging the battery and leaving it over night?
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Quote Originally Posted by Goodforyou19 View Post
    yes
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Veteran Member Three Rings Jflow23's Avatar
    Apr 10 2007
    2014 S4/2009 Q7/2022 Model Y
    Beaverton OR
    If you have VCDS, you can just clear codes on the engine...same effect
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    I also installed mine temporarily last night and drove it for about 20 minutes. No idea what the setting is on as shipped, but I had no issues at all with stalling or shift lag. It got too late to scan the car for codes with my Vag-Com but once I do, and as long as they are clear, I'll finish zip tying the whole thing in.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Jan 28 2015
    BMW 435i Grand Coupe 2015
    Melbourne, Australia
    I don't have a chipwerke but have the racechip version. I had issues when I first installed it and whilst my car didn't shut off, I had the car idling rough and also experienced shift lag. Their customer service is really crap to say the least and i ended up working out the issue myself. I had accidentally reversed the plugs, so please check your pin configuration it should be labelled 1,2,3 etc. so make sure all the pins lined up in order. Once I had the right pins lined up everything worked well...
    Jul 02 2013
    As I mentioned previously, I installed mine Tuesday night. I went in tonight and ran a scan with my Vag-Com. Found the following code:
    1 Fault Found:
    9605 - Manifold Pressure / Boost Sensor 2 (G447)
    P0240 00 [032] - Implausible Signal
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 94129 km
    Date: 2000.00.00
    Time: 00:00:00
    I opened up the chip box and saw that it was sent with the settings set to 5-1, which seems high to me, even if running 93 octane.
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    check all connections, even the one at the box
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Veteran Member Four Rings Dannydyn's Avatar
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by sacandagaD View Post
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 94129 km
    Date: 2000.00.00
    Time: 00:00:00
    5-1 is the recommended setting for octane 93. As for the fault code, you either have a loose connection, a bad connector, or a faulty box.
    2014 S4 | 6MT | Estoril Blue | Lunar Alcantara | Rotors
    AWE S-Flo | Bilstein B8 | H&R OE Sport | RS4 Grille | 35% Tint
    Jul 21 2004
    South Florida
    Quote Originally Posted by Dannydyn View Post
    Yeah, the code is showing that your bank 2 map sensor is not connected. So as stated by danny, you either have it not connected all the way or correctly, a broken map sensor (on the car) or map sensor connector (on the CW harness), a short in the CW wiring harness, or a short in the CW box/connector to the harness. Somewhere it is not connected.
    Mike
    2018 Audi S5
    Gone-
    Jul 02 2013
    Quote Originally Posted by bhvrdr View Post
    Mike
    Thanks Mike and Danny- I will reinstall it again tonight and scan after a run to see if that is the problem and go from there. It is possible that I may not have had the locking clip all the way down on one of the sensors.
    Veteran Member Three Rings chopz33's Avatar
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    for those that have the CW pro, is it comparable to Stage 1?
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by chopz33 View Post
    I had the Chipwerke 'S' (not the pro), and now I have EPL Stage 1, and I can say that the Chipwerke 'S' torque output is similar to Stage 1 except that the transition into the higher torque output of the Stage 1 tune is smoother than that of the Chipwerke box.
    SOLD 2015 Daytona Gray S4
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    Quote Originally Posted by SteveYem View Post
    thanks Steve, im in the process of reading the 75 page thread...been on the fence about this for a few weeks. my car is now out of warranty so looking at options
    Mar 21 2015
    Chipwerke shouldn't be an option if you're out of warranty.
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    Not sure I'm following. I don't track my car, just want to get a few extra horses and don't really want to spend $1200 on a tune.
    Sent from my LG-H820 using Tapatalk
    2012 S4/ Prestige/ Black Optics Package/DSG/Red Leather/B&O sound
    KW HAS/RS4 grille/LED conversion/USP Intake/AWE Touring-resonated DP's/034 trans mount/Niche Stacatto 20x9/CF Stvbek front lip/Unitronic Stage 2 ECU/TCU/ECS CF diffuser/CR-15 Strut brace
    Mar 21 2015
    You're following, EPL for almost half that price. Flash from home too. If price is the issue then I see what you mean but I wouldn't even waste my time with the CW if you're out of warranty.
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    gotcha, now im interested in the EPL. Website seems to be non existent.
    Dec 20 2013
    Mercedes Benz ML350
    I did a few pulls against my pal who's running EPL ECU/TCU tune stage 1.... 3 runs from roughly 50mph, and I had about a 1/2 car lenght on him.
    Mar 21 2015
    It is non existent, there's a couple threads on them, here's one.
    http://www.audizine.com/forum/showth...cussion-Thread
    Senior Member Three Rings dluxxx's Avatar
    Mar 13 2013
    2016 Porsche Cayenne Diesel
    Nor*Cal
    I was on the chipwerke pro in CA and i ran 4-1 no problem. Thats what murat told me. So if you want a lil more umph on CA 91 octane bump it up to 4-1.
    2010 A6 C6.5 3.0T, Remus Mufflers w/ Quad tips, Magnaflow Resonated X-Pipe, RocEuro Intake, EPL Stage 1, Transparent Gloss Copper Verde Axis V99 20x9, Michelin Pilot Sport 4S 265/30, Bilstein P14 PSS Coilover, H&R Rear Sway Bar, Ultra Racing Front Lower Brace, Ultra Racing Center Lower Brace, RS6 Black Gloss Grill, Rear diffuser, Black Vinyl window trim, Smoked Rear Tailights, Complete Interior LED Lights, Blacked out front sidemarkers, Morimoto 5000k D3S bulbs, SB3 Alpha Ceramic Coating.
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    is this a good deal considering the CW pro is $400?
    this is the deal EPL just sent me
    stage 1, DSG TCU tune and the flashing cable for $1550 shipped ..seems steep to me
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    I got to witness that. Chipwerke looks impressive.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Mar 21 2015
    You didn't say anything about the tcu tune before, you can look around for a cable used here on AZ. One popped up the other day. I think you get a better deal if purchased together instead of separately.
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    Ok thanks for all your help
    Mar 21 2015
    ^ In my opinion that 1550 is worth it compared to apr's price. TCU tune is nice also.
    Apr 05 2016
    Portland, OR
    Honestly it really is not.
    Compare that to an APR or other competitors tune where the TCU tune alone costs $1000 + the $1200 or so for stage I.
    If you don't track your car and are not interested in the higher LC limits and better shifting you could get by just fine with only the ECU tune.
    Would knock the price down to ~$1,100 or so I would guess.
    Geoff
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    here is the offer my local Audi shop just quoted me. APR retailer
    Stage 1 is $1,299.99
    Stage 2 only requires the pulley to be added to your existing supercharger, an additional ECU flash (at no charge,) and you're good to go. ($2300 for parts and labor from stock to stage 2, this includes stage 1 and is the best money saving option
    There's also a TCU tune that offers launch control in addition to a multitude of fine tuning to the transmission software. It's $999.99
    Mar 21 2015
    Quote Originally Posted by whiped View Post
    ^ You don't think 650$ savings is good compared to that apr price? I agree with him probably not needing the tcu tune. With a little patience he might find a used tune and cable for sale.
    - - - Updated - - -
    You're really heading way north of price range here, lol
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    Lol right. I got carried away
    Apr 05 2016
    Portland, OR
    I was saying that the price was not that steep.
    I do think EPL is a great deal and personally I would much rather go with a proper tune over the CW.
    Geoff
    Mar 21 2015
    Ok, I misinterpreted your statement, lol. I agree with the tune over CW especially out of warranty.
    Jul 02 2013
    UPDATE: Reinstalled everything making sure connectors were locked down, scanned clear after install, ran 20 minutes hard, scanned clear again afterward. Butt dyno seemed to indicate it ran stronger above 4500 and shifts were all smooth.
    Just wish it made for a little neater install under the hood, I mounted the chip box in front of air box near headlight, and zip tied the wires everywhere.
    Jul 31 2007
    Boston
    $1550 is an epl stage 1 tune, cts intake and dsg tune. Stage 1 and the intake is $1050. without an intake your looking at ~$850
    Mar 21 2015
    Quote Originally Posted by beans912 View Post
    There ya go chopz.
    Feb 08 2016
    2018 A3 Cabriolet
    Coppell, Texas
    My thoughts exactly. I don't need the intake
    Senior Member Two Rings dyl0n's Avatar
    Dec 14 2014
    New Orleans, LA
    get a real ecu tune
    B8.5 S5|P+|DSG|Sport Diff|APR Stage 2+|APR Stage 2 Intake|ST Coilovers|20x9.5 RS5 OEM Rotors|AP Racing 370mm BBK|Pirelli P-Zero 275/30|Ecodes|B&O
    AWAITING BOOST SEASON
    Mar 21 2015
    Just realized we derailed this thread abit, lol. Sorry OP
