    Jun 17 2016
    Ontario
    Replacing one tire only on Quattro OK?
    Hi there,
    The tire guys ripped one of my rear tires, and now they're replacing it. I drive an Audi s5 (2014, quattro is standard). My current tires have 7/32" tread left in the remaining rear one, and 5/32" in both the front ones. Would replacing one tire be OK? I've heard some mixed opinions on this - some have said that it should be fine, while others have said I should shave the new tire to match the existing tires.
    If I should shave it, what should I shave it to? 9/32"? 7/32"? 5/32?
    Any help would be appreciated. Thanks!
    May 20 2010
    Sounds like you haven't been rotating (or not in a while) between the fronts and rears. That said, new tires come with 10/32" tread depth, so that may cause quattro to throw a fit. I have personally gotten a tire via Tire Rack shaved down and it worked like a charm. Shaving it to match the other rear will ensure that when you do rotate them, the fronts will match and the rears will match.
    Best of luck!
    Senior Member Three Rings d1amund's Avatar
    Oct 27 2014
    Park City, UT
    Shave it, at their expense of course.
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    Quattro's tolerance is 4/32" tread depth difference between all for wheels. You are gonna be 1/32" out of tolerance with your front tires and the brand new rear tire. Have it shaved to 7/32" and then rotate your tires, so you get some more even wear.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Jun 17 2016
    2008 Audi A5 3.2 6MT, 2011 MB SL63 AMG, 2016 Hyundai Tucson 1.6T, 2016 Golf R Manual
    New York, NY
    not ok
