Results 1 to 9 of 9
    Senior Member Two Rings M0ve0ver's Avatar
    Jul 18 2010
    Ft. Hood, Texas
    Clear coat peel on bumper, suggestions?
    So I just noticed yesterday a quarter sized spot of clear coat peel just below my right tail light. Obviously the only way to really fix it is a replay, but what can I do to protect the area/halt the spread? I was thinking of a light clay bar, heavy wax, and covering it with a small square of clear vinyl. Any suggestions are appreciated... this peel happened on one of the headlight washer covers and the paint all came off over the course of a few weeks so I obviously want to prevent that from happening here.
    http://imgur.com/YQ1Q25b
    Dec 07 2009
    East Coast
    I'd buff and polish it extremely carefully and go over with protective paint coating of your choice like Ceramic Pro, Opti-Coat, CQuartz, Xpel, etc... Hopefully it'd help to seal it and stop from spreading. However since it started in one spot, you most likely will see more in other spots. It's just age and exposure to the outside weather elements.
    Forget the B8, keep the V8!
    Veteran Member Three Rings iparatroop's Avatar
    May 31 2010
    '23 Glacier RS6, '21 District Green SQ5, '21 Tiggy, '19 Roush Raptor
    AL
    What Mr. Wrong said, or you could just leave it in the garage and drive the MKIV in the background.
    Jul 18 2010
    Ft. Hood, Texas
    Quote Originally Posted by iparatroop View Post
    that's the TDI road-trip car, I can drive from Kentucky to Rhode Island on $50 of diesel.
    05 B6 S4: JHM 93 Tune, Trex DP, JHM 2.5" CB, JHM LWCP, Apikol snub, Bilstein PSS9, 034 Adj Control Arms, 034 Rear Sway + Endlinks, 034 front Endlinks, Team Dynamics Pro Race 1.2's, 034 wheel studs, 034 Strut Bushings, 034 Lower Control Arms, tyrolsport caliper bushings, ECS braided brake lines, Hawk HPS pads, Evo skid plate
    13 8P A3 TDI: Malone Stage 3 Tune, CR170 turbo, Rawtek DP, Malone DSG tune, Darkside Race Pipe/EGR delete, CP3 fuel pump, Panzer skid plate
    May 31 2010
    AL
    On a serious note, how often do you clay bar/polish/wax/glaze? I'm not pointing fingers, but my MKIV R has 194,xxx miles with no signs of the clear peeling. I'm pretty religious about that stuff and it sits outside.
    Jul 18 2010
    Ft. Hood, Texas
    I clay bar once in the spring and once in the fall, then wax about once a month in between regular hand washes. The car is garaged, and spent two separate stretches of 12 months in garage storage.
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    If i were i would detail with clay, wax etc. Then try using a sealant to keep from spreading. But your gonna need to respray.
    SUSPENSION-KW V3-Hotchkiss RS4 sway bars-034 Adj UCA-034 strut mount-034 F&R end links-034 motor mounts-034 Snub mount W/bracket-034 Trans mount l BRAKES-ECS Stage 4 BBK-ECS rear rotors & lines, Hawk pads l Engine-JHM Tune-JHM 6 rib pulley-Milltek catless DP's-FI exhaust l EXTERIOR-RS4 black grille-Custom headlights-LED city & DRL lights-ECS LED tail lights & plate lights l INTERIOR-Custom steering wheel-SRP pedals-ECS LED lights-MOMO shift knob-Gen 2 RNSE & AMI l WHEELS-OEM RS4 W/ Michelin PSS
    Established Member Two Rings Crispy Waffle's Avatar
    Mar 16 2015
    Columbus
    I would recommend using a ceramic coating like C-Quartz. I've applied it to my car last September and it was the best thing I've done. It seals the paint and protects it for up to 2 years depending on the level of use and exposure. Makes the car super easy to clean and it also eliminates the need to wax the car at all. Just need to use a reload spray.
    Only thing that I would say is to make sure you prep the car to the best of your ability including: Iron-X, clay bar, polish, paint correction, paint scratches..etc. Once that coating is dry, it seals everything. I spent about two weeks cleaning and buffing the car before using C-Quartz.
    Good Luck!
    06 s4 - Dolphin Gray - Stasis Exhaust - O34 Motor/Trans/Snub Mounts - Koni/H&R suspension - Hotchkis Sway Bars
    2000 Jeep Cherokee Sport - Rusted Rockers - Rusted Floor Pan - Hood Latch Is Being Weird
    Jul 18 2010
    Ft. Hood, Texas
    Quote Originally Posted by Crispy Waffle View Post
    Good Luck!
    that's probably what I'll do after a respray.
    speaking of which, what's a reasonable amount to expect to spend on a quality respray? I have a few door dings that would need to be taken care of as well.
