Results 1 to 9 of 9
    Jul 15 2014
    Cape Breton Island
    Problems arising
    I have a b6 s4 6 speed and it works great. Having some issues come to the surface. First one is squeak on bumps from the right rear area.. Strut mount or strut? Or bushings?
    The second one is when I cut the wheel all the way left I get a noise coming out of the steering rack ... Only notice doing u turns its fine otherwise. Sounds like a squeak or a dry squeak.
    Let me know what you guys think thanks !
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Check your axles and control arms for damage both front and rear. ;) nice whip!
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Established Member Two Rings jmcdermott's Avatar
    Jul 21 2014
    Canal Winchester, Ohio
    I would also lightly apply your brakes when going over the bumps and see if squeak goes away. If it does then it's your brake pads
    Sent from my SM-G900V using Tapatalk
    Jul 15 2014
    Cape Breton Island
    Quote Originally Posted by Lucca M View Post
    Thanks ! Im pretty sure the noise is coming from the centre of the fire wall; it seems to be making noise on any steering inputs. But I'll look into it
    Jul 15 2014
    Cape Breton Island
    Quote Originally Posted by jmcdermott View Post
    New pads and rotors ! Sounds like a dry strut ? Possibly blown from stock struts + H & R springs?
    Jan 17 2014
    New Jersey
    Check bolts holding the steering rack. Two or three from top one from the bottom. If you google steering rack replacement youll find pics where they are located. They tend to get loose
    Insta: luccamentone
    Jul 15 2014
    Cape Breton Island
    Just to add also the front axles are perfect I replaced one awhile back... Not making clicking its squeaky
    Jul 15 2014
    Cape Breton Island
    Will do thanks also arnt the steering racks on these cars known to go bad ?
    Jan 17 2014
    New Jersey
    I wouldnt say they go bad too often. More often the power steering hoses, thats for sure. But yeah they can go bad for sure.
    Insta: luccamentone
