Results 1 to 9 of 9
Thread: Overheating
    Established Member Two Rings jesse_gabriel's Avatar
    Dec 09 2015
    california
    Overheating
    My a4 1.8t is overheating and I'm not really sure where to start, if I leave the car stationery and even rev the engine, it's fine but when I'm driving the temperature will shoot up very very fast probably all the way to Max in about 10 seconds but it will also go down again. It's very inconsistent, Amy ideas?
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    You can check the thermostat
    Try not to drive it around if it's overheating. You'll warp the head.
    how many miles on it ?
    Audi Club Bay Area
    Dec 09 2015
    california
    165,000 miles
    Established Member Two Rings andrew96's Avatar
    Jan 05 2015
    Annapolis, MD
    I had a similar problem. First my waterpump then a defective thermostat. Do you still have heat?
    Mar 28 2015
    1987 Dodge Raider G54B Turbo
    Portland OR, United States
    Quote Originally Posted by jesse_gabriel View Post
    A ten second temperature rise seems strange, although with the factory gauges nonlinear response, I guess its possible. I would double check to see if the motor is really getting that hot, or do you have a bad temperature sensor.
    Senior Member Two Rings G-Ride's Avatar
    Dec 16 2008
    Imola 2003 A4 1.8TQ 5spd
    Melbourne Australia
    Is it spitting coolant back out through the overflow on the expansion tank at all? Any heavy pressure build up in the upper radiator hose?
    Imola Yellow '03 A4 Quattro 1.8T 5 Speed
    :: Motoza Performance Tuned on e85 ::
    : Frankenturbo F21-L : Bosch EV14 750cc Injectors : 3" MAF : Milltek Turbo Back Exhaust : AudiSport Suspection : ER FMIC : Sachs RE Clutch : TyrolSport Brake Kit : StopTech & Ferodo DS2500 : Goodridge SS Lines : Forge 008 : 034 SD Engine & Trans Mounts : Apikol Snub & Rear Diff Mount : Podi & VEI Digital Boost Gauge :
    Dec 09 2015
    california
    I haven't tried the heat but I wil tomorrow. And the engine is definitely getting hot, the first time I noticed it there was already coolant coking out of the overflow.
    Mar 28 2015
    OEM water pump with a loose impeller?
    Dec 25 2004
    Earth
    Take it to a mechanic who knows Audi and can fix.
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
