    Established Member Two Rings artz66's Avatar
    Jan 04 2016
    Illinois
    New daily driver. Picked up a A4 1.8T
    Well I decided to give the whole Dave Ramsey thing a try and today I picked up a 1 owner 2002 Audi A4 with 155k for $2,000.00. It needs some work but I figured I did most of the stuff to my S4 so I should be good. Tonight I ordered timing belt with tensioner, pads, rotors, oil, oil filter, water pump(figure might as well change it), test pipe because the cat is clogged up, and driver side window motor. Other than that it is a really clean car. Interior is immaculate and the exhibit isn't bad. The front fenders are starting to rust s bit but I'll fix that later on. I'll probably be lurking in this section now.
    Old car
    New car
    I'm still keeping one fun toy
    Jun 02 2016
    San Angelo, TX
    Seems like a good deal. Are you sure it's the driver side window motor, and not the regulator?
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Jan 04 2016
    Illinois
    Yeah I've torn the door panel off and voltage tested it. It's shot and I got a used one pretty cheap so if it doesn't work I'll just sell it and try again.
    Established Member Two Rings Bobby417919's Avatar
    Mar 14 2010
    Concord, NC
    Nice, don't forget to remove the front plate bracket.
    Jan 04 2016
    Illinois
    Quote Originally Posted by Bobby417919 View Post
    I actually thought about using it but I have no idea where my front plate is.
