Results 1 to 6 of 6
    Senior Member Three Rings CronicPAIN's Avatar
    Jun 16 2016
    Honda%20CRV
    pennsylvania
    knock sensor low circuit ?
    hi my car is giving me a code P0327 knock sensor (ks) 1 low circuit bank 1 so i bough it new but were does it goes ? i dont find it i have a audi a4 2.0t quatro s-line 2006 the car has 131k any help please thanks
    Veteran Member Four Rings onedumslack's Avatar
    Mar 05 2014
    phoenix/az/usa
    You have 2. Located under the intake manifold which you'll most likely need to remove to get to them.
    Jun 16 2016
    Honda%20CRV
    pennsylvania
    ok perfect thanks a lot
    Sent from my SM-N920T using Tapatalk
    Mar 05 2014
    phoenix/az/usa
    Search for the instructions from stasis for installing a k04 turbo. The first part walks you through manifold removal. It's fairly involved.
    Jun 16 2016
    Honda%20CRV
    pennsylvania
    nice i check it out
    Oct 20 2018
    Michigan
    I actually have a code for the bank 1 knock sensor, I know where they are at and all but I don’t know which one is the bank 1 sensor the one closest to me or the one near the firewall.. any help would be appreciated. The parts at Autozone look exactly the same only difference is one has a green plug (front) and a blue plug (rear). It would be greatly appreciated if someone could tell me which is bank 1 and which connector I need
