Results 1 to 2 of 2
    Junior Member One Ring
    Jun 08 2016
    Post How to fix A4 B7 Fuel Gauge not showing Full
    Cause:
    A) Cluster needs calibration to adapt to sensor info
    B) Fuel Pump Sending Unit is not working properly
    Fix A):
    - Buy "VAG-COM KKL 409.1" Cable from ebay ~$5 (Those are usually Arduino chipset. so here are the driver http://www.microcontrols.org/arduino..._switcher=true)
    - Download VCDS-Lite (http://www.ross-tech.com/vcds-lite/download/index.php)
    ## If you have Mac, you could download VMWare Fusion. Then find a Windows (XP or 7 etc) image.
    OPTION 1 - Full Tank Calibration
    Step1) Fill up gas tank to full
    Step2) Open VCDS-Lite > Click 17 - Instrument > Type 33 in first box > Click Read > Type in 2nd box "65535" (press up/down if SAVE button is greyed out) > SAVE
    ## That should fix it. But if not, try Option 2
    OPTION 2 - Update Fuel Level Sensor to higher
    Step1) Open VCDS-Lite > Click 17 - Instrument > Type 30 in first box > Click Read > Press UP button on 2nd line until needle reach to FULL
    Fix B):
    - There are plenty of instructions out there on replacing Fuel Pump. However, i'll probably upload a youtube video soon to show how to remove the fuel lines.
    - You could opt to replace just the Fuel Sending Unit instead of entire pump but it might require soldering.
    Hope that helps
    Feb 16 2015
    I had this issue and it ended up being the float in the gas tank (drivers side under the rear bench seat) was getting caught on some hose. Moved the hose and problem fixed.
    2005.5 Dolphin Grey A4 Avant 2.0T Tip / Premium / Lighting / Cold Weather / Sport
    RAI K0R-GT / JHM K04 Tune / 034 HFC -> B7 S4 CB/ ST Coilovers / Hyperco 8" 750 Lb / 034 RSB / 18Z / 15% Tint / S-Line Paddle MFSW / 034 St M and T Mounts / GEN II RNSE
