Results 1 to 3 of 3
    Senior Member Three Rings engineerjet's Avatar
    Aug 02 2013
    engine issues, started with misfires, the saga continues...
    So a quick update. Originally I have been going through coils like it was my job. I finally schedule some time to get a diag on it and it turns out the PCV valve was leaking and they said it is a good chance that a majority of my issues can be due to the pcv. So i order a new one and install it.
    As i'm driving with the new PCV I noticed right off the bat that every time i take my foot off the gas i can hear the turbo winding down (very noticeable). Sure enough CEL pop up and i use my generic code puller (sorry dont have the exact codes right now) and there are a codes up the wazoo. Codes for fuel pressure (P0089) as well as a bunch of other lean bank codes (again, dont have the exact code)
    This is where things get confusing. I notice the new PCV does not have a check valve, and the old PCV valve did. I do a quick google and it turns out that depending on when the 2007 was produced it could either have a check valve in the pcv or a check valve in the metal breather tube. So naturally i check the date my car was made and it is NOT supposed to have a check valve in the PCV.
    Which means the old PCV i had was the wrong part all along and the new one is the correct one. But now that I have the correct one all these codes are flying, the power seems to be lacking (takes forever to accelerate in higher gears, and that turbo spooling down every time i let off the gas. Has anyone had issues close to this?
    Current setup: APR K04, HPFP, injectors.
    When I switch to stock mode, no issues
    Veteran Member Four Rings mcpcartier's Avatar
    Oct 14 2011
    12 Taco, 13 Ex, 16 Civic EX, 15 JKUR
    post the codes....that give everyone something to go off of.
    2007 2.0T Q 6MT, S-Line, Ti Package, BB
    Revo Stage 2 | JHM Stage 1 Clutch | K&N Drop in | APR HPFP | 034 HFC | AWE Catback | 034 SD Tranny & Motor Mounts | Neuspeed Snub | H&R Sport Springs | Bilsteins | Moog ACA | B5 Perches (removed) | RS4 RSB | ABT Drilled n Slotted Rotors | Redstuff Front & Akebono Rear | Podi Stepper Boost Gauge | Recaro's | H&R Spacers 15f/20r | Clear Corners w/Blackout | Smoked Frt Markers | Cupra R Lip | 20% Tint
    Aug 02 2013
    P0237
    P0106
    P0642
    P0089
    Just got a chance to pull the codes again, I was away from the car before
