Results 1 to 4 of 4
    Veteran Member Three Rings hotleadsingergu's Avatar
    Jun 18 2015
    Cleveland
    Small squeak on bumps...suspecting brake change
    Hello, AZers!
    I changed my brakes around 1,200 miles ago and all went great. I've changed many many brakes in the past, and nothing went unexpectedly. That is, until the past week or so. Around 1,000 miles in, I noticed when I hit bumps I can hear a light squeak, and I can't entirely seem to determine which wheel it's coming from...in fact it seems to come from multiple/all, as I'm really having a hard time narrowing it down.
    I haven't taken the wheels off again yet, but at least a visual inspection looks fine. Nothing feels loose from external feeling, but it's obvious something needs adjusted.
    BTW, the reason I'm strongly assuming the brakes is because if I am applying any brake pressure at all, the squeak doesn't occur. This squeak happens on even the slightest of bumps, but when I'm touching the brakes it does nothing.
    Any thoughts from the crowd? Really racking my brain here!
    Veteran Member Three Rings sirsycott's Avatar
    Sep 20 2013
    Orange County/CA
    Quote Originally Posted by hotleadsingergu View Post
    Hello, AZers!
    does it sound like a squishy sqeaking sound? or metallic?
    check the bushings , on front side of car, i had this same issue was driving me bonkers, the shop i go to found out it wasn't the brakes but the bushings
    2018 TTRS
    Jun 18 2015
    Cleveland
    It sounds like a metallic squeak, but it goes away entirely if I have any pressure (at all) on the brakes). Even just touching the pedal enough to light up the brake lights is enough to keep the noise down. The only thing I can think is a loose part, but a visual inspection showed nothing (with plenty of pushing and touching).
    Veteran Member Three Rings Bikel's Avatar
    Jun 19 2013
    same issue here. mine is more of a thump/slap that chimes in even when hitting raised lane reflectors. it also seems to dissipate as soon as a little brake pedal pressure is applied. so i am curious...
    2010 S4 | Prestige | Ibis White | DSG w SD | ADAC Grille Badge
