Originally Posted by
MRPANDA
Looking into a new project car.
Will definitely be tuned.
Trying to determine differences between an A3 & S3 given my plans, which include:
Stage 3+ Engine Mods
Upgraded DSG clutchpacks/TCU tune
Upgraded brakes
Aftermarket suspension (sways/springs/shocks)
Aftermarket wheels & tires
Given the changes I plan to make, would a lightly used A3 at approx $28k make sense, or a lightly used S3 at approx $38k?
Aside from nicer seats and a nicer front bumper - is there anything from the S3 that I wouldn't have in the A3 after the planned modifications?
Any other thoughts would be very helpful. I'm leaning towards A3 + $15k in mods - but I'm not sure if there's something I'm overlooking seeing as I don't know this platform well.
Lots of info available if you search. If you're planning on going stage 3+, the S3 is the safer bet for longevity.
The most significant difference between the S3/R version of the engine between the A3/GTi version is likely the unique high temperature aluminum-silicon cylinder head. It's supposedly extremely resilient to repeated high temperature stress. On top of that, the S3/R engine has upgraded forged connecting rods, wrist pins, a forged crankshaft, strengthened engine cover, on top of sodium filled exhaust valves, and a number of smaller tweaks.
Folks unfamiliar with the extreme and complex mechanical stresses involved in high output forced induction applications will write those changes off, but there's engineering science behind them at stock power levels, let alone tuned or turbo swapped. There's a reason APR torture tested the stage 3 kit on an S3/R engine. Till date at upwards of 550HP, there have been no reported failures on the stock S3/R engine on any of the forums.
Does that mean the A3/GTi engine can't handle that power? Not at all. The E888 is still an iron block motor, it's stout and reliable. That said, long term longevity at high output - the S3/R version is the more robust motor, end of story. The extra cost more than offsets the cost of doing all of those changes manually, not including any superficial interior/exterior differences.
Short version - the S3 was purpose built and engineered for performance, if that's your goal, start with that.
