Hello far more intelligent mechanics than I...
Following my saga of breaking down mid trans america relocation, I'm attempting to correct my thermostat issues once and for all.
Following an overheating issues I've narrowed down the issue to the thermostat not opening/operating correctly. I currently have a gutted thermostat in the car and it runs and drives perfectly apart from a bit cold any time the ambient temps are below 80 or Im not driving like a lunatic (albiet hard autotragic).
I was hoping my thermostat issues were related to the non OEM brand and have since attempted to fit a brand new OEM unit with the same issue; overheating.
The car has all the traditional symptoms, hot upper hose, cold lower, rising coolant level in reservoir etc. Using a chemical reaction tester hopefully eliminated the possibility of a leaking head/head gasket as all of my tests were negative for mixing of combustion gases.
I have tried boiling water to test the second new thermostat but for the life of me cannot get it to open. For those that have, what are you doing to prove its functionality on a stove top?
I've been told and read the sensor is purely a warm up function and the thermostat itself is an old school mechanical unit?
Lastly where and when does the signal to the sensor originate from? Id like to throw a meter on the wires and see if there is indeed power running to the unit as it should be.
Thanks everyone, really appreciate the time and effort.
