Results 1 to 13 of 13
Thread: LPFP upgrade
    Feb 18 2014
    toronto
    LPFP upgrade
    Hi there,
    I need to replace my Low pressure fuel pump and it seems like the DW300 is the way to go. Can anyone provide a buy link because there are different models available.
    Or if there are other options let me know.
    2008 B7 2.0T 6MT QUATTRO S-LINE
    Veteran Member Three Rings StatusQuo's Avatar
    Jun 15 2016
    Northern California
    Quote Originally Posted by jubegnx View Post
    Hi there,
    You might wanna look at getting a stock fuel pump instead. The biggest reason is because you will lose your surge capabilities.
    If you need to upgrade down the road then just get an RS4 controller. This will increase the voltage to the pump to make it flow more.
    B7 Audi A4 Quattro - Built. Not Bought.
    Upgraded HPFP | RS4 Injectors | RS4 LPFP Controller | 175 Bar PRV | 50/50 E85 | Straightpipe Exhaust | Cold Air Intake | Big Turbo | Front Mount Intercooler | -- The Maestro Community Project --
    Feb 18 2014
    toronto
    Quote Originally Posted by StatusQuo View Post
    I will keep this in mind. So the controller is what needs to be updated when adding power?
    Jun 15 2016
    Northern California
    This is correct. The stock fuel pump is good for around 400hp. I have not personally tested it's limit but that's what I hear.
    Upgrading the controller should make pump good for 500hp+
    Also note that you will need to make sure your tuner is aware of the controller upgrade as the tune will need to be adjusted.
    Jun 17 2013
    jersey city nj
    Just wanted to clarify that ing a RS4 lpfp controller does not add current to the lpfp. Nor does it increase the flow of the stock lpfp. All it does is brings down the duty cycle threshold so it doesnt trigger a cel and code p0089 and throw it into limp mode when your ingunder wot. memberSeal66 has a ed TT-RS lpfp that he runs for his E85 tune with a KO4. If you really need a lpfp you can pm him for more details
    APR KO4, APR HPFP,RS4 LPFP Cntr,145 bar PRV, APR TP, TT DP, GFB DV+, AWE FMIC, BFI CC, AWE Exhaust, RS4 Exh tips, ST CO, 034 RSB,034 St Dnsty Mtr Mts, New Sth West Bst guage, B7 RS4 8 pot Calipers.Goodridge SS brake lines frt & rr. Hawk HPS frt & rr. RS4 PS rack, RS4 Servotronic Relay,RS4 rims. S4 mirror caps,DTM frt bmpr and rs4 fogs,LED tail lites
    Jun 15 2016
    Northern California
    Thanks for clarifying. Learned something new today ha.
    Jun 17 2013
    jersey city nj
    NP. Thats what we at all are here to do. We learn from each other.
    Dec 23 2011
    I'll be attempting to install the dw300c pump in my stage 3 setup. So will CanadianA4B7.
    Feb 18 2014
    toronto
    Quote Originally Posted by p0isin View Post
    Do you have a link for that pump? Because on their website I'm getting DW65v is the one for 2.0fsi engines.
    Dec 23 2011
    I'm on mobile but here is the raw URL. It has a higher flow rate vs the dw65.
    HTTP://www.deatschwerks.com/resource...fuel-pump-tech
    Feb 18 2014
    toronto
    K thanks. Can you post back when you're done the install, il be doing this as well.
    Dec 23 2011
    Will do. I'll hopefully have some time in the next few weeks to work on it.
    May 09 2012
    Virginia
    I know the DW pump is significantly cheaper but both APR and USP advertise a higher flowing pump. No details of the pump listed on the respective websites however.
