Results 1 to 40 of 63
    Established Member Two Rings dogears's Avatar
    Sep 05 2014
    Anyone use Carista or ODBeleven for coding?
    UPDATE - It works
    So, I really want to enable the lap timer and gear indicator functions on my 2016 S6. I still have my BMWhat Bluetooth OBD adaptor from my M3. Yesterday I purchased the Carista app and it does connect with my adapter. Lap Timer is listed for coding and I enabled it. However, it did nothing. Tried it a couple times. (EDIT: Doh...was not aware of exactly how to view it. It does work!)
    Has anyone used the Carista app successfully? Do I need their adapter? The ODBeleven seems to offer more features, like the gear indicator.
    Any advice other than buy a Ross Tech VAG-COM cable?
    Lastly, is anyone in the Cherry Hill area with a VAG-COM? I'd pay a few bucks to be able to enable these features.
    2016 Daytona Gray S6 w/ Arras Red Designer Interior, Sport Package, Black Optics, Bang and Olufson, Driver Assist, Night Vision, and Cold Weather.
    May 19 2016
    Wethersfield, CT
    I used Obdeleven and it works like a charm. I was able to successfully enable gear display in the lap timer mod e. I haven't had any issues with Obdeleven.
    2013 Audi A6 Prestige
    2002 Audi S6
    1995 Audi S6 (retired)
    Jun 23 2011
    Toms River, NJ, USA
    I used Carista, and it kept failing for me. Every time I connected my dongle, I'd get a different set of available options to enable. After many tries, I was finally able to activate the hidden MMI menu and put my windows / sunroof down with the key fob. Nothing else worked for me.
    My friend suggested signing up for the beta app, which may take a day or so to activate. Once signed up, you get access to the beta Apple or Android installer. It has a couple more options and better compatibility, apparently.
    Sep 05 2014
    Carista worked! All I need to do now is enable gear display. Lap Timer working. I emailed Carista about whether they can enable that feature.
    Mar 21 2015
    Quote Originally Posted by dogears View Post
    They don't support the gear display. I used vcds for that one.
    Sep 05 2014
    Yeah I figured that. I emailed them about making that feature available.
    Question, does the D and S gear choices show in the HUD when in lap timer mode, or just in the dash?
    Mar 21 2015
    No HUD for me man, dont know.
    May 19 2016
    Wethersfield, CT
    D and S show up for me in the HUD, as well as the gear number. If I recall this was another option I set.
    All done with OBDELEVEN. Couldn't be happier with the product.
    2002 Audi S6
    Active Member One Ring danfzx14's Avatar
    Feb 25 2016
    2011 Infiniti G37XS, 2008 ZX14
    New Hampshire
    Does anyone know if you can change the adaptive cruise control preset distance with the OBDELEVEN?
    Moonlight Blue Metallic w/Nougat Brown Interior, Black Optics, 20" Sport, Driver Assist, Night Vision Assist, Cold Weather
    Focal 165 KRX3 Front Speakers, Focal 165 KR2 Rear Speakers, Enclosed JL Audio 10W6v2-D4 Sub, Mosconi 6to8 V8 DSP Processor, JL Audio HD900/5 Amp, JL Audio HD600/4 Amp, Stock Sub Removed and Rear Deck Dynamatted, Compustar Dash CD-3200 Front & Rear HD Surveillance Hardwired, Compustar RF-2W1B-SP Remote Start, 3M/Xpel Clear Bra (Hood, Fenders & Front Bumper)
    Aug 11 2016
    CA
    For what's it's worth I've been very happy with my VCDS wifi unit from Ross Tech but at literally 10 times the cost of the Carista.
    The pricing on the Carista app is obviously much much less and seems pretty capable.
    Look forward to seeing more people share results.
    Veteran Member Three Rings R3.'s Avatar
    Nov 03 2016
    Dallas,TX
    I just ordered the carista adapter. I have the OBDLink MX but it's not compatible even with a firmware update. That bummed me out.
    2016 S6
    2013 A6 3.0T Sold
    Registered Member One Ring sdouet01's Avatar
    Apr 17 2012
    Summerville SC
    I have had great success with ODBEleven enabled lap timer, window control from Fob, and did the start stop button inverse all worked really well.
    2014 A6 3.0T Prestige
    Sent from my LG-H810 using Audizine mobile app
    Nov 03 2016
    Dallas,TX
    Got the carista app on yesterday. Used it to change a few things. I was able to turn on the gauge sweep easily.
    https://youtu.be/U8pg_1XjJlk
    2016 S6
    2013 A6 3.0T Sold
    Veteran Member Three Rings Frenetic's Avatar
    Dec 13 2015
    '17 Audi S7
    CA
    I guess I need one of these to enable the lap timer.
    Anyone else use OBDeleven?
    Can anyone post the exact screens and menus to turn on the lap timer in OBDeleven or Carissa?
    This is my first Audi so I'm not knowledgeable in any of these.
    Thanks.
    2020 BMW X5 M50i | 2017 AUDI S7 (gone)
    Veteran Member Four Rings IowaRS7's Avatar
    Mar 22 2017
    69 Camaro SS
    Iowa
    OBDeleven is minimal cost to purchase and then you buy credits, like an in app purchase, to use pre-built programs for many of the changes you want to make. One can also make changes manually. For example I used it to enable VIM with the push of a button instead of having to go through a sequence of steps. I had purchased VCDS first then found I couldn't do some things with it and found OBDeleven. May have still bought VCDS anyway to have but I have been pretty impressed with OBDeleven.
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    Quote Originally Posted by IowaRS7 View Post
    What can OBDeleven do that VCDS cannot, or what could VCDS not do that you wanted?
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Mar 22 2017
    69 Camaro SS
    Iowa
    Quote Originally Posted by GilliamOS View Post
    On my 16 RS7 I could not activate VIM or the green menu with VCDS, but OBDeleven it was simple.
    Mar 22 2017
    69 Camaro SS
    Iowa
    It may be possible at some point with VCDS, but the security codes are unknown, that is unless someone has figured out by now. The various password generators didn't work for me, so I just picked up OBDeleven.
    It uses Bluetooth and is easy to use. My only gripe is that there was only an Android app and not Apple.
    May 26 2015
    Mormon Country
    Interesting, I could not enable VIM either using the known login code generator, but it wasn't a pressing matter for me.
    2000 A4 1.8T - Sold
    1987 Maxima - Sold
    Dec 13 2015
    '17 Audi S7
    CA
    I think I may just buy the Carista.
    I literally just want the lap timer, that's it.
    Anyone with the Carista been able to do that?
    Senior Member Two Rings moonlights4's Avatar
    Jan 11 2014
    2018 S4
    Kansas City
    Quote Originally Posted by Frenetic View Post
    Yep. Have done it in my car. Was super easy, and exactly why I bought it as well.
    2018 S4 Prestige, S Sport, DAP, Dynamic Steering, Cold Weather
    Past Cars:
    2014 S6 Prestige, APR Stage 2 ECU/TCU, APR Downpipes
    2014 S4 Prem+ DSG
    2013 S4 Prem+ DSG
    2010 Q5 Prem+ 3.2 V6
    Dec 29 2016
    south
    I have OBDEleven and love it. I have not used any of the apps yet as I was able to make all the changes I wanted via manual coding using the instructions I found on this forum for VAGCOM. There is a thread that links to a word document containing instructions for all possible coding changes. Some that I did are as follows: lowered air suspension 15mm: increased DRL LED brightness when headlights are on; keep DRL on when blinker is on; taillights on during the day; activated gear indicator when in drive; cleaned up headlights and taillights by disabling the yellow/red side lights; and enabled lap timer. I plan on using their app to enable VIM soon. Best $60 I have spent and highly recommend their product. If anyone needs assistance PM me.
    Senior Member Three Rings ClaudeG's Avatar
    May 27 2017
    2023 Audi Q7 3.0 | Daily 2006 Mazda Speed6
    Santa Clarita
    I have Carista! It worked better on my MK VII than it does for my C7. However, the plus side is that they update it and I'm hoping that with updates it gets better.
    I have been tempted to get OBDEleven as from what I have seen, you can do more with that, than with Carista. Downside is that I have an iPhone and OBDEleven is strictly Android based.
    2016 S6 Prestige, Sepang Blue, Black Optics, Lunar Silver Interior | APR TUNED: APR Stage II, TCU Tune, APR DP and Exhaust | VMR V802 Matte Bronze wrapped in 275/35/20 | Silly Rabbit Intake | NeuSpeed SS Brake Lines | Lowered via OBDEleven | JL Audio XD7005V2 | JL Audio 10"W3
    GONE BUT NOT FORGOTTEN 2017 A6 3.0 Prestige, Brilliant Black, Black Optics
    Project Car soon to be Daily... 2006 MazdaSpeed6
    Dec 13 2015
    '17 Audi S7
    CA
    Thanks. I just ordered the Carista. All I really want is the lap timer and seeing how others have confirmed it can be done with it, that's what I'm getting since I don't have an Android device anyways for the OBDEleven.
    May 27 2017
    Santa Clarita
    Yea, the lap timer, needle sweep, LED brightness are all easy to do w Carista, plus for the price, its a no brainer.
    Dec 29 2016
    south
    Quote Originally Posted by ClaudeG View Post
    I had the same issue, as my family only has IPhones. I ended up buying a cheap Amazon fire tablet for $50. It allows me to use OBDEleven, and when I am not using the tablet my 5 year old has another toy to play with.
    May 27 2017
    Santa Clarita
    Quote Originally Posted by BigTex View Post
    NICE! Good to know! The only thing I hate is that it takes 5-6 weeks. My cousin has his own shop, I want to see if his computer has ability to do the same mods before I go spending more money.
    Dec 29 2016
    south
    I received the OBDEleven dongle within 3 business days of ordering it from a U.S. supplier (Deutsche Auto Parts). Tablet even quicker due to Amazon Prime.
    Dec 13 2015
    '17 Audi S7
    CA
    Well that was easy.
    I ordered the Carista from Amazon, same day delivery and got it last night.
    I plugged it in this morning, turned on my ignition, turned on the app on my phone and it synced for about 2 minutes (I didn't have to do a thing). I then had to subscribe $39 for a full year (the other option was $9.99 for a non-renewing month), but it won't charge me until after the first month for a trial period.
    I turned on the lap timer and turned up the DRL while driving to 37%. I didn't get a chance to review all the other customization options, but it took all of one minute to do that.
    For my simple needs, this works just fine. There were many other customizeable items that I'll go through later.
    Edit: Well, I couldn't find the transmission gear indicator. Maybe I wasn't reading it correctly, but I saw nothing in any of the customization menus that turned this feature on. So, that's one limitation.
    Aug 11 2016
    CA
    Frenetic - glad it's working out for you! That's a great deal. For perspective I paid $449 for my VCDS from Ross Tech.
    May 27 2017
    Santa Clarita
    That one isn't on there. I play with it all the time. The good thing is that as they release App updates we get more to play with.
    I have been wanting to leave my LEDs on with the blinker, and its not possible with Carista (not sure if its possible at all with the C7.5). And I would also love to be able to get the sweeping on the turn signals
    Dec 29 2016
    south
    LEDs on with blinker is possible on c7.5 as I coded mine to do so. I believe sweeping turn signals require different coding and hardware, but I may be wrong.
    May 27 2017
    Santa Clarita
    Nice! Good to know! I ended up ordering an ODBEleven as well, it seems more can be done with that than with Carista, and I am gonna borrow a tablet from a cousin. :)
    Dec 29 2016
    south
    If you need any help with coding send me a PM as I would be happy to help in any way I can. The only app worth buying credits for is the VIM as all other modifications you can code manually in less than 5 minutes.
    Aug 11 2016
    CA
    Does Carista do VIM?
    Mar 22 2017
    69 Camaro SS
    Iowa
    Quote Originally Posted by gta7 View Post
    The only thing that I found to do VIM on my 16 RS7 was OBDeleven and I was successful with that. It's nice to have for the kids!!
    Aug 11 2016
    CA
    So what do you do put movies on an SD cars or just straight from the DVD player?
    I have little ones too and they like the occasional movie.
    Veteran Member Three Rings 4Chio's Avatar
    Mar 14 2005
    STL
    I have both! I used carista for my A6 and got the OBD11 for the S4 and q7 because carista does not support them
    2018 S6 Prestige ,sport, JB4
    2014 991 Cab C4S
    2018 S4 Prestige
    2017 Q7 Prestige
    (sold)
    2016 S3 Monsoon Gray Prestige | Sport seats| 19's W/ mag ride| Milltek Res valve
    2013 X5 M, 08 A6 4.2 Sline, 08 :.R32 ,07 S4 White/Black, 04 S4 6MT,
    Mar 22 2017
    69 Camaro SS
    Iowa
    I have only played from the discs thus far.
