Results 1 to 12 of 12
    Established Member Two Rings BB c7's Avatar
    Jan 23 2016
    Chicago
    Battery replacement help
    Hi guys
    I need to change my battery. But i heard if i change my battery it has to be cod it, using vac-com.
    If i buy the battery from the dealer do i still need a coding ? Or is it just for the after market batteries ?
    Dealer want to charge over $200 for installation.
    Mar 18 2014
    Salt Lake City Utah
    Doesn't sound right. I disconnected my battery recently to install new steering wheel and no issues when turning back on.. Maybe this is different ?
    2016 S7 Daytona gray, arras red interior
    RS7 performance steering wheel
    9500ci Passport with mid-city enginering module integrated into instrument display
    Resonator delete with x-pipe
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by andrewaw View Post
    Disconnecting is one thing...replacing is another and ,yes, it will have to be coded and only Auid OEM batteries come with the code on the battery. Some have found a hack if you search.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Mar 18 2014
    Salt Lake City Utah
    Quote Originally Posted by gk1 View Post
    Learn something every day! Thanks for sharing
    Jan 23 2016
    Chicago
    Thanks for reply.
    Yes u right i stopped by couple battery shop and saw the batteries they recommended to my car. But it didn't have the code on battery.
    Do u know what would happen if i buy the after market battery and instal it without coding ?
    Is it going to show some silly light ? Or is going to destroy my electric?
    Veteran Member Three Rings plat's Avatar
    Dec 19 2015
    GVRD, BC Canada
    Quote Originally Posted by BB c7 View Post
    Hi guys
    This is what I have read in the B8/8.5 forums concerning battery swaps. I am not sure if it applies to the C7's but I won't be surprised if it did. When the battery you plan to replace is at its end of life but still has enough power in it, just disconnect it and replace it with a new battery. As long as the car did not go into power saving mode, you do not need to recode the new battery using VAGCOM. The car will run OK with no issues. However, if the car went into power saving mode due to a dying battery, you will need VAGCOM and recode the new battery. If not, it will still be in power-saving mode.
    How to recode using VAGCOM. Just change the last three digits of the battery serial number that shows up in VAGCOM. After that, you are all set. The car will now know that it just got a fresh battery.
    Current: 2016 S5 in Sepang Blue with Technik Package.
    Mar 26 2010
    US
    Thanks for reply.
    http://www.audizine.com/forum/showth...1#post11092893
    Vagcom, Just need to change the last digit of the serial number on the right side, so the serial number is new and the battery manager resets, to learn the new battery is in place.
    The stock battery is not cheap, $186 At Autozone.
    http://www.autozone.com/batteries-st...uestid=5718629
    2019 RS5 Sportback
    Jan 23 2016
    Chicago
    Quote Originally Posted by plat View Post
    Thanks for the reply. I will definitely try that I don't think my car is in power saving mod but still i need jump start a car even after driving for while.
    Do u think this would work if I swapped the battery with after market battery? Or it has to be audi OEM battery ?
    Another question about coding.
    If had to cod the new battery the last 3 digit number has to be match on the new battery that i am swapping? Or it just a random numbers ?
    Feb 25 2010
    magimmeMVE
    Usa
    Just change the original last 3 digits of the serial number to anything and the car will know its a new battery. You need to go to 19 CAN and then Adaptation and select battery info/replacement
    Mar 26 2010
    US
    This works on aftermarket batteries, like the Autozone one I posted. The battery module, just needs to know it is a new battery (new serial number).
    My Autozone battery had a serial number on the side, next to a faint QR looking marking on the side.
    2019 RS5 Sportback
    Dec 19 2015
    GVRD, BC Canada
    No, it does not need to be the OEM Audi battery. However, I have read in the forums that the OEM Audi battery on some instances can be bought cheaper than aftermarket replacements. It won't hurt to find out how much your Audi dealer is selling the OEM battery and compare with the aftermarket alternatives.
    What morski and wwhan said above, you do not need to match the serial number when coding a battery. Just any random number will do.
    I believe the OEM Audi batteries are manufactured by VARTA. The OEM VW battery in my '11 VW GTI was VARTA. I replaced it with a MotoMaster that is sold by Canadian Tire here in Canada. No coding issues. Like you, my battery just died one day. I got a boost from AAA then drove to Canadian Tire to buy a new battery. Changed in the parking lot and the car is good to go.
    VARTA is owned by Johnson Controls. Johnson Controls manufactures batteries under Duralast, Interstate, and Die Hard. In VAGCOM, when coding the battery serial number, the software will have a drop-down menu asking you to specify the battery brand in the form of a three digit/letter combo code. You can either disregard this one or code it to the correct battery manufacturer. It is not really necessary.
    Jan 23 2016
    Chicago
    Thanks for the replies and advice guys i learned a lot :)
    I didn't have a proper VAGCOM. So tried to use cable from amazon but some reason it didn't work.
    So I decided to just replace the battery and see what happens and i did it today. Bought a battery from advance auto part and replaced it. I think It working fine. It start the car and drive few miles I don't have any error codes or anything now.
    Hopefully nothing would happens after driving for while.
