Results 1 to 15 of 15
    Established Member Two Rings waynegz1's Avatar
    Apr 30 2013
    San Antonio, TX
    Rear Side Markers Unable to Disable via VAGCOM
    Did the VCDS directions to disable the rear markers work? I followed the process below and it never worked.
    Disable rear side markers in US vehicles
    [Select]
    [46-Central Convenience]
    [Security Access] enter 16017
    [Adaptation - 10] --> channel 209 for left rear side marker
    Document your existing number should you need to re-enable rear side markers later
    Change existing number to 0
    Channel 210 for right rear side marker
    Change existing number to 32
    When I went to channel 209, I got the message that security code must be entered (which I already had).
    I tried taking out the bulbs thinking they are not powerful enough to throw a code, I was wrong. Anyone know/used a resistor to put in place of the bulbs in the rear side markers? Have the TAG painted reflectors coming in and don't want to install until I can get this fixed (already tried the TAG instructions but they did not work either).
    Thanks
    Apr 30 2013
    San Antonio, TX
    anyone?
    Jun 30 2012
    16 Lava Orange GT3 RS, 18 Nardo Grey RS3, 17 Panda Macan GTS, 91 C2 964, 16 F150 Lariat, 63 Impala
    Woodstock GA
    Serious question, not trying to be a smartass... does this even matter?
    I know I did my fronts on my own (plus disabled w/vagcom) and the body shop did my rears when they were doing calipers. Doubt they disabled them and it hasn't seemed to be an issue.
    Apr 30 2013
    San Antonio, TX
    Quote Originally Posted by tonymission View Post
    Yours don't seem to shine through the painted rear side markers?
    Jun 30 2012
    Woodstock GA
    Quote Originally Posted by waynegz1 View Post
    No, but can't say I've looked for it. Is that the only possible issue?
    I'll look tonight while it's dark out.
    Apr 30 2013
    San Antonio, TX
    Yeah, that is my only concern since I cant shut those bulbs off. I appreciate your help
    Established Member Two Rings rbravo's Avatar
    Jul 17 2016
    Cerritos, CA
    Late reply because I only recently bought my S7. I installed the TAG painted reflectors and left the lights activated. I actually like the way they work with white paint which allows the amber and red to shine through at night.
    https://www.youtube.com/watch?v=fVzd8BFlKpE
    2019 S5, KW Adjustable height springs, 20" Vossen VFS1's
    2014 S7 APR Stage 1, 21" TSW Bathurst, SOLD
    Stage 2 Banner Advertiser Four Rings Alex@TAG's Avatar
    Nov 15 2011
    ABT RS5-R, SQ5, 488 Pista
    San Diego, CA
    Good morning! :)
    So the reflector coding is quite simple. It varies from year to year - but your coding should be Channel 209= 12, Channel 210= 44.
    Give us a call if you have any more questions.
    TAG MOTORSPORTS
    (866) 748-4388
    SITE: www.TAGMotorsports.com
    EMAIL: [email protected]
    AUTHORIZED DEALER: HRE Wheels || FlowForm || Vossen || ABT || TechArt || AWE Tuning || APR || KW Suspension || Milltek || BBS || Brembo || Michelin & more!
    Active Member Two Rings schrajw's Avatar
    Sep 27 2016
    Greenville, WI
    Quote Originally Posted by Alex@TAG View Post
    Good morning! :)
    Anyone have luck disabling rear side markers (single red LED) on a US spec 2017 S6 yet? I've tried everything listed on multiple sites, no dice. Not a big deal, just surprised they won't disable via coding listed as the front ambers did without issue. Anyhow, TIA to anyone who can help.
    Established Member Two Rings davelong9050's Avatar
    Oct 09 2015
    Gold River, CA
    Quote Originally Posted by schrajw View Post
    Not doable on 2016 S7 C7.5. Gave up, wrapped bulbs and tucked them in quarter panel compartments. Leave bulbs in otherwise you will see error warnings.
    2016 Audi S7 (C7.5) // Ibis White w/ Black Interior/ Contour Seating/ Driver Assist/ Sport Package/ Carbon Inlay/ Power Assist Doors/ Head Up Display
    Aftermarket // APR ECU Tune/APR TCU Tune/ Xpel/ Opti-Coat/ 30,50,70 Ceramic Window Tint/ 20” Rohana RF1’s (refinished silver)/ Painted Calipers/ Slotted Rotors/ H&R ETS Lowering Module/ RS7 Grill/ Carbon Fiber Rear Valance/ Upgraded Sub with Dedicated Power Amp/ Escort 9500ci Radar Detector/ VAG-COM Mods
    Sep 27 2016
    Greenville, WI
    K, thanks... appreciate the info.
    UPDATE: Pulled a rear tail light out last night, the single LED side markers are part of the PCB board inside the light assembly. So, unless we figure out how to decode via VCDS, no dice for MY17 S6, etc.
    Sep 27 2016
    Greenville, WI
    Anyone know of a solution?
    Established Member Two Rings rqgunn12's Avatar
    Jun 11 2018
    2015 Audi Q3
    Pennington, NJ. USA
    How did you take the them out? Had to remove bumper?
    Jun 11 2018
    2015 Audi Q3
    Pennington, NJ. USA
    Quote Originally Posted by davelong9050 View Post
    How did you take them out?
    Mar 30 2018
    long island
    I had trouble diabling mine on MY17 RS7. As you experienced, the fronts turned off easily using the channel that was listed in the VCDS thread, the rears.
    The coding that was in the VCDS thread was incorrect for my application; it has the wrong channel. took some trial and error, but i remember changing a few channels between 210 to 215, using the guess and check method. eventually got them to turn off. intoned down the channel and code, change the code, inspected to see if it did what i wanted, and changed it back if it didn't.
    Wish i could help you with exactly what i did, but i cant remember and I didn't write it down.
    and to those of you asking how to remove them.
    front - turn wheel to have access to fender liner screws. unscrew a couple screws at the fender liner, reach in and pop them out.
    rear - apply pressure to the bumper just towards the rear of the reflector. this will create a small space to slip in a a very small screwdriver or butter knife to pry it out. alternatively, if you have small hands, you may be angle to rear from underneath and push it out.
    EDIT: I just realized the original post was from 2016. oh well. maybe this will still help some one.
