Results 1 to 10 of 10
    Established Member Two Rings kirkendall's Avatar
    Jan 20 2015
    06 zx6r , 2008 a4 B7
    Lehighton, PA
    JHM tune with no communication
    Hey guys, has anyone ever had any trouble communicating to the ECM module, brake module, and airbag module after getting a JHM tune?
    I'm currently sitting at the Audi dealership and they told me they cannot communicate to these modules? Anyone else heard of any problems like this?
    2008 A4 6 speed mt.
    JHM STAGE 1 - 93 oct.
    Test pipe
    rs6 grille mod
    Veteran Member Four Rings pw211's Avatar
    Dec 14 2008
    Bay Area
    I have this problem as well, anything "past" the cluster cannot be communicated with via my shop (JHM stage 1)
    Pat
    F.T.W.L.T.B.D.W.I.C.T.W
    P.I.I.T.B
    IG: pwwhite
    "I bet if Sean posted a picture of toast it would get 50 likes. And more than 3 people would say 'specs?'" - Solarsuplex
    Jan 20 2015
    Lehighton, PA
    Quote Originally Posted by pw211 View Post
    Why has JHM not made this information available? And what needs to be done to communicate with this? I am also JHM stage 1
    2008 A4 6 speed mt.
    Test pipe
    rs6 grille mod
    Dec 14 2008
    Bay Area
    Quote Originally Posted by kirkendall View Post
    I don't doubt they will chime in, they are on here regularly.
    Pat
    P.I.I.T.B
    IG: pwwhite
    Aug 31 2011
    C7 A6 3.0T Prestige - AEV JKUR
    Lathrop
    Can you show me some examples? We don't block communication with anything so I would need to see what modules you are having issues with.
    Dec 14 2008
    Bay Area
    Quote Originally Posted by Jake@JHM View Post
    Couldn't com with anything but airbags, abs, engine - we suspect RNSE-swap because we can't com with radio. I just pitched in here because tune hadn't occurred to me but I'm having the same issue.
    Pat
    P.I.I.T.B
    IG: pwwhite
    Aug 31 2011
    Lathrop
    Can you send a screen shot of it?
    Veteran Member Four Rings Copen-cisco's Avatar
    Sep 06 2013
    B7 Audi A4 Avant+ B7 Sedan and '69 912
    Dublin, CA
    Did you swap pins in your harness? I couldn't communicate with my Navigation module until I changed the pins.
    Kristian
    l Audi A4 2007 Avant l 2.0T TIP l Custom Stage 2 tune l IE HPFP l 034 HFC l 034 TIP l Rev Snub mount l 034 motor mounts l ST Coilovers l RS4 rear sway bar l Milltek Cat-back Resonated l S4 Recaro l RNS-E MKII l 19" Peelers
    Dec 14 2008
    Bay Area
    I'll be going by later this week or weekend I imagine, will try to remember to get a screenshot
    Quote Originally Posted by Copen-cisco View Post
    RNS-E swap occurred prior to my ownership, so cannot say for sure.
    Pat
    P.I.I.T.B
    IG: pwwhite
    Jan 20 2015
    Lehighton, PA
    Jake,
    I don't have the vagcom, I went to the Audi dealership to have them look at why my a/c is all messed up and they said they cannot communicate with the things I mentioned in the original post. I'm my mind I was thinking it had to do with the tune and that's why I came here to ask. What would cause this?
    2008 A4 6 speed mt.
    Test pipe
    rs6 grille mod
