Hello Audi Gang. You may recall I had another thread going titled..."2007 4.2; suddenly ESP and EPC...all kinds of issues". We went to church one morning with no issues, then we went to breakfast and as we were leaving the restaurant, the Q7 started running a little rough. It was only a couple of miles to get home, and by the time we arrived, I had the EPC warning light on and the engine was running quite a bit rougher than just minutes ago. I decided to go ahead and clean the intake system and the valves as well. After getting everything back together, new plugs, new gaskets, etc....I hesitantly started the Q7 up. My hopes and prayers were dashed as the Audi still runs like crap! I suspected the throttle valve so I swapped it out and no change. I also did the same for the throttle pedal...nothing. All of this work did clear up the misfires I was getting so it wasn't all for nothing. But as you can imagine I'm a bit down in the dumps now. Any help is appreciated....thank you.
Using Vag-Com I did a scan and here is what shows up.
Summary of "malfunctioning" systems. I'm not so worried right now about the HVAC systems....
1) ABS Brakes
2) Auto HVAC
3) Instruments
4) CAN Gateway
5) HVAC Rear
Here are the codes:
Address: 03: ABS Brakes
Component: ESP ALLRAD MK25E1 0140
Code: 01826 Sensor for steering angle (G85) supply voltage terminal 30000
Address: 17 Instruments
Component: KOMBIINSTR. M73 H16 0070
Code: 01044 Control Module Incorrectly Coded.
Address: 19 CAN Gateway
Component: J533 Gateway H06 0040
