Results 1 to 16 of 16
    Veteran Member Three Rings xthealienatorx's Avatar
    Mar 01 2013
    10 Avant, 03 Superduty 6.0 zf6, 13 Grand Cherokee Overland Hemi
    Louisville, Kentucky
    Project Time! AEB RWD Track Car
    Hey All, Time for another project! Im still building my AWM Exo car but time is really limited and im waiting to get a few parts made to start fabing the third dimension of the frame. I recently wrecked my dd and tore up the bumber and headlight, quote was 2200, insurance gave me 1300, and i figured i could fix it for about 300. I recently came across a 99 a4 1.8t 5 spd swapped rwd for 300 with a good bumper and headlights, so free car right?? I fell so. Car doesnt have a title which is why im considering it a track car. Came with a gasket set, valves, test pipe, jhm short shifter, ie manual timing tensioner, a bunch of extra coils, and three extra turbos (one with minimal shaft play, others dont spin). Body is supper clean.
    List of things i need to get it running:
    Vacuum Lines, Coolant lines, Wire Harness put back on, exhuast, ac compressor mounted back, interior stripped, clutch bled, intake, and a starter.
    Now for the ecu, ive got one from a auto aeb, and one from a manual aeb. Im assuming all i need to do is run the manual ecu and itll work, however, id like to do my own tuning to make a little more power, ive been looking into doing it on a me7.3 ecu, but i dont believe these are me7.x, can i run my awm ecu on this car can be okay??
    Also, Im not familar with the aeb, What goes here?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Will take a lot of work to run the AWM ecu.
    Considering the status of the car, I'd just run the auto ecu as is. There will be tons of codes but not like it matters. I dont think the enigne will have any trouble with it.
    I think this is a cool idea. For $300 why not? Better than hauling to the scrap yard
    Last picture is for the block breather. Just run a hose to the ground for venting.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Oct 24 2013
    girls MK4 1.8t
    United States
    you can just use the manual AEB ecu and be fine, they dont have immobilizers or anything. It also takes less than 5 minutes with vagcom to make the ecu from auto to manual and vice-versa.
    the AWM ecu/dbw conversion is not that hard and is worth it.
    idk what the process is like in your state, but in most states, it is not that hard to get a new title issued.
    I am all for your project, I like rwd b5's
    Stupid drift A4
    R.I.P RWD-converted '99 A4 Avant 1.8T
    Veteran Member Four Rings xdewaynex's Avatar
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Lucky ass, youre the one that was buying that car today. I messaged the seller last night about it, because I was wanting the engine to a build on. $300 was a steal just for all of the extra parts and JHM short shifter.
    1998.5 A4 1.8TQM My Build
    Veteran Member Four Rings Mattr567's Avatar
    Mar 20 2016
    1989 Honda CB-1, 1986 Suzuki SP200
    What a steal.
    FWD in the tradition of AutoUnion
    99.0 B5 A4 1.8TMS
    I turned a $750 car into a $10,000 car worth $2500
    Mar 01 2013
    Quote Originally Posted by xdewaynex View Post
    Ha, yep, I couldn't belive there wasn't more interest. I went and looked at it about an hour after the post I couldn't resist.
    Sent from my SM-G920T using Tapatalk
    Mar 01 2013
    Quote Originally Posted by garytightpants View Post
    Do you know of a write up on the conversion?
    Mar 01 2013
    Good surprise today when I took the wheel off to get to the starter, the Cmcar has sport suspension!
    Been wo4king on it for about 3 hours and feel like I'm pretty close to being able to start it. Check the timing for interference, good. Checked the plugs, good. Checked the pistons with anew inspection camera for valve hits, good. Got the starter on, just need the signal wire. Just put the harness in and I believe it is still an auto harness as it has the d connector with the speed sensor connector.
    I'm having to pull a few to many parts from my parts car for my other project, but oh well.
    Mar 01 2013
    Hey guys, got it stripped today and the engine pretty much back together other than cooling and the bottom crankcase breather.
    I need help though, I can't find the starter signal wire in the harness so I figure I just bypass it to a momentary switch. When I hit the switch it just clicks twice and then does nothing for a few minutes, when we first did it there was a big spark. What could it be????
    Mar 01 2013
    Figured it out, had a few loose grounds and missing the air intake temp sensor.
    It's nice and throaty with just the down pipe.
    Mar 01 2013
    Hey, I sent you a message.
    Aug 23 2011
    Erie
    Keep it up!
    Mar 01 2013
    Update time! The weekend of my last update I tried to drive it for the first time, to here this ridiculous knocking, to find out the back of the driveshaft wasn't hooked up. I got that hooked up last weekend and put some coolant in and she drove! I massive amounts of smoke but I didn't really care as it was driving (in the yard...). After I parked I found all of my coolant spilled out on the driveway. So that was my project for this weekend, found a total of 5 leaks from missing seals and clamps, and one crack. It was also missing a thermostat. It's times like these I'm glad I have 3 parts cars. I had to make a heater core bypass to fix the problem of not having a heater core and one of the plugs was cracked.
    Also added a bit of exhaust from a fwd passat back to the center of the car, mad it a tiny bit quite but not enough, now to do a full system with one of my extra borlas I have laying around. Also cleaned up the wiring on the passenger side of the car, a little nervous to pull the driver side as there are probably some relays I need.
    But yeah, she drives, and one wheel peels like no other.
    Mar 01 2013
    So, I realized last night when I was packing up I pulled all the wires for my windows.... and they where down.. Great. Now to put the wires back in or run my own to switches in the center.
    Also, I heard that possibly the v6 diff rear diff is somewhat locking? Any truth to this? I've got a 97 2.8 parts car. The one wheel peel thing is kinda confusing to me as I can get all 4 off my wheels on my daily to slide no problem, but again, it's a 2.8, but I didnt think there was a difference across the diffs. Other than gearing.
    May 24 2009
    98.5 A4 1.8TQM
    Danville, KY
    Nice to hear that its running and nothing is wrong with it. Still jealous of the deal you got, haha.
    Veteran Member Four Rings ray4624's Avatar
    Nov 27 2010
    mass
    Quote Originally Posted by xthealienatorx View Post
    if you want a rear LSD you are going to have to put one in unfortunately.
