Results 1 to 6 of 6
Thread: Coolant tank
    Aug 08 2007
    San Francisco, CA
    Coolant tank
    Is anyone selling new coolant tanks with the cap? Mine has decided to go all orange and get leaky on me.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    They are like $20. $70 or less for OEM. Buy a new one
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Veteran Member Four Rings LJS's Avatar
    Apr 08 2013
    15 VW GTI S-Very WHITE
    Connecticut
    A little FYI----DON'T go after the DORMAN garbage offered at RockAuto----Yes they're cheap at $24 but after I went thru 3 of the damn things (all replaced by Dorman) I purchased an OE item....ALL three leaked after only several months of use! The funny thing is that I changed the damn thing, originally, due to the discoloration....It was leak tight after some 14 years of use! The old adage holds true-YOU GET WHAT YOU PAY FOR!
    Jul 04 2012
    Woodbridge, VA
    I member on here mentioned an a4 tank will work and that the only difference is the drain doesn't have a 90 on it or something to that effect. Price difference was significantly cheaper for OeM
    Apr 16 2013
    Colorado
    I've got one that looks really good, oem.
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by vavJETTAw36 View Post
    yup just get an a4 tank and take the 90 degree elbow off the bottom and push it into your new tank, I bought a brand new Febi for an a4 for mine and did that.
