Results 1 to 14 of 14
Thread: Launch Control
    Established Member Two Rings s3_ernie's Avatar
    Apr 11 2016
    E30 Vert, Ruckus, Volvo XC40, Harley StreetGlide
    Lincroft NJ
    Launch Control
    So dynamic, sport, hold down traction control button til everything turns off, left foot on brake right foot on gas, car only revs to 2 grand than bogs down.
    Is it because the car is 100% stock?
    Jan 12 2016
    Los Angeles, California
    This has nothing to do with the fact that your car is stock...
    You must be really stepping on the brake to get it to work. You must put a lot of pressure on the pedal, then mash the accelerator, let it get up to around 4000 then let it rip.
    I personally keep it in manual, but I'm sure you will get faster times in automatic
    2016 Monsoon Grey S3 P+ w/ BO, Resonator Delete, AWE Resonated Catted DP, Unibrace UBQ, 034 Rear Sway Bar, 034 Dogbone Insert, 034 Rear Subframe Inserts, 034 P34 Intake, CTS Turbo Inlet, ED Springs, Eurodyne ECU and TCU
    Aug 06 2012
    san diego
    for me its just. put in s mode, turn off traction, full brake, full gas, revs bounce at 4k, release brake
    make sure the oil is at normal operating temp. and make sure the wheel is not turned.
    you can launch in comfort mode so long as s mode is engaged
    Apr 11 2016
    Lincroft NJ
    Quote Originally Posted by KevinM. View Post
    That was the difference. Guess I wasn't pressing in the brake hard enough. Thanks.
    Quote Originally Posted by markn1689 View Post
    Can I see the oil or water temp in the obc?
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    ya, you'll have to go to the "lap timer" in your info screen.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Senior Member Three Rings Speedybrit's Avatar
    Apr 15 2010
    Quote Originally Posted by diztek View Post
    Or you can enable oil temp in DIS via vagcom
    Current Cars:
    2016 Sepang Blue S3 - Tech Pkg, Black Optics, B&O - Eurodyne Stage 2 ECU/TCU (Crackle Tune), Resonator Delete, CTS Intake, CTS Turbo Muffler Delete, CTS Turbo Inlet, USP Downpipe, APR Roll-Control Springs, APR Rear Sway Bar, and PowerStop Z23 Brake Kit
    Past Cars:
    2013 Monsoon Gray B8.5 A4 Prem+ 6MT
    2010 Meteor Gray B8 A4 premium 6MT
    2008 Subaru Legacy
    Aug 06 2012
    san diego
    Quote Originally Posted by Speedybrit View Post
    this. i keep my oil temp up at all times
    Veteran Member Three Rings Dakine17's Avatar
    Mar 29 2009
    '13 Iceberg FJ Cruiser, '05 Scion TC
    San Diego/CA
    Is launch control only in cars that have drive select?
    Apr 11 2016
    Lincroft NJ
    Can you explain that in English. Lol.
    Sep 20 2004
    Paradise Valley, AZ
    he used vcds to change the computer settings to show oil temps at all times on the info screen.
    Set Oil Temperature on all DIS Menus -
    [17] Instruments -> Long Coding -> Byte 10
    CHANGE: Tick Bit 1. Display Oil Temperature
    Aug 06 2012
    san diego
    Quote Originally Posted by s3_ernie View Post
    VAG COM noob
    Jul 08 2016
    Northwest Ohio
    Hi all! New to the forums. Just purchased a pre-owned 2015 S3. I've noticed when using launch control that the boost guage fills but doesn't stay full. It throttles between 70-100% Is that normal? My main reason for concern is that I've been having trouble getting a sub 5-sec 0-60.
    Veteran Member Four Rings HurrayFive's Avatar
    Jul 21 2013
    Remote
    Quote Originally Posted by silversho92 View Post
    Yup, normal response w/ LC, boost builds/bleeds on a cycle via the wastegate and/or diverter valve, I'm assuming it's wastegate controlled. I've noticed I get the best launch timing the release of the brake to the positive "upswing" just before it reaches full boost on the next to worthless gauge, 1 bar before max. Takes a little practice but the car definitely launches harder when you time it just right.
    '25 M8 Comp GC Frozen Tanzanite on Ivory/Night Blue - 11.0 @ 126 bone stock
    Jul 08 2016
    Northwest Ohio
    Great tip. Thanks!
