Results 1 to 7 of 7
    Junior Member Two Rings istaygold88's Avatar
    Aug 20 2015
    Panorama city/CA/SoCal
    Needing new rear left axle, which direction should I go?
    the cv joint has torn apart and spitting grease.
    what should I do?
    any advice would greatly be appreciated by everyone
    Senior Member Two Rings mr16valve's Avatar
    Nov 24 2013
    GreenvilleSC
    Raxles & done.
    Veteran Member Three Rings a4kamila6's Avatar
    Sep 30 2015
    A1 cardone with lifetime warranty, raxles, used OEM axle, or new OEM axle.
    I run two A1's and they are great.
    Dec 10 2013
    Borden, Ontario, Canada
    I have a good rear axle I can send you
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Jul 04 2012
    Woodbridge, VA
    Just buy a new boot kit. comes with grease and everything you need. Pull the axle (you could do it still on the car if u want) pull the cv joint off, clean it, regrease, reboot and reinstall. Simple job (but messy). They are like 25 bucks... This is all assuming your Cv is still good. Chances are if it hasn't been broken for years you'll be ok.
    Aug 20 2015
    link to where i could buy a new kit thats considered good?
    Quote Originally Posted by vavJETTAw36 View Post
    Aug 20 2015
    link to their site so i could check them out please
    Quote Originally Posted by a4kamila6 View Post
    - - - Updated - - -
    left rear correct? how much if you don't mind me asking
    Quote Originally Posted by Bordom View Post
