I don't recall the actual code that was shown when the shop's laptop was plugged into the car.
The tech said that it's "lacking boost"or "it's under boost".
Just a few weeks ago, I had the shop replace the diverter valve (OEM).
Since it's the wife's car, I don't really spend as much time on it as I do on my own car. But I'm still learning about maintenance, repairs, and mods on the car. Thank goodness for the Audi forum, right?
I'm planning to have the shop diagnose the check-engine-light soon. Unfortunately, they're booked. And the earliest appointment is on June 29th (Audi / VW Performance shop). Therefore, I'd like to start gather ideas and potential solutions in case I'm able to fix it myself.
The car does feel a bit sluggish upon normal take off from a complete stop. I guess the best way to describe it is... it "feels like it's struggling". Might not be as bad as it sounds, but that's the best description I have.
If you have ideas, suggestions, or opinions, please feel free to throw them my way.
I have a long list of items to get done to the car (maintenance-wise), and this added issue is definitely bugging me (...and the wife).
Thanks in advance.
Repairs / mods already done...
- Transmission service
- Diverter valve
- Purge valve
- Valve cover gasket
- PCV gasket
- Spark plugs
- Coil pack
- Oil changes
- Drilled front rotors
- Akebono front pads
- Stigan turbo (with gaskets, bolts, etc.)
- Turbo cut-off valve (twice)
- Paint correction
- White LED city lights
Repairs to be done...
- Replace rear rotors (maybe)
- Replace rear pads (maybe)
- Flush brake fluid
- Replace cam follower
- Replace engine oil cap ring
- Replace air filter
- Replace crankcase valve gasket (still trying to confirm if it's leaking)
- ...there's more. I just can't remember the rest at the moment.
Mods I plan to get done...
- Tint
- Crank pulley
- APR tune
- Front license plate delete
- RS4 wheels (replicas)
- Spacers all around
- Lowering springs (just enough to minimize the fender gap. Wife doesn't want it "that low".)
- Opt7 LED headlights (currently have halogens. Considering to swap into projectors.)
- LED fog lights
- Rear diffuser for quad tips
- Quad muffler tips
- Xpel clear bra
- Upgrade to OEM navigation system & add back-up camera
- Replace climate control (current one is peeling)
- White license plate bulbs
*** Update as of 6/19/16 ***
I was at a red light this morning. As soon as the light turned green, I left off the brake and gently pressed on the gas. The engine revved for two seconds then engaged / jerked forward and slowly started to move forward. The car was really hesitating and struggling up till about 40 mph. It happened during the next 4 complete stops I made.
After making it to my destination, I was out of the car for about half an hour. Then when I drove it home, it did the same thing. Except this time, instead of pressing the gas right away, I gave it a few seconds and eased on the gas. That's when it didn't really jerk anymore. It was a similar feel as if the car was going to die on the road.
Anyone experience this?
*** Update as of 6/20/16 ***
Took the car in and left it for the entire day at the shop.
Got a call saying that the turbo cut-off valve had to be replaced. It was in four pieces.
The shop owner also said that the turbo ring was replaced due to oil leaking into the inter-cooler.
The inter-cooler was flushed.
I asked him if there were any other issues he or his tech may have caught during the diagnosis. He said all looks pretty good.
He said that I have to keep an eye out for smoke coming out of the tail-pipes. If so, that would be a sign that the turbo is really bad and should be replaced (due to the 1/4 to 1/2 quart of oil that leaked into the inter-cooler.
The wife picked up the car at 4pm. She drove it back to work. Afterwards, she ran some short errands. At around 7pm, she calls me saying that the check-engine-light came back on. Argh!!! A bit frustrating. The shop offers a 2 year warrant on their parts and labor. Looks like I'm making another trip down there to see what this other problem is.
*** Update as of 6/21/16 ***
The car was brought back to the shop and diagnosed.
The shop owner said that the new turbo cut-off valve is ruined due to the massive oil leak from the turbo.
Now I'm frustrated even more and need some assistance / suggestions / opinions from those that have experience with my issue.
I've been quoted $710 for labor.
As far as the turbo itself, are there any quality options? I don't think I want to do an "upgrade" if it involves needing other upgraded parts (downpipe, inter-cooler, etc.). I'm looking for a simple direct swap.
Cost is somewhat a factor for me because I still have other necessary repairs to do.
What brand(s) do you recommend?
Are there any other very reputable yet inexpensive Audi shops that you recommend in Southern California? (LA County / Orange County)
*** Update as of 7/24/16 ***
I should have posted a final update 3 weeks ago regarding the issue that the wife's car was having. Here it is... (along with another issue / question)
OEM turbo was replaced with a brand new Stigan turbo. The power is definitely there. It's such a different feel now that the turbo now works correctly.
However... there is something that the wife told me about. Then when I drove it, I noticed it as well.
Somewhere on this thread, I may have mentioned that when the turbo was having issues, there was a heavy hesitation with the car from a complete stop. As in... it wouldn't have power till you reached 40 mph (which took a long time). That is no longer an issue. No more check engine light, no more "lunging forward" when the brake is released, etc.
What I noticed this weekend was... there's something still not feeling 100% when taking-off. There's still a very light hesitation. It's not bad to the point where there's no power. It just doesn't pull right away when you give it some gas (normally). It takes a second or two for it to kind of pick up and go. When the car is in motion, there's no problem (at least I haven't noticed anything). But it always happens from a complete stop. Is there something else that the technicians and myself could have over-seen?
Would the car react this way if I have a faulty cam follower?
If you scroll up to the top to the list of "Repairs already done...", you can see what I've completed. From there maybe I can get suggestions and/or opinions on what may be causing the minor take-off hesitation.
Thanks in advance again.
