Hi guys,
Need some insight from those smarter than me in this area. I did some logging since I was curious about the drop in boost when shifting from 2>3 or 3>4 when in WOT @ redline. The logs are showing some timing pulled up to 6 degrees in some cases. Is this due to the APR tune or perhaps because its so dang hot outside (93+, 4000+ DA)? I'm currently running the 93 file with 91/100 octane mix in the tank (6 gal 100 / 10 gal 91). I've noticed this drop in boost using the 91 and 100 files as well. No timing is pulled when just regularly cruising. Will an AMS cooler help with this? Thoughts?
