Originally Posted by
TBarCYa
My 2.0t with cvt is slow. I mean slow enough that it gets scary pulling into traffic. Today I bought torque pro and it seems to only sustain 11.5psi of boost which seems awful low to me. The car is stock and I'm wondering if this points to a bad diverter valve or if 11.5psi is reasonable for a stock engine? I had a 2003 a4 1.8t and that thing was a rocket compared to this.
Thanks for any help.
11.5 is good for stock boost, when logging mine in VCDS it peaks at about 12 and trails off to ~10.5-11psi
B7 is a heavier car, especially the cab model (I'd guess it's a least a few hundred pounds heavier than the sedan). Have you done a tune-up lately? Plugs, air filter, fuel filter, oil change? All of these can kill your power and MPG's as well.
Also the CVT is meh, but if you're up there in mileage you should change the fluid (and filter if it has one). That might liven up the trans a bit too.
