Results 1 to 10 of 10
    Senior Member Two Rings mjames's Avatar
    Dec 21 2012
    2019 Audi Q7
    Lake Wylie, SC
    Noise when turning left at low speed
    I notice a squeal/squeak from my car when turning slowly at low speeds (i.e. a drive-thru). What's odd is I don't hear it when coming to a stop and going straight, only when turning (specifically left from what I can tell). It's pretty noticeable. Any ideas what this could be? 2010 with 78k miles. If it's brakes, why only when turning at low speeds?
    Mar 11 2012
    Audi A5
    Ventura, CA
    Make sure all your lugs are tightened to spec
    2011 A5 2.0T//Ice Silver Metallic//30% Tint//RS5 Replica Grille//LED Interior Lighting//APR Carbonio Cold Air Intake, HFC, Downpipe, and Stage 1 ECU Tune//Carbon Fiber Mirror Caps//Lamin-x tailights//H&R Swaybars and Street Performance Coilovers
    Dec 21 2012
    2019 Audi Q7
    Lake Wylie, SC
    I had my tire rotated a few thousand miles ago and my brother in law did it, I trust he didn't leave one loose, but I can look into it.
    It really sounds more like brakes or an axle or something? Wheel bearing?
    Jun 20 2015
    NC
    It's brakes.
    Dec 21 2012
    2019 Audi Q7
    Lake Wylie, SC
    Why would brakes make noise only when turning?
    Mar 11 2012
    Audi A5
    Ventura, CA
    Checking the lugs will take 2 min and I had this same issue and that's what it was
    Dec 21 2012
    2019 Audi Q7
    Lake Wylie, SC
    I have AG wheels if that matters. What do I need to do? What tool do I need? Sorry, I am not a mechanic-type.
    Mar 11 2012
    Audi A5
    Ventura, CA
    Just tighten the bolts. I mean you SHOULD use a torque wrench. But just make sure they're all snug
    Senior Member Three Rings miA4's Avatar
    Jul 17 2015
    miami
    I was told that it could be the lower control arm bushings that are making noise. Apparently it's common on the B6's and B7's. I would imagine the B8's would inherit this issue as well.
    Established Member Two Rings IbisB8.5S4's Avatar
    Sep 09 2015
    2015 Tahoe LTZ, 2008 Silverado
    Mount Vernon, WA
    might be the ball joints either on the lower or upper control arms.
    also, are you lowered? i found out that mine did that because the strut mount bushing on my airbag was shot. Airlift sent me a whole new design and the problem is solved.
