Page 19 of 55 FirstFirst ... 9171819202129 ... LastLast
Results 721 to 760 of 2167
  1. #721
    Feb 02 2016
    Quote Originally Posted by netwibe View Post
    I am the latest victim of timing chain tensioner failure. Happened last week while I was going from work to home. Engine light with code P0016.
    The garage estimated 4000-5000$ repairs cost. I have 104000 km on my Q5 2011 2.0. The engine was shaking on low rev but over 1000 rpm it was working OK.
    I am so disappointed with Audi and how they handle this problem. Is there any class action lawsuit here Canada? I would like to sign up.
    That really sucks, such a low mileage too.
  2. #722
    Feb 16 2018
    Michigan
    Just got nailed by this one on my 2012 A4 with under 89k mi. Timing chain slipped at startup after an oil change at my preferred mechanic and immediately stopped the engine. Good mechanic who immediately diagnosed it as a failed tensioner.
    Called AoA and fortunately, still under my Certified Pre-Owned warranty, so getting it towed to the dealer for service and hopefully will only get stuck with the $85 deductible on this one. We'll see . . . .
  3. #723
    Veteran Member Four Rings mtroxel's Avatar
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by MT11187 View Post
    Check and see what the CPO is going to pay for. If they just want to pay the dealer to get in there and change the tensioner, pay for the parts for guides and chain also. No point in spending $$ to get there and not do it all.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
  4. #724
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    Do idler pulley, belt and belt tensioner too while you’re there with the nose off.
  5. #725
    Mar 26 2014
    This problem sounds like a disaster.
    I had Stage 2 done and on my bill i see tensioner listed a few times under the summary. Do you guys think it's likely that they changed them?
  6. #726
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    If It says they changed it they better have. Otherwise you get a free engine if the tensioner fails.
    2011 A4 Avant Prestige S-Line
  7. #727
    Feb 16 2018
    Michigan
    Thanks for the advice. Ended up with bent intake valves, so they are replacing the entire head, chain, guides, etc. - all under the CPO warranty.
  8. #728
    Mar 26 2014
    Hope they did, wish i knew about this problem when my car was in there getting the Stage 2 done.
    I'm going to try and find the part number on the bill. Maybe I can compare it to someone that has got the tensioners done as well.
  9. #729
    Nov 17 2010
    Courtenay, BC, Canada
    Quote Originally Posted by JVince View Post
    I believe the most current is still 06K 109 467 K.
    2011 A4 Avant
  10. #730
    Mar 26 2014
    Thanks, I'll have to check what mine is.
  11. #731
    Feb 07 2018
    PDX ish
    This and the oil burning issue have me seriously contemplating buying a 14 motor and replacing it's tensioner before swapping it into my 11 Avant. Seems like if you do it prior to blowing up your current block (able to sell) its the most cost effective way to mitigate the time bomb-iness of these cars.
  12. #732
    Active Member One Ring aywakko's Avatar
    Nov 17 2010
    Toronto, ON
    Quote Originally Posted by belzebutt View Post
    Any news for Canada? Mine just blew up, and it will cost me ~$6000 (still isn't finished). I went to a local mechanic since the dealer basically told me there would be no help and it will likely be more expensive. I wrote to Audi Canada and didn't hear back.
    Not sure if this thread is still alive....mine just blew up. 156k KM, 2010 Audi A4. Not sure what to do at this point. My local mechanic (very reputable) says it will cost $3,000 minimum and $4,000 if the crankshaft has to be replaced as well. Anyone had any luck with Audi? And how are the class action law suits coming along?
    HELP!
  13. #733
    Veteran Member Four Rings blbroo's Avatar
    Oct 26 2012
    SQ5, Nissan D21, 435i Gone: K04'd B8 A4, M235i, UrS6, B9 SQ5, D21 Nissan 4X4
    St. Louis, MO
    Quote Originally Posted by aywakko View Post
    HELP!
    As long as there are old tensioners in 2.0Ts, this thread will never die.
    Best option is swap in a B8.5 motor with lower miles.
    Collector of German things.
    “Whoever said laughter is the best medicine had clearly never tasted scotch.”
  14. #734
    Nov 23 2009
    NYC, US
    Quote Originally Posted by b6Hate4 View Post
    I paid $700 for labor. $400 for parts.
    $400 for one tensioner and one set of timing chain? What?
  15. #735
    Veteran Member Four Rings JBAeroEngineer's Avatar
    Sep 19 2012
    Capitol Area
    Quote Originally Posted by AutoRacer100 View Post
    Parts should include tensioner, guides, rails, chain, etc.
    2018 A4 | Mythos | Prestige | S
  16. #736
    Jan 04 2009
    Currently have: 09 A4 2.0T Quattro
    Just dropped mine off for stage 1 OC. $750. Out of extended warranty period, but since I'm burning a quart per 1k miles, I'm hoping (since I just bought a 2018 Q5 with Audicare and 10year/100k mile warranty) AoA will pay for some of the Stage 2.
    My plan is to squeeze the parts of the timing issue into the Stage 2 OC fix. Wish me luck....
    2018 Mythos Black Q5 Premium Plus
    2018 Ducati V4
    2009 Brilliant Black A4 Quattro Premium
  17. #737
    Oct 27 2010
    Sepang S3, Arctic S4.
    Norwood, MA.
    Lol no. I replaced every single component of the timing system. 2 tensioners, 2 chains, all guides ect. Refreshed everything.
  18. #738
    Nov 23 2009
    NYC, US
    What is the cause of failed timing chain tensioner? Is the updated version of timing chain tensioner has a stronger spring in it that keep the timing chain in place?
  19. #739
    Feb 24 2004
    Minneapolis
    https://www.youtube.com/watch?v=qAdSyBRHOPs&t=94s
  20. #740
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    I hate this thread. Scares the shit out of me.
  21. #741
    Nov 23 2009
    NYC, US
    Quote Originally Posted by BeerBrent View Post
    Me too even at 36k miles. I can't stop thinking about getting the tensioner replaced. But then the cost of that job. It's scary.
    Sometime I think I should not have bought this car back in 2009. But how would people know all those issues that come with a brand new car. That is impossible to know.
  22. #742
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    I'm at 75K and scared. Yeah, the cost is crazy. What's bullshit is that Audi isnt covering it under an extended warranty similar to the turbo. Obviously this is a fairly common issue.
  23. #743
    Feb 06 2017
    Middletown DE
    Audi/VAG is such a dirty profit hungry company. They only extended the oil consumption warranty to 80,000 miles.... only after being sued. I don't expect them to do the right thing on their own related to the timing chain/tensioners. The 2.0 TFSI has to be one of the worst engines made in recent times (at least the 2009-2011s). HORRID! Not a smart way to get repeat customers... thought it seems like a lot of folks on hear accept their piss poor reliability and lack of making things right with their customers and keep buying them.
    It is really a shame as they have so many good qualities....
  24. #744
    Veteran Member Four Rings avantagg's Avatar
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    My 2012 is currently getting the chains and tensioner done and all I can say is wow, I’m glad to be taking care of this now and not holding out for higher miles to rack up. Car has 72k on it and judging by these pics the chain might have been ready to go any day. It was stretched and making contact with the timing cover.
    2012 B8 Avant (3.0t Swapped)
    034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
  25. #745
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by avantagg View Post
    You've also got the old style tensioner with the metal band that is known to slip out of place.
  26. #746
    2020 A4 allroad
    NH
    Quote Originally Posted by mtroxel View Post
    Pretty clear that 2012 models are NOT exempt.
  27. #747
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Good to see you got yours taken care of!
  28. #748
    Nov 23 2009
    NYC, US
    I contacted one shop in my area. They quoted me $700 for the labor to do this job. I'm not sure how much the parts going to cost me?? My car only has 36K miles and I guess I have a few more years before the need to do this job.
  29. #749
    Jul 02 2017
    Knoxville TN
    Do it now. Some have failed with low milage
  30. #750
    Sep 19 2012
    Capitol Area
    parts are around $400-450 depending on your area.
  31. #751
    Nov 23 2009
    NYC, US
    Quote Originally Posted by JBAeroEngineer View Post
    Didn't you guys order the parts online?
  32. #752
    Sep 19 2012
    Capitol Area
    I had mine done at the dealer when it was in for Stage 2
  33. #753
    Veteran Member Four Rings Marko S's Avatar
    Mar 03 2015
    I ordered mine on ECS. They will price match.
    Sent from my SM-N950W using Tapatalk
    Current: 2019 Audi A4 Allroad Technik
    Past: 2011 Audi A4 Prem+ Stage 2+
  34. #754
    Nov 23 2009
    NYC, US
    Do you guys still remember what are the parts replaced exactly and what other parts can be replace while they are in there? Any after market parts that help improve reliability or even boost power? I know the piston rings can't be changed with this job.
  35. #755
    Senior Member Two Rings NYDCB's Avatar
    Aug 22 2016
    Washington, DC
    Might as well replace the guide rails and chain. I had mine done at NGP in VA and they didn't do anything other than the tensioner. Said I didn't need it... 2010 @ 91K.
    Mike, if you're reading this, how much more would you guys have charged for a chain and guide rail replacement?
  36. #756
    Sep 19 2012
    Capitol Area
    I lot of people have posted their receipts in here, mine is around November 2016 if you want part numbers/costs/parts
  37. #757
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    2013 A5 CAEB with a November 2012 build date. New style tensioner. 45,000 miles. When the spring clip gets to the 8th notch I will change everything out.
  38. #758
    Dec 28 2006
    Western Maryland
    OK. Time for a bit of discussion here,,,,
    The more I research this the more concerned I am becoming. I took this picture in a static condition.
    In other words, the engine was turned off. Once you start the engine the internal spring pressure moves the CCT to the right to take up any slack. So the critical measurement is the number of grooves from the end of the plunger to the snap ring clip. Not the number of exposed rings from the end of the tensioner body. As you can see mine is in the 7th groove.
    Here's a pic from when CharlieBrown replaced his tensioner as what I believe was done as a preventive measure:
    His picture shows 6 grooves between the clip and the end of the plunger. I hope he chimes in on what he replaced. Did he replace just the tensioner or the chain and the chain wear pads as well as the tensioner?
    I believe the maximum number of adjustment grooves is 10. so that would mean I am at 70% of the maximum. I think I am going to go ahead and order all the components necessary to replace the tensioner, chain and wear pads. This pretty much sucks for an engine with 45K miles......
  39. #759
    Feb 24 2004
    Minneapolis
    ^^^Was CharlieBrown's picture taken right after he swapped it out?^^^ I ask because your tensioner is only one groove past his.
    The problem with the original tensioner was that the plunger would slip back in. The other problem that happens is that the chain stretches until you run out of tensioner travel. I think that's your concern and if your tensioner is just one groove past CharlieBrown, I think your chain would have to stretch quite a bit more before your tensioner runs out of travel.
  40. #760
    Nov 17 2010
    In several pic's I've looked at, the clip is in different positions, including the two in your post. The length of the piston however is constant, so I would tend to think that the ridges past the end of the body are key rather than the position of the spring clip. I've seen a photo's of new chains and tensioner that show the edge of the tensioner on ridge 1 or 2.
    Your's is on the third ridge past the body and I would think you are fine. I have also read that an Audi shop noted on a customer invoice that "spec" was ridge 7 and I assume that would also mean showing past the body.
    Good idea to get some consensus on this.
    2011 A4 Avant
