Page 1 of 3 123 LastLast
Results 1 to 40 of 114
Thread: KI crank pulley
    Veteran Member Four Rings s4matty's Avatar
    Aug 15 2015
    2 feet
    Niagara canada
    KI crank pulley
    Hey guys
    I just took this off my car last night to test another size.This pulley is 186mm
    And was a sweet set up with the apr blower pulley.It has been used for 3000kms (not miles) as well as idler pulley
    Comes with conti belt (I will give a new one)brand new gr 12.9 bolts
    $400us plus $31us shipping with tracking number.
    Sent from my SM-G900W8 using Tapatalk
    Jun 20 2015
    NC
    I can't keep up with all the sizes
    Jun 12 2015
    CA
    I take it you like the 194mm better.
    Aug 15 2015
    2 feet
    Niagara canada
    Posted in wrong section! Damm
    Aug 15 2015
    2 feet
    Niagara canada
    I'm going to run the 194 for a few weeks.
    Then swap it out for another size..
    That's the nice thing about making your own,you get to try them all
    Jun 28 2016
    US
    So, which specific KI pulleys require new idlers and require grinding of the block if you're running a stock supercharger pulley?
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by SwankP3RF3ct10n View Post
    I don't believe any of them require new idlers.
    I believe all pulleys(Not just KI) bigger then 190mm or so will require grinding off some of the block for clearance on the belt.
    Geoff
    Aug 15 2015
    2 feet
    Niagara canada
    186mm and up required grinding the snub on the block..My pulley or someone else's doesn't matter.
    Jun 28 2016
    US
    Quote Originally Posted by s4matty View Post
    You kinda lost me with that last statement. Are you saying that despite the manufacturer, the grinding will be necessary after going higher than 186mm? (Perhaps that's what you meant.) Funny how nobody making larger pulleys mentions this in ANY of their posted info for the pulleys.
    Apr 05 2016
    Portland, OR
    Yes all pulleys regardless of manufacturer will require grinding , there is a good picture about it somewhere.
    Keep in mind, until recently only JHM offered a bigger crank pulley. (179mm so it required no grinding)
    Geoff
    Veteran Member Four Rings BlownOne's Avatar
    Dec 30 2015
    Sacramento, Ca
    Yea search for my KI 184mm crank pulley thread...there are pics posted inside of what needs to be done. It's juts a mounting boss that needs to lose about 1/4" from the face
    2011 CtsV Blk/Blk Loaded
    StageX 10.51@135mph E85
    2011 S4 Quartz/Blk Loaded
    034 Stg1 12.31@111mph 91octane +660Da
    034 Stg2 11.84@118mph 91/E85 +2200Da
    034 Stg3 11.55@119mph 91/E85 +1360Da
    Jun 28 2016
    US
    Quote Originally Posted by BlownOne View Post
    Yes, I'm aware of that (saw the thread/post when it was put up)... I'm just personally not into doing that if I don't have to, hence my question on what sizes don't require it. Thanks though for the link.
    Apr 05 2016
    Portland, OR
    someone confirmed you can do the 180mm GMG pulley without modification.
    That is the biggest I can confirm so far.
    However, honestly the modification is so minor I would rather go with this pulley than one of the more expensive slightly smaller ones. (my .02)
    Geoff
    Aug 15 2015
    2 feet
    Niagara canada
    I have a 181mm that did not require grinding on the block..It was border line though..
    Jun 28 2016
    US
    Well, if 181mm was borderline, then how can 186mm not be? I guess what I'm asking is... what is a "safe bet" size that won't have any issues. I think what I'm gathering here is that 179mm is that. Anything above and it'll either be a gamble, require grinding or be too close for comfort and if there's any weird belt movement, it could contact. Yes?
    Apr 05 2016
    Portland, OR
    See here: http://www.audizine.com/forum/showth...lopment-thread
    179 or 180 are both safe bets
    This is all new development and S4matty is very much at the forefront of it. Thus we do not have very much information other than 180 is confirmed no grinding, 184 is confirmed needing grinding.
    Geoff
    Jun 28 2016
    US
    Ya, Leo must have edited some of that original post today to add the second graph and to also add the * comment about 180mm and up requiring grinding.
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    If you want to sell that 194 when you're done testing,let me know. I'll buy that
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by mrmomo313 View Post
    OK that works.
    Next week it is coming off.
    Oct 27 2010
    Michigan
    OK that works.
    Sounds good
    Aug 15 2015
    2 feet
    Niagara canada
    Still available
    Also have a 181mm
    184mm
    186mm
    189mm available
    Aug 15 2015
    2 feet
    Niagara canada
    Red 186mm pulley is sold.
    Have a few of multiple sizes available..Including 200mm
    Senior Member Two Rings withENEMYin's Avatar
    Jul 24 2014
    2017 Q7 3.0t, 2008 Q7 4.2L
    Chicago, North Burbs
    Looking Forward to it!
    2014 RS7: Milltek Turbo back, RocEuro Intakes, Ported TB
    Jul 24 2014
    Quote Originally Posted by withENEMYin View Post
    s4matty has exceeded their stored private messages quota and cannot accept further messages until they clear some space.
    Sep 12 2011
    2003 RS6 Daytona
    Syracuse NY
    YO S4 Matty, PMed you bro :) Gimme one of them pulleys
    Jul 24 2014
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    Are any of you guys encountering an increase on NVH at certain rpm's, whether at idle or 2-3K? Seems like no one is mentioning that aspect of the solid pulley.
    Just a simple yes or no would be appreciated before I jump into this pool with a 189 or 194mm.
    Thanks
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Quote Originally Posted by RWD2quattro View Post
    Thanks
    none, no different than the OEM pulley, and no different than my last JHM 179mm pulley. It's a nice piece that doesn't draw attention to itself in terms of NVH.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Dec 29 2011
    The Bay
    Quote Originally Posted by Loe View Post
    Thanks Loe, I sent S4matty a pm.
    Senior Member Two Rings Jackinmochers's Avatar
    Jul 12 2015
    04 A6 - Scrapped, 01 GMC Denali - Sold
    Virginia
    What are the gains over just stage 2 looking like? Is it noticeable/ worth it?
    Aug 15 2015
    2 feet
    Niagara canada
    Thanks
    Nope
    I haven't noticed anything
    Aug 15 2015
    2 feet
    Niagara canada
    Quote Originally Posted by Jackinmochers View Post
    It is a noticeable difference in low and midrange power..
    Dec 29 2011
    The Bay
    Matty, I tried your PM box is full. I got your message. Where do I pay?
    Aug 15 2015
    2 feet
    Niagara canada
    Send me a text
    289 2one4 4two12
    Thanks
    Oct 27 2010
    Michigan
    +1
    My experience has been the same with APR/JHM and on the 194KI/APR combo now
    Jul 12 2015
    Virginia
    Interesting. I will see what happens with the new APR kit that comes out and maybe jump on this bandwagon depending. Thanks
    Veteran Member Three Rings Trent212's Avatar
    Sep 10 2015
    AL
    New home is very appreciative of this fancy little toy!
    2018 TT RS - Nogaro Blue | CF Inlays | Black Optic | Design Selection Interior | Red Calipers | Technology Package
    APR E85, Intercooler, Inlet, And intake
    TVS Stage 3 TCU tune
    SRM TB Inlet
    SRM GTX3582
    SRM/Eurocode fuel system
    Jul 24 2014
    S4matty, thanks! Got her back this afternoon, and the big bitch has a noticeable increase in midrange power over my jhm overdrive. I also threw in a new heat exchanger. Power every pull now...
    Account Suspended Three Rings
    Oct 15 2015
    That's awsome to hear!
    Aug 15 2015
    2 feet
    Niagara canada
    I have a few more pulleys available in multiple colors..
