    Mar 05 2013
    CA
    uneven ride height
    Driver side sits lower. Any advice?
    (by half an inch)
    25.5" vs. 26" (FTG)
    I swear you can notice it. From outside the car. Inside of it. Or when measuring finger gap.
    Surely the shocks are gone at this high mileage.
    Unladen, the pass side springs look taller too.
    (pic4clicks)
    Dec 03 2009
    1991 RX-7
    Seattle/WA/USA
    Yeah I have the same problem. Only I have KW v2. Probably need a rebuild :(
    ohm mani padme hum
    Established Member Two Rings daniel B6 1.8t's Avatar
    May 31 2016
    OC, CA
    So the springs are gone......I have the same problem and the only thing I did was go with koni struts kit and stock springs and seems fairly uneven....
    Mar 05 2013
    CA
    Quote Originally Posted by daniel B6 1.8t View Post
    http://www.onestopauto.com/How-do-yo...w-springs.html
    http://www.audiworld.com/forums/a8-s...o-bad-1739325/
    May 31 2016
    OC, CA
    Thanks
