Page 1 of 3 123 LastLast
Results 1 to 40 of 88
    Jun 02 2016
    Just got S6 resonator delete...........unsatisfied :(
    I just got the resonator delete done on my 2013 S6 and I'm unsatisfied. smh. I can BARELY hear it. I was hoping it would be a lot louder. I went with straight pipes thinking it would be louder than an X-pipe. Oh well. Guess I need to just invest in AWE and/or downpipes.
    Veteran Member Four Rings Djpeaksd's Avatar
    Feb 01 2016
    Encinitas, CA
    Quote Originally Posted by TheMajesticKing View Post
    I just got the resonator delete done on my S6 and I'm unsatisfied. smh. I can BARELY hear it. I was hoping it would be a lot louder. I went with straight pipes thinking it would be louder than an X-pipe. Oh well. Guess I need to just invest in AWE or downpipes.
    What year is yours? I think it is way more effective on 2016's with sport exhaust.
    2021 RS7 Sportback Nardo Grey - Vossen HF3's satin black, lowered via ODIS
    Established Member Two Rings ke116ngc's Avatar
    Jun 27 2011
    Denver Metro
    I have a 2013 S6 and I did the resonator delete with straight pipes. That lasted a few weeks. Then I felt like I lost a boatload of torque, not proven by anything other than butt dyno. So I then put in a magnaflow xpipe and removed the straight pipe. That lasted for about 3-4 months. Improved torque, again butt dyno, and nice sound. However, it wasn't enough so I then pulled the trigger on the AWE touring. In hind sight, I should have just gone AWE from the beginning. It would have saved time, effort, and money.
    I am very pleased with the AWE touring result in sound and power. It was what I was looking for all along. My $.02, go full exhaust from the get go.
    2013 Audi S6 - Phantom Black Pearl Effect, Black Interior & Headliner, Driver Assistance, LED Headlights, Cold Weather, 20" Wheels, Piano Black Inlays
    APR ECU Stage II Tune, APR TCU Tune, APR Downpipes, AWE Touring Exhaust, AWE S-Flow Intake, Eurocode USS Sway Bar & End Link Set, Eurocode Alu Kreuz, Adam's Rotors Slotted/Dimpled, Porterfield R4S pads, Stainless Steel Brake Lines, 034 Motorsports Driveline Mounts Package, RS Grille, H&R 20mm DRA Spacers, Vagcom lowered.
    Jun 02 2016
    Quote Originally Posted by Djpeaksd View Post
    it's a '13. It does kind of feel slower. This is my first turbo car so I'm not familiar with how exhaust setups affect peformance. I'm used to losing torque but gaining top end HP, which this car needs. But it's hard to tell if it feels slower overall.
    Established Member Two Rings Mdavis1722's Avatar
    Jul 12 2015
    Any sound clips?
    Jun 02 2016
    Quote Originally Posted by Mdavis1722 View Post
    Any sound clips?
    I'll take a sound clip later today.
    Active Member Two Rings sonjh81's Avatar
    Aug 31 2015
    Seoul, Korea
    Do not mess up with stock exhaust. If you cut the center resonator, you wll lose low-mid end torque.
    2013 Audi S6 4.0TFSI Quattro
    Havanna Black Metallic, Fully loaded
    APR Stage 2 ECU, APR Downpipes
    May 31 2015
    Darien, CT
    On this topics...anyone know if the 2016+ Sport Exhaust sounds different with the AWE touring and the APR Stage I or does the APR Stage I sort of mitigate the programming effects of the 2016+ Sports package?
    Said another way, if I have a 2016+ and go with AWE and APR would that sound exact the same as a 2015 with AWE and APR or will the 2016 still have more pops and gurgles. Just sort of wondering if the APR tuning is also changing things (adding or undoing) OEM programming that results in the additional pops and gurgles on the 2016+s.
    Sep 19 2014
    Newcastle
    Not true about losing torque on boosted cars. You don't need the back pressure. From what I've read it's a myth. There's some good videos on it of you look on YT. Mines making more power. Djpeaksd is right though 2016s work well with this mod.
    Sent from my XT1580 using Tapatalk
    Audi S6 C7.5 Avant 2016 Sepang Blue APR Stage 2, Custom Downpipes, Revo RS Intake, X-Pipe & Resonator Delete - 441WHP 528WTQ 551BHP 660 LB FT.
    Jan 15 2013
    2013 Audi S7, 2012 Land Rover LR4 HSE
    I have APR down pipes and the straight pipe resonator delete. I highly doubt you actually lost mid-range torque. Maybe part-throttle on the low end of rpm range it could "feel" that way.
    Exhaust was notably louder after down pipes and coupled with the resonator delete its significantly louder now. I bet it would sound even louder/better with a sports exhaust like djpeaksd said. The non-sport mufflers do a pretty good job of quieting the exhaust down and the car itself is pretty well insulated.
    2011 Audi R8 Spyder - Ibis, 6MT, HRE P43S, white calipers, gloss black vents/trim/window frame, tints/radar/laser, UGR TT
    2013 Audi S7 - Estoril Blue, RS7 carbon diffuser, skirts, mirrors, tint/radar/laser, Eurocode sways & links, APR Stage 3 (RS7 turbo & intake, APR downpipes & AMS boost cooler), 285/35/20 on 20x10 ET25 ...GONE
    2017 Audi Q7 - Graphite Gray, BOP
    2001 Honda S2000 - Silverstone Metallic
    Established Member Three Rings fatherdeath's Avatar
    Jul 20 2016
    2016 Honda CRV EXL, 2006 Dodge 2500 laramie mega cab, 1974 Buick apollo
    Tampa, FL
    In know going from stock 17 S6 with sports exhaust got a lot of exhaust fees back in farts and crackles on shifts after time the added pops are a lot less now but exhaust sounds a bit louder..I think Audi enables the extra drop or 2 of gas in the motor during gear changes to provide that noise and the tune took that away but added a ton of power so I'm ok with it I'll be doing apr pipes on the borla exhaust and I expect some crazy results
    Jul 27 2013
    indianapolis/indiana
    my center resonator delete is a huge difference maker. It seems like it has gotten louder and I love the sound under wot. I have straight pipe, it costs all of $80. Did a launch control with a buddy and lowered the windows, wow. Very happy.
    2003 RS6 Apr stage 1 and tiptronic, Apr divertors, Clear bra, Yellow konis SOLD
    2014 S7 Audi exclusive edition 1, Havana black metallic exterior, Havana brown interior, APR stage 1 ECU/TCU, Total Loss Wreck
    Sep 10 2015
    VA
    I thought you had to have a x pipe or H pipe because of the valves. Straight pipe will be blocking the exhaust gases will it not?
    Mar 29 2014
    Hampshire, UK
    Quote Originally Posted by Barritia View Post
    This.
    X or H. I recommend X.
    If you've gone straight with no crossover, your risking a whole heap of problems related to back pressure.
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Jan 09 2013
    UK
    To the OP, when you removed the resonators did you also have the central muffler / Silencer removed as well? One in isolation makes little difference, having both done and thus just leaving the rear silencers in place makes a fair bit of difference.
    Jan 09 2013
    UK
    Given the OEM system has a crossover point in it in the central silencer / muffler its best to replace it with an x / h pipe to ensure optimal gas scavenging. If you leave that silencer in then you don't need any crossover but then it would be quiet.
    May 31 2015
    Darien, CT
    Quote Originally Posted by ke116ngc View Post
    I am thinking I will be in same boat as you here. I am tempted to try the center resonator first and then if that is not loud enough maybe do the front resonators as well. My question is how much louder the car is on startup with the AWE Touring vs. S6 Sports package OEM exhaust? I know I will love the sound of the AWE Touring on WOT and downshifts but I am concerned about the cold starts as I sometimes get up early and don't want to wake up the family.
    Is there a way to start the car with the AWE Tuning exhaust and not have it be so loud? My concern is no since you are removing the OEM exhaust valves. So this has me leaning towards trying the center resonator delete / replace with x-pipe first and see how that goes.
    Sep 19 2014
    Newcastle
    Quote Originally Posted by SilverTT View Post
    Personally if you're going to remove the centre muffler I'd remove the fronts as well-meaning centre didn't change it much for me personally.
    Veteran Member Four Rings 1975audi's Avatar
    Nov 15 2012
    2013 ALLROAD B5 S4
    Ancaster Ontario
    I did the middle res delete MOD and it made my S4 sound raspy at wot.
    Are you guys experiencing the same thing or does the v8 eliminate that from happening.
    FYI.picking up a 2014 S6 tomorrow
    2007 RS4
    2000 B5 S4 stage 3
    Apr 14 2016
    2014 Mustang GT500, 2015 BMW R1200 GSA
    Northern NM
    Anyone have a sound clip of a C7 with the suitcase and front resonators deleted? Most of the ones I've seen are C7.5 with sport exhaust. The C7 seems much lower volume.
    2014 Estoril Blue S7
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    How much did you guys pay to remove the res
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Mar 29 2014
    Hampshire, UK
    Average cost seems to be around the $350 mark.
    There are no rasping issues with the centre and front resonator deletes on the 4.0TT engines, only roars at wot. The turbos eliminate a lot of the raw noise.
    Nov 15 2012
    2013 ALLROAD B5 S4
    Ancaster Ontario
    Any links to xpipe
    Is it 2.5" or 2.25"
    2007 RS4
    2000 B5 S4 stage 3
    Aug 03 2014
    Queens
    Remove the front dual resonators and replaced with straight pipes
    Non sport exhaust
    Previous
    Senior Member Two Rings LJohnson32's Avatar
    Dec 08 2014
    2016 BMW M6 Gran Coupe
    Saint Paul, MN, United States
    Quote Originally Posted by DGVR6 View Post
    Non sport exhaust
    I like the sound - did you cut the suitcase silencer out as well or just the front pair of resonators?
    Aug 03 2014
    Queens
    Quote Originally Posted by LJohnson32 View Post
    Thanks, the suitcase was left alone.
    I was curious on how it would sound with just the front two resonators removed and replaced with 2.50 pipes
    Previous
    Sep 19 2014
    Newcastle
    Non sport exhaust
    Nice
    Nov 15 2012
    2013 ALLROAD B5 S4
    Ancaster Ontario
    How many of you have had to visit the dealer ship to adjust or recalibrate the ANC ?
    2007 RS4
    2000 B5 S4 stage 3
    Sep 19 2014
    Newcastle
    Quote Originally Posted by 1975audi View Post
    ANC?
    Established Member Two Rings Roadwarrior's Avatar
    Oct 01 2016
    Atlanta, GA
    active noise cancelling. It is a real pain.
    2015 Audi S6- Phantom Black Pearl Effect, Black Interior, Black Alcantara Headliner, Driver Assistance, Night Vision Assistant, Carbon Atlas Inlays, Cold Weather Package, 20" OEM Wheels. Mods- AWE Touring Exhaust, Bel STI R+, ALP Laser Shifter, RS6 Intake. On the way but not installed: Alu Kruez, Sways, End Links and Mounts.
    Aug 03 2014
    Queens
    I've always had ANC errors when I scan since new.. I just disabled it all together.
    Previous
    Senior Member Two Rings FourRings115's Avatar
    Sep 28 2016
    Hoboken
    I had read this thread and others, and after debating just had a Milltek non-resonated exhaust installed on my 2016, which had the sports package with the sport exhaust.
    I set my individual drive setting in MMI with the sort exhaust on the day I bought it, but after a couple months just pulled the trigger on the Milltek system. The standard sport exhaust just didn't do justice for this engine.
    While it can't be adjusted like the stock sport exhaust, using the transmission setting to regular Drive or Soort makes a big difference in exhaust sounds. Drive gives you growl when you are on the gas, while Sport gives you growl, pops, and nice throttle blip exhaust sounds on decel and overrun.
    Will get some videos up when I can- got this done right before holidays and have been gone for a while. (Daydreamed about sliding around my S6 in the snow Sun Valley where I spent the holidays).
    '16 S6
    ‘14 Porsche Cayman S
    '18 Subaru Forester (company car)
    '11 A8L 4.2 (sold)
    '07 A8L 4.2 (sold)
    '04 A6 2.7T (sold)
    Aug 03 2014
    Queens
    Quote Originally Posted by FourRings115 View Post
    Can't wait.. I really want to do either custom or miltek
    Previous
    Feb 25 2014
    Texas
    Bet you could sell that sport exhaust pretty quickly!
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Sep 28 2016
    Hoboken
    Quote Originally Posted by AudiS4B8 View Post
    Asked the shop about that- how many people take it with them to try to sell. I live in a condo in a crowded city so keeping even winter tires and wheels is a pain. Was going to take home the stock exhaust but didn't see much market for it online.
    Oh well.
    '16 S6
    '11 A8L 4.2 (sold)
    '07 A8L 4.2 (sold)
    '04 A6 2.7T (sold)
    Nov 15 2012
    2013 ALLROAD B5 S4
    Ancaster Ontario
    Non sport exhaust
    Looking at doing this tomorrow.
    Would you say it's loader then a non res awe touring exhaust.
    Any drone?
    Is it only load at wot ?
    I'm afraid that doing the middle res won't be loud enough but I definitely don't want it to be too load when driving around town with the kids and wife
    2007 RS4
    2000 B5 S4 stage 3
    Aug 03 2014
    Queens
    Any drone?
    It's like OEM .. you won't hear it cruising especially inside the cabin or outside, even WOT is barely noticeable inside.
    You'd have to be outside the car at WOT to appreciate it.
    Previous
    May 31 2015
    Darien, CT
    Really interesting results here by just removing the front set of resonators. Would not have thought it would be such a difference without also removing the large suitcase. I sat in our new 2017 S6 Sport Package for first time yesterday (picking up today after clearing up some DMV paperwork) and I could barely hear the car when it started. Given I have had a Cayenne Turbo with secondary bypass cats removed and a 700rwhp 2004 Cobra with headers, straight pipes, Borla stingers I think I will need a little more volume.
    AWE Touring may be the right answer but I am going to try first with the resonator deletes. Just a question if I should do fronts first, middle first, or just start with them all removed?
    Feb 25 2014
    Texas
    Given your previous cars, I wouldn't waste your time by removing one or the other. Just remove both. I bet you'll still want more noise after
    10.65 @ 129mph
    Nov 15 2012
    2013 ALLROAD B5 S4
    Ancaster Ontario
    Just did the middle res and I'm not impressed.
    Going to cut out the2 front ones next.
    2007 RS4
    2000 B5 S4 stage 3
