Results 1 to 3 of 3
    Nov 24 2015
    Leonia, NY
    08 S6 misfires.....P0171 code
    Can I remove air filter and detach air flow sensor momentarily to eliminate air flow sensor as a problem?
    Thanks,
    Established Member Two Rings haloguy628's Avatar
    Sep 01 2011
    Castle Pines North
    Check the vacuum hoses. Usually lean condition means there is leak in the vacuum system.
    The first I would check is not actually a hose but a plastic tube located behind the removable plastic cover with the Audi rings on it. It's right above the oil filter close to the firawall. That plastic tube can easily crack or break if one is not careful changing the oil filter because the electric harness and the vacuum tube has to be moved out of the way to get to the oil filter.
    I would worry about the MAF's as last resort. If MAF was bad you would have misfires and fluctuating idle. I would clean both MAFs with electronic cleaner. Spray the cleaner on the blade and gently use Q-tip to clean. Spray the connectors too.
    Senior Member Three Rings Nizmo's Avatar
    Oct 09 2015
    Boston
    The intake manifold gaskets do leak, as well as the IM flaps breaking.
    Personally, I wouldn't pull 2 MAF's on a master slave system.
