Results 1 to 6 of 6
    Apr 08 2012
    Wisconsin
    Replace Disc Brake Wear Sensor
    I put new front brakes on my 2010 A4 a few months ago. My dash warning light came on recently. I took off the wheel and found that the brake wear sensor wire had been severed where it connects to the plug.
    So, the brakes and pads are fine. I just need to fix the wear sensor. I bought this replacement wear sensor wire.
    My question is, can I just yank out the old sensor from from brake pad? How do you do that? Will it just pull out with needle nose pliers? Should I pry it out with a screwdriver?
    Or, will it be easier to cut the wires (on both the sensor wire coming out of the pad, and my new sensor wire) and connect them together, leaving the end in the brake pad?
    Any tips will be appreciated. Thanks.
    Sep 09 2010
    Destin, FL
    Quote Originally Posted by Tba5 View Post
    It pulls out with pliers and the new one pops back in, pretty easy.
    Jan 24 2012
    Tucson AZ
    I'm curious if there is a way to code out the brake pad light via Carista. I have switched to a BBK, and rather than tie a sensor to the tie rod, I'd rather code it out. Thanks for the help!
    Junior Member Two Rings
    Jan 26 2016
    Auburn hills, MI
    Quote Originally Posted by hanyoung View Post
    Would also like to know.
    Veteran Member Three Rings Townending's Avatar
    Aug 29 2014
    Claremont, CA / Big Bear, CA
    I've seen the option for that in VCDS, but no idea about carista.
    2009 BMW E92 M3 - SilverStone II - Full IPE F1 Exhaust - Stage 2
    2013 A4 Quattro - Moonlight Blue
    Mods : APR K04 E85 - Solowerks S1 Coilovers - Treadstone TR8 - RS4 Honeycomb Grille / Foglight Grilles - ECS Intake tubing - Hardwired Valentine 1
    034 Motor Mounts / Tranny Mount + Insert - ECS Rear Diff Mounts + Insert - Alzor Style 349 Wheels 19"x9.5" ET 40 - 265/35/19 Michelin PSS - VAGCOM Mods
    Veteran Member Four Rings bakedziti's Avatar
    Oct 23 2014
    Buffalo, NY
    No; at least not in the beta.
    Honestly, I can't recommend Carista anymore. Support has gone down the tubes, and usability with an iPhone and the pay-per-use feature makes the $349 for a Ross-Tech super appealing. This is really a post for the Carista thread, but I have been trying to get my inspection service due light off for weeks, and have been contacting Support for, well support, but am always told to submit feedback within the app. I can't submit feedback when something suddenly went missing from a menu, not to mention that the Tools menu doesn't offer a feedback option.
    1999 A4 Avant | Cactus
    2001 S4 | Silver | 6MT
    2021 Porsche Macan Turbo | Carrara White
    Sold: °2014 S4 | MGM | 6MT | ABG | ACC | ADS | AFS | ASA | B&O | MMI | Sport Diff | 034 DP 57/187 | 034 Adjustable UCAs, Toe Arms, Front + Rear Endlinks | 034 LCAs | 034 Strut & Engine Mounts | 034 Trans Mount + Insert | AWE Touring + Res DPs | Bilstein PSS10 | CR15 | G5-r | H&R Sways | Merc HX | P3 | Ringer S3+ Clutch & FW | ECS AK
    °2011 A4 | 6MT
