Results 1 to 12 of 12
    Veteran Member Four Rings quietcropduster's Avatar
    Feb 21 2015
    2014 C7 Corvette 3LT Z51
    Ohio
    How to hide wires behind center console or dash?
    Can't figure it out!
    Using a dash cam "Black Box." I don't trust other drivers!! (A story for another time).
    I have it plugged in the cigarette lighter in the center console by the shifter, how do I hide the wire? It goes from there back behind the glove box to the passenger side door.
    Thoughts?
    double thumbin' it!
    B9 S4 Prestige | Glacier White Metallic | B&O | Sports Diff | CF Inlays | Roc Euro Intake | APR FMIC | ECS Valved catback | 034 tour brace/RSB & trans mount | Forge Motorsports OCC | Michelin PS4s | EPL Stage 2 93 |
    May 09 2012
    2013 s4, 2008 cbr1000rr
    United States
    Quote Originally Posted by quietcropduster View Post
    Thoughts?
    double thumbin' it!
    Mine goes from the driver footwell to the center of the front windshield. I used a small flathead screw driver to slightly pull the panel gap apart and ran the wire from the fuse box up the A pillar, to the location by the rear view mirror. Took time to make sure not to scratch anything. Feels weird at first pulling the panel gap to be large enough to fit the wire, but returns to normal gap and hides the wire nicely. I originally tried the cigarette lighter, but their adapter is bulky. So I used the fuse box adapter to the cigarette adapter then hide the wires from there...much cleaner.
    Apr 05 2016
    Portland, OR
    I agree with DBL R, I would hard wire it to the fuse box.
    Mar 21 2015
    Definitely hardwired that thing. Its simple just like a radar detector.
    Feb 21 2015
    Ohio
    Will it turn off thought when the ignition is turned off?
    double thumbin' it!
    Veteran Member Four Rings infinkc's Avatar
    Feb 13 2004
    S Ã C, CÃ*
    double thumbin' it!
    if you tap into a fuse circuit that is only on with the ignition.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Oct 20 2008
    Denver
    double thumbin' it!
    do you not understand the concept of hardwiring?
    Feb 21 2015
    Ohio
    Quote Originally Posted by AudiTFSI3o3 View Post
    I do but didn't know if the fuse box was always energized or not, but thanks for the smart ass comment. I'll be sure to return the favor sometime
    double thumbin' it!
    Mar 21 2015
    Just tap into the radio or cig lighter fuse with an "add a fuse" circuit. The items like those are only on when the key is turned other wise they would drain the battery.
    Oct 20 2008
    Denver
    double thumbin' it!
    in that case, here's what I dug up after researching in less than 1 minute. should try that some time.
    http://www.audizine.com/forum/showth...who-ve-done-it
    http://www.audizine.com/forum/showth...o-2013-Audi-A4
    http://www.audizine.com/forum/showth...om-for-DashCam
    http://www.audizine.com/forum/showth...ashcam-install
    http://www.audizine.com/forum/showth...94121-dash-cam
    until then
    Feb 21 2015
    Ohio
    Thanks man!
    double thumbin' it!
    Feb 21 2015
    Ohio
    to make sure I understand:
    so getting the add a fuse, just make sure its the full size fuse, but what amp 10?
    Driver side fuse box - I can use the soundaktor fuse for the 'add a fuse' ?
    No need for the power magic pro control box if I want the dash cam to power off when the car turns off? (or ignition is off)
    use the groundling bolt to the left of the drive side fuse box?
    Did I miss anything ?
