Results 1 to 30 of 30
    Oct 06 2015
    SQ5 APRs Stage 2 claims on 3.0T tunes seem questionable
    All,
    I'm looking for some feedback from the community on people who have actually run DYNO's on the SQ5s after a Stage 2 upgrade.
    First I want to start this thread off by saying "I AM NOT A DYNO EXPERT". But I have spent some time around Mustang and Dynojets to at least understand how they work. So I just spent about 2 1/2 hours at my local Dyno shop who has a really nice Mustand Dyno system. Additionally I'll say I have a '16 SQ5 with a Roc-Euro Intake and AWE full non-res downpipes Exhaust system. After the parameters for the system where inputted like we set the max rpm in the system to 6500 based on Audi's website, but then found out APR has their system set to 6900, but not sure this matters for us US folks as I found out another tidbit from APR techs that was interesting (i.e. a SQ5 in the US even with a APR tune done still will not let the car max out to 6500 when shifting EVEN in manual mode, yes how crazy is it that even with the APR Tune the system still has a fail safe to shift at 5000 rpms).
    The other issue is Audi posts that the 1:1 ratio is at 6th gear, which seem to be fine, but APR tech couldn't confirm this on their side in their tests done. Actually waiting on the tech to email me APR's actual dyno test information.
    I am not totally oblivious to marketing claims as I work for a manufacturer myself and we post marketing claims on many of our products which are not always what happens in real life, BUT I really wonder how APR got some of it's claims of i.e. 463 HP, which in their caveats it states at the crank. Interesting how APR though shows they where able to get a '15 SQ5 to 6900 rpms when there wasn't anything we could do at my dyno testing to get to 6900.
    So here is is what I do know, based on my sheet below you can see after a Stage 2 APR tune was done I may be able to see the LB-TQ close to 400, but the HP is still VARY lacking.
    Mustang Dyno (PEAK TORQUE at rear wheel is 331 lb-tq @ 6077 rpms) - converted to crank using a conversion tool says around 397 lb-tq (which seems to be in line with APR's claims on the website)
    Mustang Dyno (PEAK POWER at rear wheel is 334 HP @ 5998 rpms) - converted to crank using a conversion tool says around 400 HP (which is pretty far off from APRs claims on the website of 463 HP)
    Now to be a little fair I did even convert to a DynoJet system to compare, which most will know runs about 11% ish higher then Mustang's System.
    DynoJet conversion (PEAK TORQUE at rear wheel is 367 lb-tq @ 6077 rpms) - converted to crank using a conversion tool says around 438 lb-tq (which seems to be in line with APR's claims on the website)
    DynoJet conversion (PEAK POWER at rear wheel is 370 HP @ 5998 rpms) - converted to crank using a conversion tool says around 442 HP (which is MUCH closer to APRs claims on the website of 463 HP)
    With all that being said here is the data from my Dyno.
    APRs Claims:
    Lastly, a little AWE love from that awesome sounding exhaust they have:
    Senior Member Three Rings rgvsq5's Avatar
    Feb 03 2015
    Texas
    In order to be able to shift at 6900 RPM... You have to disable auto-upshift via VAGCOM and even then can only rev that high when shifting manually. It works, I've done it.
    As far as HP numbers are concerned, I've never dyno'd my SQ so I can't comment on that. However I have a best 0-60mph of 3.97... So there's power coming from somewhere that's well above and beyond what these things put out stock. :D
    SQ5 | APR Stage 2+ : APR CPS v2 : AWE : Bilstein : H&R : ECS Tuning : 034Motorsport : P3Cars : Adam's Rotors : E-Code : XPEL
    Veteran Member Four Rings zcspec's Avatar
    Aug 10 2015
    Need VAG-COM work, IM me
    Orange County
    Gasparm, I personally don't own a SQ5 so I will ask you this, what transmission does your SQ have? Is it the ZF-8 like my 2015 allroad? If so, the APR tech you spoke with, *may* have forgot one small detail regarding the transmission's willingness to auto-shift, even in manual mode.
    Take a look here: http://www.goapr.com/support/zf8upshift.html
    When this feature is enabled in my allroad, the transmission auto-shifts around 5800 rpms. When I have the feature disabled, I am able to rev up to about 6200rpms. Again, I don't know which transmission your SQ has, but look into this feature if you do have the ZF-8
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    Don't put too much stock into the numbers, they don't hold much value without a baseline. These readings are best used for comparing cars only on that same dyno, as calibrations vary between different dynos, not to mention temperatures, other environmental conditions, etc. Also, the DynaPack dyno (which APR uses) reads high even compared to a DynoJet.
    Next; already mentioned but to shift at 6900, you need to disable auto upshift in manual mode with VCDS. The car keeps gaining power as it revs, so this hurt you slightly.
    Select control module
    Select Auto Trans
    Select Adaptation
    Load Automatic Upshift from the dropdown
    click "not active"
    Hit Do it
    Hit Yes
    Hit no
    Here it may say it was not accepted. If that's the case, hit OK.
    Hit Yes this time around for using the default values
    It should accept it.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Jun 12 2015
    CA
    APR claims 463hp at 6900. It looks like they claim about 445hp at 6500. If you're using APR's latest SQ5 Stage 2 software, you need to go into VCDS to disable auto-upshift in order to rev to 6900 in manual mode. Whomever at APR told you that you wouldn't be able to do that as a US Audi customer is sadly uninformed. Dozens of guys on this board so this all the time.
    Oct 06 2015
    Quote Originally Posted by zcspec View Post
    I do believe the SQ5 is the 8speed. And that link and from what "rgvsq5" says seems to be inline that I will have to go in through vagcom and disable the autoupshift. Dang it. Great find.
    Oct 06 2015
    Quote Originally Posted by colby7 View Post
    Thanks for the insight. Agree'd he should have mentioned the auto-upshift thing.
    - - - Updated - - -
    BTW, this is WHY I LOVE THIS FORUM. You all are so great and damn quick on the information.
    Apr 26 2014
    2012 R8 GT; 2016 SQ5; 2017 Q7
    DFW
    I have a '16 SQ5 with APR stage 2-93, NRDP, 034 intake hose, and auto up-shift disabled. I use the JHM pulley and stock SC pulley. I had it on a dyno Saturday and it was producing 454 HP (crank) at 6500 RPM. I do not yet have the other details as their printer was down and they still haven't emailed me the PDF they saved.
    Veteran Member Three Rings rusq5's Avatar
    Mar 27 2015
    SF Bay Area
    Quote Originally Posted by SQive View Post
    What was your whp and what are you using for drivetrain loss?
    I'm interested in seeing a stock vs apr stg 2 dyno from someone other than apr.
    -Rusty
    2022 RS6 Deep Green/Cognac
    2019 RS3 Nardo/RS Design
    IG: @grn_rs6
    Apr 26 2014
    DFW
    Quote Originally Posted by rusq5 View Post
    As I said, I'm still waiting on the detailed report. They had it set to account for parasitic loss with a calculated crank value. It was consistent on all three runs 451 to 454 HP. I'll share that report as soon as I have it.
    Veteran Member Four Rings riceboy22's Avatar
    Mar 26 2015
    2015 Audi SQ5, Felt F65x, Levy Electric Scooter
    New York, NY
    I've got some bias here admittedly, but just curious why it seems like some people are implying that APR isn't delivering (potentially compared to other tunes). I've personally only got my butt dyno so far, but in looking at the AudiRevolution 1/4 mile list for the S4 3.0T, the fastest cars are a pretty even mix of mostly APR and GIAC Stage 2 cars. That would suggest to me that they are likely putting out comparable power on their 3.0T tunes.
    Also, +1 to what @LINDW4LL said as far as dyno numbers not meaning much without some sort of baseline comparison. There are way too many variables in play.
    Current
    2015 Audi SQ5 3.0 TFSI (Build Thread | Flickr | Instagram)
    Past
    2006 Lexus IS350 | 2001 Audi S4 | 2000 Honda S2000 | 1999 Yamaha YZF-R6 | 1995 Acura Integra GS-R
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    Quote Originally Posted by gasparm View Post
    All,
    I'm looking for some feedback from the community on people who have actually run DYNO's on the SQ5s after a Stage 2 upgrade...
    Question: Why should anyone care what a dyno reads? The delta in measured performance is the only data that matters in the real world, 'cause nobody drives dynos...
    Just sayin'...
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Oct 06 2015
    Quote Originally Posted by zcd2.7t View Post
    Just sayin'...
    I'll agree to disagree. Getting a dyno done after you get a tune done in my opinion keeps the manufacturers semi-honest about what they publish. Most educated buyers don't buy blindly hoping for the sake that the manufacturer isn't screwing everyone. I did the dyno to see how close it was to APRs published numbers and nothing more to give back to the community when others are trying to do an educated purchase on such a product.
    Mar 26 2015
    New York, NY
    I definitely appreciate seeing dyno numbers, but I think the point is that dyno numbers without context only mean so much. You really need to have a stock run and a tuned run on the same dyno in order to determine if the tune is doing what it's supposed to do. If a stock SQ5 put up 354 on that dyno and stage 2 only put up 400, then I think there are some legitimate questions that could be asked. If it only put up 310 on that dyno stock, then 400 tuned looks a lot better. It would probably also be helpful if you have some logs of things like timing, boost (spec/act), IAT, etc to ensure that nothing whacky is going on with your car.
    In terms of APR delivering, I think the posted 1/4 mile times for 3.0T cars suggests that the APR tune is at least in line with what other tuners are producing.
    Current
    Past
    Mar 13 2013
    Chicago Western burbs, Il
    Quote Originally Posted by riceboy22 View Post
    Well said! completely agree.
    '21 Atlas 2.0 AWD, Stg1 93/Stacked JB4 E25, Eibach Springs, AFE Catback
    '18 mk7.5 Golf R STG 2 E30, TCU, IC, Milltek DP/HFC, AW SwitchPath
    '12 Golf R APR S2 93 HPFP W/iABED RCF, IC, UM Haldex, Milltek HFC, SMF STG2, Fluidampr, RVC, PSS10, PolarFis
    '08 R32 UM ECU/DSG, Schrick 268/264,Milltek Headers/HFC, Corsa Catback , RNS 315/RVC, PolarFis
    Jun 12 2015
    CA
    Also, please keep in mind a dyno is about so much more than peak numbers. For example, I'd gladly trade a tune that's 30 hp below an advertised peak, in exchange for one that has a super flat curve.
    Oct 06 2015
    Quote Originally Posted by tmoe View Post
    I'd agree with riceboy22 also. I have to go back and get the tune removed and run it again for sure for an accurate comparison. Good thing Eurotech and the Tune place are only about 20min from each other.
    Mar 26 2015
    New York, NY
    I love area under the curve!
    Or we can all go to a test and tune in the 1/4 mile at Island Dragway lol.
    Edit: You should also try and get a hold of a laptop and cable to take some logs while you're on the dyno.
    Current
    Past
    Oct 06 2015
    Or you could come out to Englishtown, NJ on July 16th & 17th for Waterfest which allows us to enter the Drag racing.
    Jan 19 2010
    MI/CA
    ...You really need to have a stock run and a tuned run on the same dyno in order to determine if the tune is doing what it's supposed to do...
    This, exactly.
    Jan 19 2010
    MI/CA
    ...I did the dyno to see how close it was to APRs published numbers and nothing more to give back to the community when others are trying to do an educated purchase on such a product.
    OK, but you didn't really prove anything, other than your run didn't show exactly the same results that APR's runs did, which is what EVERY dyno run ever run shows, basically.
    Measured performance is the only proof that matters - no bullsh*t conversion factors, or statements like "...everyone knows that this dyno reads this much higher than that dyno" (seriously?? everyone knows this?? and it's been scientifically proven and verified? Yougottabekiddin' me...)
    Nevertheless, if it makes you (and anyone else) feel better about your purchase, knock yourselves out.
    Oct 06 2015
    Anyone in the Lower NY / Upper NJ area with a stock SQ5 willing to get a DYNO done? I'll pay.
    Jan 19 2010
    MI/CA
    Baselining someone else's car won't really prove anything, either...
    Dec 10 2011
    CLT | MKE
    I disagree. Stock SQs should be extremely close to each other on the dyno. It will serve the general purpose here.
    -Hayden
    Oct 06 2015
    Move along TROLL move along.
    Mar 26 2015
    New York, NY
    Waterfest is a little too crazy for me to try to get in any runs there. I'm going to try and get in on a track during a slower night.
    Move along TROLL move along. [IMG]http:/
    I don't think @zcd2.7t is trolling you. He's maybe being a little rigid because of your original post. In an ideal world, you'd do a baseline run stock and then subsequent runs under various states of tune with identical conditions. The reality is that's not generally practical or doable. If you can get a stock SQ5 on that dyno with similar conditions that should be good enough. You really should be logging at the same time though to make sure there's no underlying issues.
    Current
    Past
    Jan 19 2010
    MI/CA
    Move along ...
    Oh, right - I see - you don't like someone point out the relativie inanity of your actions - too bad. I've been here on AZ 5 years, and an Audi owner for 17 years, and am not trolling.
    You're the one who started a thread questioning a tuner's products and/or claims with essentially zero valid data to back up your post. Might want to look at the definition of "troll" to see if it fits who you see in the mirror, rather than pointing the finger at someone you don't know who has done nothing wrong...
    ...In an ideal world, you'd do a baseline run stock and then subsequent runs under various states of tune with identical conditions...
    Not in an ideal world, but if I were to post questioning the validity of a tuner's claims, I'd sure as sh*t make sure I had actual, valid data to back up my assertions. The OP's post doesn't. It's that simple.
    Oct 06 2015
    Well if you want to ever meet up or hang at the Bear Mt. Car Show that is every Wed night let me know. Would be cool to hang with another SQ5 owner.
    As for the other note, I called it for what I believe it to be. Everyone so far minus him has actually posted useful or constructive feedback, none of his was either.
    Jan 19 2010
    MI/CA
    Quote Originally Posted by LINDW4LL View Post
    If by "extremely close" you mean within 20-30 hp of each other, I'd agree, but the delta for the "fail" the OP is suggesting is about that much, so it really won't be valid for the OP's purposes, at least as he's explained them.
    Jan 19 2010
    MI/CA
    ...Everyone so far minus him has actually posted useful or constructive feedback, none of his was either.
    Oh, so when I suggest the same as other posters (that what you presented doesn't really prove anything without a baseline to compare it to) it's trolling, but when others say the same thing, it's not.
    Right - gotcha.
