Results 1 to 16 of 16
    Senior Member Three Rings ImOnABoat's Avatar
    May 12 2012
    Imola B8 S4
    Eastern Pennsylvania
    ECS Wheel spacers. (12.5mm & 15mm)
    Selling ECS wheel spacers, 12.5mm and 15mm, extended ball seat black lugs included.
    Used for about 400 miles
    105 shipped.
    Thanks,
    -Steve
    Ol' A6 Build Thread-
    Noveske
    Imola B8 6speed
    Senior Member Two Rings Shaun Perry's Avatar
    Jan 02 2013
    San Ramon, CA
    Do these have the centering lip on them? I would use these on my 19 inch peelers. Would not want issues with the hub being off or having vibration
    May 12 2012
    Imola B8 S4
    Quote Originally Posted by Shaun Perry View Post
    Yes these are the newer versions with the lip built into the spacers.
    I used them with my peelers, they are aggressive and did rub occasionally, just so you know.
    Noveske
    Imola B8 6speed
    Jan 02 2013
    San Ramon, CA
    Quote Originally Posted by ImOnABoat View Post
    What are you lowered on? And rubbed where, in the rears?
    May 12 2012
    Imola B8 S4
    H&R sport, and only the rear I believe.
    Noveske
    Imola B8 6speed
    Jan 02 2013
    San Ramon, CA
    Gotcha. I assumed this would be the case. Are your 19inch peelers on the stock tire and tire width as well?
    May 12 2012
    Imola B8 S4
    Yup 255/35/19 Continental all seasons.
    Noveske
    Imola B8 6speed
    May 12 2012
    Imola B8 S4
    Bump.
    Noveske
    Imola B8 6speed
    Veteran Member Four Rings Staz's Avatar
    Jul 03 2010
    QUEENS, NY
    Where are you located?
    May 12 2012
    Imola B8 S4
    Quote Originally Posted by Staz View Post
    Hamburg Pa.
    Noveske
    Imola B8 6speed
    Veteran Member Three Rings ALAN12186's Avatar
    Mar 30 2016
    Brick, NJ
    where did you get that plus sign emblem?
    13 S4/6mt/SDiff/MMI/B&O/Black Ops/APR Stg2+ Ultra,SC & 187MM Crank Pulley,TB & CPS V2/APR Intake/Milltek Res GT100/TA HF Cats/FF103 19x9.5/ Vorsteiner Front Lip/E Codes/ECS Diffuser/P3-Vidi Track Pack/Bilstein B12 & H&R OE Springs/EBC Red Pads & Slotted Rotors & SS Lines F&R/Brembo Calipers/CR15/APR 7MM F&R/034 Sway/Moog Links/ECS Drivetrain Mounts/Eurocode Krez/ECS Clutch Line/034 Trans, Motor & Sub Mount/SB STG 3 Clutch/USP Slave/Enlaes Spoiler/ECS SS/Autotech HPFP/Jokerz Blower/Killer Chill
    May 12 2012
    Imola B8 S4
    Quote Originally Posted by ALAN12186 View Post
    http://www.chromeautoemblems.com/pro...8#.V22ab-crJ0E
    Noveske
    Imola B8 6speed
    Mar 30 2016
    Brick, NJ
    thanks!
    Jan 10 2014
    2012 a4, 2015 s4
    TX
    I'll take them, you got PM
    Jan 02 2013
    San Ramon, CA
    Can I ask what the significance of the red plus emblem is
    May 12 2012
    Imola B8 S4
    Quote Originally Posted by mintytoo View Post
    Sold!
    Nothing really, just sort of means oem plus to me, and there is an R8+ trim now. I just like it haha.
    Noveske
    Imola B8 6speed
