    Active Member Four Rings alien_brain's Avatar
    Jun 04 2013
    SE MI
    need help with my 01E part list
    ok so i have an FTQ 01E with matching rear diff, and thats all. i wonder if anyone can help me put together a list of parts i need to make this work. i suppose i need a shift box and connecting arms, an appropriate drive shaft and some front and rear axles. can anyone help demystify this?
    thanks.
    Jun 04 2013
    SE MI
    ok so are all 01e shift box and actuator arms the same? do i need a specific one for this trans? also are all rear drive shafts the same for b6 a4? i assume i need a cross member. this trans was in an a4 so i think the front and rear flanges would be the same as what i need.
    anyone wanna confirm some of this?
    Sep 16 2010
    Central Wash
    Quote Originally Posted by alien_brain View Post
    I'm pretty sure the 01E transmission itself is the same for swap purposes. But there are a couple / few different versions of the shifters and linkages. I can't do a breakdown by memory, but I'd say when you buy the shift linkage, make sure you get a complete shift box with the linkage complete from one car. Then the linkage problem should be taken care of. Also, check the VSS place on the side of the trans, above/next to drivers side axle flange? The B6 had that change of where it got vehicle speed , at the axle vs. from the ABS unit. Also check the placement of the crank position sensor. I don't know why..for some reason it seems like I've read something about that being different either in dimension or placement.
    But, aside from the trans/ rear diff I'd just go off the usual 01E swap parts list and use everything else from an A6..it's around here somewhere..
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    I got lucky and bought a complete kit from a 06 S4. If I had to piece it together I probably would have given up.
    Good Luck!
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Jun 04 2013
    SE MI
    thanks you guys. no it came from a european allroad, was put into an a4 and the interior of the car burned. i got the trans and rear diff before i knew i should have gotten everything from the same car.
