Page 23 of 55 FirstFirst ... 13212223242533 ... LastLast
Results 881 to 920 of 2167
  1. #881
    Established Member Two Rings IbisB8.5's Avatar
    Jul 07 2016
    I bought the car used at 76k and now I have 114k miles. I’m not quite sure what cam phase adjustment is, I’ll look into that.
    Ok so I have a little bit more time, I’m getting over active duty this week so I have some money to buy the parts, I’m be doing this myself. Just wanted to make sure I want about to blow up now
  2. #882
    Jul 21 2004
    South Florida
    Quote Originally Posted by IbisB8.5 View Post
    If you could access vagcom, obdeleven, carista, etc you can read your cam phase and it would be helpful for us to see
    https://www.audizine.com/forum/showt...ser-adaptation
    2018 Audi S5
    Gone-
  3. #883
    Nov 23 2009
    NYC, US
    How bad is this!!?? MY2013 Attachment 58734Attachment 58735Attachment 58736
    Is it easy to check the tensioner condition? Do you need to remove the bumper in order to get to that hole? I briefly tried to locate that hole on my car. But I couldn't find it.
  4. #884
    Feb 24 2004
    Minneapolis
    Go up from below. Pull the belly pan and the plug is in that lower, metal cover. Once you pry out the plug, you'll need something like a dental mirror to see in there. I think some guys have just snaked their phone up between the radiator and motor and snapped a pic. It's not that hard.
    11 A4 Q, Prestige, Black
    207,000 miles, APR Stage 1
  5. #885
    Nov 23 2009
    NYC, US
    Quote Originally Posted by mtroxel View Post
    Great thanks!
  6. #886
    Jul 07 2016
    THE Timing Chain Tensioner Failure Thread
    Quote Originally Posted by bhvrdr View Post
    Not sure what they mean...any help would be great!
    Thanks guys!
    Car is at idle in the picture as well
  7. #887
    Feb 24 2004
    Minneapolis
    Thanks IbisB8.5. So this picture below equates to -5.84° phase adjustment. I think we're coming to the conclusion that anything around -6.00° or higher is a stretched chain at risk?
  8. #888
    Jul 07 2016
    Ok thanks for the info! So I should change it as soon as I can I guess, but I have to drive from Jacksonville, NC to CT....I should be good right?
  9. #889
    Veteran Member Four Rings wkhanna's Avatar
    May 12 2017
    finally got cleaned so i moved
    Land of Archaic Anachronisms
    sorry for the spam.....
    reaching out to @reignmaykr
    he pm'd for advice regarding how to cope with the dealer & AoA, but his mailbox is full.....
    Billy
    Practicing Curmudgeon & Audio Snob
    2011 A5 2.0T Old Man Project
    Philips SimplyGo Mini o2 oxy concentrator, fully optioned
    Drive Med Walker, BBS, Brembo BBK, Kenwood 8 Track
    Avatar Chart
  10. #890
    Jul 07 2016
    Hey guys, so this might be a dumb question but from looking at ECS’s website what timing chain kit would I get for MY2013?
    Thanks in advance and for your guys input
  11. #891
    Nov 23 2009
    NYC, US
    Do anyone know that you can check your timing chain condition through OBD2/VCDS port? Someone who is an Audi master tech plugged in and looked for me. Mine shows zero. He told me the timing chaining is stretched if the number is -2, -3 and really needs to be replaced if it shows -4 or -5.
    I have a 2010 A4.
  12. #892
    Aug 17 2015
    California
    Quote Originally Posted by AutoRacer100 View Post
    I have a 2010 A4.
    Yes. Kind of. Read through this thread:
    On a 2010 you should go ahead and get the tensioner, chain, and guides replaced ASAP. It doesn't matter how much stretch you have because the tensioner can snap at any time and cause catastrophic damage.
  13. #893
    Nov 23 2009
    NYC, US
    Quote Originally Posted by A4x View Post
    The screen shot in the thread linked is not the one I have seen when the guy show me on his laptop. The number isn't representing in degree. But thanks for the link.
    I think it will be a good reason for me to get a S4 if my tensioner snaps.
  14. #894
    Sep 21 2011
    B8 A4, CRV
    Boulder, Colorado
    OK....... I am getting ready to tackle this job so just need a parts update.
    Cut to the chase, I am getting all new part numbers for the Primary and secondary chains for my 2010 A4 Avant-
    Primary Old -06k109158AD New -06k109158BE
    Secondary Old -06k109158A New -06k109158BS
    Secondary tensioner has a new # -06H109467AR old # -06H109467A
    Anybody want to clarify this and have one to compare to the old chains, seems these #'s have been updated on other parts sites as well?
    The Cambridge I have ends in "J" new one now ends in "K"... old on was like $100, new one is over $200..... anyone know if its a complete redesign? I had mine changed
    when it when in for stage 2, has about 20k on it. Should I sit on it for another 45K and check if the screen poped out or just replace it now?
    The balance shafts, any maintenance for these or is this something to do when the head is off the car? My engine is fine with 73k on the clock, I just want to get the timing chains and tensioners
    updated.
    Any help with this would be great as I am ready to order these parts.
  15. #895
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    06K109158BE for the upper, looks like it was revised AGAIN (primary chain) and 06K109158BS for the balance shaft chain, also looks like it was revised yet AGAIN. 06K109467K for the primary tensioner, balance shaft tensioner which is not needed to be replaced is 06H109467AR. You shouldnt need to replace the cam bridge at all. Pull the remaining parts of the bridge particulate screen out of the cam bridge itself and leave it empty. Long as the check ball doesnt fall out its fine. That's what I did on mine.
  16. #896
    Sep 21 2011
    B8 A4, CRV
    Boulder, Colorado
    Quote Originally Posted by Spawne32 View Post
    Spawne32, thanks for clarifying! I'll get these parts ordered up this week and get the job done!
    BTW, I enjoy your posts as well as all of those who have contributed their knowledge to this timing chain issue.
  17. #897
    Veteran Member Four Rings BeerBrent's Avatar
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    Google says this was posted 7 days ago. Is this a new lawsuit? Another one? I hope so!
    https://www.carcomplaints.com/alerts...-lawsuit.shtml
  18. #898
    Sep 21 2011
    B8 A4, CRV
    Boulder, Colorado
    Quick question, , in regards to the chain on the balance shafts, do you need to drop the motor? How much extra time to get that chain off? Just doing some research and haven't seen one come off in any of the DIY videos. Thanks.
  19. #899
    Nov 20 2016
    Quote Originally Posted by medvedko View Post
    http://www.audizine.com/forum/showth...-and-front-end
  20. #900
    Sep 21 2011
    B8 A4, CRV
    Boulder, Colorado
    Thanks for the vid!
    The link is huge, funny... now it's giving me pictures but before it didn't?
  21. #901
    Nov 20 2016
    Thanks for the vid!
    photobucket is a bitch lol
  22. #902
    Veteran Member Four Rings JBAeroEngineer's Avatar
    Sep 19 2012
    Capitol Area
    There's a chrome plugin...
    2018 A4 | Mythos | Prestige | S
  23. #903
    Nov 20 2016
    Quote Originally Posted by JBAeroEngineer View Post
    oh i know, i use it, alot of people dont know the work around for it though
  24. #904
    Feb 24 2004
    Minneapolis
    I hope no body is paying them. They left a mess on every message board on the internet. Now they want to get paid?
  25. #905
    Veteran Member Four Rings choppstixxx's Avatar
    Apr 24 2017
    2016 Audi Q5 3.0T Premium+/2003 Honda S2000
    Hilton, NY
    Anyone know if it matters that my 2013 B8.5 (July 2012 build date) is a flex fuel (E85) engine model? I am still gonna take a peak through the little cover window, but right now I currently have 60k miles. Rather just get a job like this over if needed before it's too late.
    2020 Manganese Gray Metallic VW Arteon SEL Premium R-Line
    2003 Berlina Black Honda S2000
    2004 Crownline 202 LPX
    2016 Glacier White Metallic Q5 3.0T Premium+ S-Line 1 of 589 *RIP*
    2013 Moonlight Blue Metallic A4 Quattro Premium Flex Fuel 1 of 519 *RIP*
  26. #906
    Veteran Member Four Rings Elliott's Avatar
    Oct 28 2007
    Ocean Beach, CA
    This guy took 7 minutes to complete this job?
    lol I can do it in 6.
    CEO and General Manager of the AZ Pedal Responce Team
  27. #907
    Dec 13 2015
    Too%20many%20
    PA
    Dunno if you bought your parts yet, but I'm getting ready to do this job as well on my kid's 2012 w/87k miles.
    I bought both chains (latest versions, BE, BS), both tensioners (K, AR), cam bridge (K), all six guides, top cover gasket, intake cam seal and a new bolt ... $651.11 from audionlineparts.com
    I asked ECS and they couldn't even come close on pricing. I wanted to stay with "Genuine Audi" parts in the event one of these class action suits ever pans out. I ordered a new lower cover (Elring) from China via eBay, about $70.
  28. #908
    May 08 2018
    DC
    Hi,
    I have a 2011 A4 Premium + with 110k miles. Pulled my service history through the dealer:
    Serial No.
    Labor Operation
    Description
    Maintenance Paint Casual Package Part
    Engine complete removed+reinstalled Pistons removed+reinstalled
    Test drive .
    17160299
    OIL CONSUMPTION PART 2
    28202399 Parts items
    IGNITION COILS REMOVE+INSTALL
    17261913 24702599 17160199 13741963 13751913
    Pressure regulating valve rem+reins SVM UPDATE
    PART 1 OIL CONSUMPTION TEST Crankshaft seal,pulley end rem+rein Crankshaft vibration damper rem+rei
    01320000 15331914
    Technical check .
    Chain housing cover removed+reinsta
    This is what my dealer is saying:
    " it doesn’t look like the timing belt was performed. The timing belt package runs about $1800-2000 for the repair."
    I got the car used at 94k, was wondering since I plan to keep it for 1-2 more years whether i should get it done?
  29. #909
    Veteran Member Four Rings pierreb's Avatar
    2020 A4 allroad
    NH
    Quote Originally Posted by acea4q View Post
    Hi,
    Serial No.
    Labor Operation
    Description
    Test drive .
    17160299
    01320000 15331914
    Technical check .
    Yes. And when you sell it you can point out you had it done and ask for a premium for it, recouping some cost. I would have it done at a german car specialist indie for cheaper than dealer.
  30. #910
    Mar 26 2012
    Charlotte, NC
    Hello Guys,
    Do I need to replace my secondary chain or only the main one fails?
    Mine was replaced at 106,000km 3 years ago. Now I'm at 150,000km
    Looking at the notes I see this is what it was replaced by
    Chain# 06K109158AD
    Tensioner# 06K109467K
  31. #911
    Veteran Member Four Rings jfo's Avatar
    Nov 17 2010
    Courtenay, BC, Canada
    Quote Originally Posted by SDF1 View Post
    Hello Guys,
    Chain# 06K109158AD
    I can't recall seeing any reports of wear issues with the lower chain, although some have done it "while in there". The timing chain is quite long and has lot's of link pins which can result in enough cumulative wear over time to cause problems. It would seem that stretch in the shorter lower chain would be much less over time and less likely to cause major problems. Just my theory though.
    2011 A4 Avant
  32. #912
    Established Member Two Rings studioRS's Avatar
    Jul 19 2013
    So Lake Tahoe
    Chiming in with positive notes.
    2012 Audi A4 Avant 2.0T, 146,706 miles
    Original engine, timing chain and tensioner
    Build date on VIN 12/11
    Build date on Car Data PR code dump 02/01/2012
    This is my 12th Audi quattro and a 2012. Total keeper — Prestige, S-Line, sport package, factory Audi 19" rotor rims, Glacier White Metallic.
    Just bought this, only put on 700 miles so far. Immediately scheduled engine timing chain, tensioner service. No service history records from Audi having any of the timing chain or tensioner replaced, only water pump replaced at 85k miles. Engine runs great, no bad sounds, pulls strong.
    Measured last week through VCDS
    Camshaft adaptation intake bank 1: phase -7.91
    Good thing I scheduled this.
    Talking with tech this morning, tensioner was at limit — totally maxed out! He noted we were SUPER lucky. Chain was stretched, guides didn't appear to be too worn at all. Balance shaft chains, tensioners looked fine. Every timing chain tensioner job he does, replaces the camshaft bridge. He's never seen a bridge with the screen intact. Mine was one of these, but fortunately, screen parts were there in the journal and recovered. Used all factory Genuine Audi parts, including a new serpentine belt.
    Just picked it up this morning, all buttoned up, runs great, smoother and tight. Love this Audi B8 A4 Avant, everything about it, styling, ride — Audi does the best job of designing a complete package. While it's no where near as fast as my 2002 S6 Avant, it is a newer, more refined Audi than than the S6 (which by the way, is for sale). While the front was off, I had them drop in some new DS3 Phillips HID White Vision 5000k HID bulbs, figured it was a good time to do that! (Note: three guides were replaced, only recovered two from the bin to snap off the photos).
    2016 Audi SQ5 Glacier White Metallic, technology & black optic packages
  33. #913
    Feb 24 2004
    Minneapolis
    Quote Originally Posted by studioRS View Post
    This is really good info. This helps confirm what we've been seeing. If the phase adaptation is up around -7.00° you might want to locate your panic button.
    On top of it all, you had the old style tensioner with the metal band that used to slip out of place no matter what the chain stretch.
  34. #914
    May 25 2017
    2010 A4 Avant
    Vancouver, WA
    ^ It's a little reassuring that you got 146,000 miles on it before replacing. I want to get mine done, but dont have the $$ right now. I'm at 70,000 miles.
  35. #915
    Mar 26 2012
    Charlotte, NC
    What is the phase with the new chain?
  36. #916
    Jul 19 2013
    So Lake Tahoe
    Good question. I'll get a chance to check this after a good long drive from Vermont to Florida and back =).
    I'll have to plug in at the shop, on a weekend. Currently I have the older KII+ VCDS cable (for my C5 S6) and need to upgrade to the latest cable.
  37. #917
    Feb 24 2004
    Minneapolis
    Just remember, take the reading with the engine warm and it's been running for a minute or two. Otherwise you'll get a 0.00° Reading which is false. Most of us have been slightly + after a new chain.
  38. #918
    Jul 19 2013
    So Lake Tahoe
    Good tip, thank you. Yes, the only time I've taken the reading (photo and note above) was at operating temp and an at idle.
  39. #919
    Apr 24 2017
    Hilton, NY
    Took a peak at my 2013 (July 2012 build date) view port, (thank god) I have the revised tensioner. I’m at 62k miles and looks like I’m down to the 5/6th tooth, this seems about half way down IIRC?
  40. #920
    May 12 2017
    damn!
    yinz guys are like pro photographers!
    Billy
    Avatar Chart
